Hello forum users,
First time poster here.
I have got something weird. On boot I login, my DE/WM does not kick in, nothing works. I only see the loginscreen in the same state as it was when I pressed enter.
I figured that if I go to my 2nd tty crtl+alt+f2, login and run startx, in that tty startx will fail. When I went back to my DE it was working as intended. I honestly have no clue what is going on, I hope someone here does!
Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=1cf4cabc-b60a-4742-a9c9-4bf249b425bd rw quiet
resume=UUID=b680e8c3-6c4d-4d37-b946-fea59c35179d
Desktop: i3 4.16.1-184-g582d9e9b info: polybar dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450M-A PRO MAX (MS-7C52) v: 1.0
serial: <filter> UEFI: American Megatrends v: 3.00 date: 08/13/2019
Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D
L2 cache: 4096 KiB
bogomips: 132847
Speed: 3806 MHz min/max: N/A Core speeds (MHz): 1: 3806 2: 3327 3: 3354
4: 3330 5: 3848 6: 4005 7: 4069 8: 3377 9: 4149 10: 3522 11: 4140 12: 4114
13: 4037 14: 3805 15: 3635 16: 3345
disabled, RSB filling
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 29:00.0
chip ID: 10de:13c2
Display: x11 server: X.Org 1.20.8 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 109 s-size: 1193x335mm (47.0x13.2")
s-diag: 1239mm (48.8")
Monitor-1: HDMI-0 res: 5120x1440 hz: 60 dpi: 130048 size: 1x1mm (0.0x0.0")
diag: 1mm (0.1")
OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Device-1: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 29:00.1 chip ID: 10de:0fbb
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 2b:00.3 chip ID: 1022:1457
Device-3: Logitech G430 Surround Sound Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:5 chip ID: 046d:0a4d
Sound Server: ALSA v: k5.4.64-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel modules: r8168 port: f000
bus ID: 25:00.0 chip ID: 10ec:8168
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: enp3s0f0u7 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 689.33 GiB used: 418.69 GiB (60.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 2B6Q scheme: GPT
ID-2: /dev/sdb vendor: Kingston model: SA400S37240G size: 223.57 GiB
rev: B1E1 scheme: GPT
ID-1: / raw size: 456.66 GiB size: 448.50 GiB (98.21%)
used: 418.69 GiB (93.4%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 57.6 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 23%
Processes: 344 Uptime: 23m Memory: 15.65 GiB used: 4.87 GiB (31.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8/9 Packages: 1645
pacman: 1640 lib: 445 flatpak: 5 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
