The device (ZOOM UAC-2) is definitely detected by the system, as I can successfully use its MIDI ports. But, the audio side is nowhere to be found. The interface has a “Class Compliant Mode”-switch, and a quick googling reveals that others have had it working out-of-the-box. If I dual-boot to Windows, I am able to use the device no fiddling of drivers.
What I suspect is that the device is marked as a MIDI device only. I have another DAC which has no MIDI ports and it worked straight away. It is not currently plugged in, but I suspect that the confusion of having them both plugged in may have been the cause for this. I am using Pipewire.
Would anyone happen to know how to force flag the device as audio or something similar? Thanks in advance. I wouldn’t mind losing the MIDI-capability in exchange of audio, if that is the price.
EDIT:
Actually, the device is listed under audio, too.
Device-1: NVIDIA GA104 High Definition Audio vendor: Palit Microsystems
driver: snd_hda_intel bus-ID: 1-10:8 v: kernel pcie: chip-ID: 1686:f028
class-ID: 0103 gen: 3 serial: <filter> speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: ZOOM UAC-2 type: USB driver: snd-usb-audio
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.65 running: yes
But it is invisible in any audio related GUI, DAW or system settings?
Also, it is listing PulseAudio on addition to Pipewire, but I thought that I had removed it. Cold this be due to mismatch in having both, PulseAudio and Pipewire installed?
EDIT2:
In qpwgraph the MIDI-ports are tagged as “ALSA”, and not Pipewire. Is this the culprit, that the device is not recognized by Pipewire? If I plug in the second DAC, it is correctly labeled to PipeWire and works immediately.
Sorry, I am new to this.
EDIT3:
The Zoom has no “PLAYBACK” or “CAPTURE”-streams, compared to the other DAC and my GPU.
# Sound card
- card: 0
longname: HDA NVidia at 0xdf080000 irq 17
driver_name: HDA-Intel
mixer_name: Nvidia GPU 9e HDMI/DP
components: HDA:10de009e,1569f278,00100100
controls_count: 28
pcm:
- stream: PLAYBACK
devices:
- device: 3
subdevices:
- subdevice: 0
- device: 7
subdevices:
- subdevice: 0
- device: 8
subdevices:
- subdevice: 0
- device: 9
subdevices:
- subdevice: 0
hwdep:
- device: 0
id: HDA Codec 0
name: HDA Codec 0
iface: 16
# Sound card
- card: 1
longname: ZOOM Corporation UAC-2 at usb-0000:00:14.0-10, high speed
driver_name: USB-Audio
mixer_name: USB Mixer
components: USB1686:f028
controls_count: 0
rawmidi:
- stream: OUTPUT
devices:
- device: 0
subdevices:
- subdevice: 0
name: UAC-2 ZOOM UAC-2 MIDI I/O Port
- subdevice: 1
name: UAC-2 ZOOM UAC-2 Reserved Port
- stream: INPUT
devices:
- device: 0
subdevices:
- subdevice: 0
- subdevice: 1
# Sound card
- card: 2
longname: THOMANN HAD-1 at usb-0000:00:14.0-6.3, full speed
components: USB0002:7022
controls_count: 6
pcm:
- stream: PLAYBACK
devices:
- device: 0
subdevices:
- subdevice: 0
- device: 1
name: USB Audio #1
subdevices:
- subdevice: 0
- stream: CAPTURE
devices:
- device: 0
subdevices:
- subdevice: 0
So, how would I add them?
