Kernel: 5.4.85-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=946d67f7-e2d1-44f8-96b2-4bf678b3bde9 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: H110M-S2H v: N/A serial: <filter>
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F22 date: 06/12/2017
Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 8 MiB
bogomips: 57616
Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
v: 390.138 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5")
s-diag: 692mm (27.3")
Monitor-1: DP-2 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.3.1
compat-v: 3.1 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f0
Sound Server: ALSA v: k5.4.85-1-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 768.8 GiB (82.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX002-2DV162
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: CC41
ID-1: / raw size: 931.22 GiB size: 915.6 GiB (98.32%)
used: 768.8 GiB (84.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 38 C
Processes: 246 Uptime: 3m wakeups: 0 Memory: 15.6 GiB used: 1.84 GiB (11.8%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1427 pacman: 1419
lib: 429 flatpak: 0 snap: 8 Shell: Bash v: 5.1.0 running in: yakuake
inxi: 3.2.01
As you can see I’m using Kernal 5.4.85-1 my system won’t boot into the KDE desktop if I use Kernal 5.10.2-2.
Only video-nvidia-390xx is installed, before the update it was video-nvidia-455xx.
Would installing xf86-video-nouveau
help? or does this mean no more video support for the GTX 1070?
