So, sometimes I check is there a problem in the system, and now I found that:
Hi @lightsweet,
To be totally honest I don’t think that is a problem, as such. I don’t think it’s something that runs permanently. I suspect it’s just for getting a list of package changes for your installed packages.
Mine also says loaded
, like yours, and like yours it also shows inactive
$ systemctl status pkgfile-update.service
● pkgfile-update.service - pkgfile database update
Loaded: loaded (/usr/lib/systemd/system/pkgfile-update.service; static)
Active: inactive (dead)
Feb 26 09:45:48 Mirdarthos-PC systemd[1]: Starting pkgfile database update...
Feb 26 09:45:55 Mirdarthos-PC systemd[1]: pkgfile-update.service: Succeeded.
Feb 26 09:45:55 Mirdarthos-PC systemd[1]: Finished pkgfile database update.
And I don’t think it can, or in fact should, be removed. So, the sudo pacman -Rns pkgfile
doesn’t work, and I don’t think that’s an error. Also, I think the name pkgfile
is incorrect, I suspect it’s pkgfile-update
Edit:
Also, please, if you post again in the futuree, please don’t post screenshots. Rather copy the text from the terminal and paste it in the post, wrapped in triple backticks (```) to format it for legibility.
Hope this helps!
