When I log on, there is absolutely nothing to see in my network connections: no wired, no WiFi, just nothing!
How should I proceed?
It helps if you tell us which wifi adapter you have. You probably need to install the drivers for it, or use a newer kernel that supports it.
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
