Hi everyone!
So, since the last stable update my system freezes suddenly and it’s completely unresponsive to any input and it’s only fixed by a reset.
Now, I think I isolated the problem: it only happens when I’m playing Hearthstone via Lutris, so from time to time my system freezes midgame.
Hearthstone it’s not my main concern, if I have to give it up to have a stable system so be it, but I want to know what is causing the issue and I’m not competent enough to find/understand the information from the journal so I’m asking for help.
It all was just fine before the last update and I think it’s very strange that it affects only that application.
Again, I’m not asking for support on lutris/hearthstone, I just want to know how to isolate and track down what the issue is and maybe learn how to troubleshoot this kind of problems in the future!
Thank you in advance and a have a great day!
inxi -Fazy
Kernel: 5.4.97-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=5f7a7ef9-ca3d-413a-8734-f763cb82c6ef rw pci=noaer quiet apparmor=1
security=apparmor resume=UUID=bc81d4a7-d397-440e-9225-c2eae38cb1df
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X541UAK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X541UAK v: 1.0 serial: <filter>
UEFI: American Megatrends v: X541UAK.311 date: 03/14/2018
ID-1: BAT0 charge: 24.4 Wh condition: 28.5/34.6 Wh (83%) volts: 10.8/10.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 490
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: E2
L2 cache: 3 MiB
bogomips: 16006
Speed: 730 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 730 2: 735 3: 743
4: 728
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1916 class ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 13d3:5a01 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d70 class ID: 0403
Sound Server: ALSA v: k5.4.97-1-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: e000 bus ID: 02:00.2 chip ID: 10ec:8136
class ID: 0200
IF: enp2s0f2 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:b723
class ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus ID: 1-8:4 chip ID: 0bda:b721 class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 577.55 GiB used: 170.18 GiB (29.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT120BX500SSD1
size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: R013 scheme: GPT
ID-1: / raw size: 161.13 GiB size: 157.6 GiB (97.81%)
used: 73.15 GiB (46.4%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw size: 500 MiB size: 499 MiB (99.80%)
used: 320 KiB (0.1%) fs: vfat dev: /dev/sda6 maj-min: 8:6
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 33.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 177 Uptime: 15m wakeups: 4 Memory: 7.66 GiB used: 1.8 GiB (23.6%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages:
pacman: 1571 lib: 497 flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole
inxi: 3.3.01
