Hi,
I have a Dell Inspiron laptop running Manjaro with GNOME. I’ve connected 2 external screens: with HDMI and VGA. Both screens are detected, but I can use only 2/3 screens at a time. When I turn off an inactive screen in the settings, one of the just turns off.
Any help would be appreciated.
UPDATE:
when I select resolutions with the same refresh rate for all screens, it works, but maybe there is a way to use 3 different refresh rates so i can get the most of my monitors.
xrandr
Screen 0: minimum 320 x 200, current 4400 x 900, maximum 16384 x 16384
LVDS-1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
1600x900 60.08*+ 59.99 59.94 59.95 59.82
1400x900 59.96 59.88
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
VGA-1 connected 1440x900+2960+0 (normal left inverted right x axis y axis) 428mm x 255mm
1440x900 59.89*+ 74.98
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1152x864 75.00
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
640x480 75.00 72.81 66.67 59.94
720x400 70.08
HDMI-1 connected (normal left inverted right x axis y axis)
1360x768 60.02 +
1280x768 59.87
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32
640x480 75.00 59.94
720x400 70.08
DP-1 disconnected (normal left inverted right x axis y axis)
VGA-1-2 disconnected (normal left inverted right x axis y axis)
inxi -Fxzc0
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 41.1 Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron 7720 v: N/A
serial: <superuser required>
Mobo: Dell model: 04M3YM v: A00 serial: <superuser required> UEFI: Dell
v: A17 date: 05/19/2015
ID-1: BAT0 charge: 25.0 Wh (87.1%) condition: 28.7/48.8 Wh (58.8%)
volts: 12.5 min: 11.1 model: LGC Dell status: Charging
Info: Quad Core model: Intel Core i7-3630QM bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L2: 1024 KiB
flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 38333
Speed: 1422 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 2789 2: 3118
3: 1613 4: 2734 5: 1591 6: 1794 7: 2431 8: 1448
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GK107M [GeForce GT 650M] vendor: Dell driver: nouveau
v: kernel bus-ID: 01:00.0
Device-3: Microdia Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.5:4
Display: x11 server: X.org 1.21.1.1 driver: loaded: modesetting
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.2.5 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
bus-ID: 02:00.0
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
IF-ID-1: br-d2869540791f state: down mac: <filter>
IF-ID-2: br-d87ad3073ef6 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 2-1.5:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 232.89 GiB used: 49.53 GiB (21.3%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-1: / size: 232.59 GiB used: 49.53 GiB (21.3%) fs: btrfs dev: /dev/dm-0
mapped: luks-b4274039-4658-4b7b-a9be-50f2aa3511d5
ID-2: /boot/efi size: 299.4 MiB used: 712 KiB (0.2%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 232.59 GiB used: 49.53 GiB (21.3%) fs: btrfs
dev: /dev/dm-0 mapped: luks-b4274039-4658-4b7b-a9be-50f2aa3511d5
ID-4: /var/log size: 232.59 GiB used: 49.53 GiB (21.3%) fs: btrfs
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%)
file: /swap/swapfile
System Temperatures: cpu: 59.0 C mobo: 39.0 C sodimm: SODIMM C
gpu: nouveau temp: 41.0 C
Processes: 340 Uptime: 51m Memory: 15.49 GiB used: 5.94 GiB (38.4%)
Init: systemd Compilers: gcc: 11.1.0 Packages: 1262 Shell: Zsh v: 5.8
inxi: 3.3.09
