On budgie opening calendar opens text editor
Hi,
Where is the bug tracker?
Issue can be replicated by doing following steps:
  1. Fresh install
  2. Open calendar (type in budgie search calendar and press enter or whatever)
It is not a big deal, easily changed within installation, although for general public encountering this issue may cause a big disappointment in quality check and therefore negatively influence the outlook on manjaro.
Farewell.
Read this post. I had similar issue.
