Old kernel removals - mine don't get removed automatically
@cscs
Only kernel-modules-hook
Something does seem wonky.
I also have kernel-modules-hook installed, and usr/lib/modules has old kernel modules fully populated - 123 directories, 675 files
I uninstalled 5.15 not that long ago, yet it’s still listed here, and I see modules for seemingly every version of 6.10 released, but only one for 6.6 and only one for 6.11 (6.11.0-7 which I just reinstalled today), I did have 6.11.0-3 but uninstalled that.
/usr/lib/modules/
β”œβ”€β”€ 5.15.163-2-MANJARO
β”œβ”€β”€ 6.10.0-1-MANJARO
β”œβ”€β”€ 6.10.0-2-MANJARO
β”œβ”€β”€ 6.10.0-3-MANJARO
β”œβ”€β”€ 6.10.0-4-MANJARO
β”œβ”€β”€ 6.10.10-2-MANJARO
β”œβ”€β”€ 6.10.10-3-MANJARO
β”œβ”€β”€ 6.10.11-1-MANJARO
β”œβ”€β”€ 6.10.11-2-MANJARO
β”œβ”€β”€ 6.10.11-3-MANJARO
β”œβ”€β”€ 6.10.1-1-MANJARO
β”œβ”€β”€ 6.10.3-1-MANJARO
β”œβ”€β”€ 6.10.3-2-MANJARO
β”œβ”€β”€ 6.10.3-3-MANJARO
β”œβ”€β”€ 6.10.3-4-MANJARO
β”œβ”€β”€ 6.10.3-5-MANJARO
β”œβ”€β”€ 6.10.3-6-MANJARO
β”œβ”€β”€ 6.10.4-1-MANJARO
β”œβ”€β”€ 6.10.5-1-MANJARO
β”œβ”€β”€ 6.10.5-2-MANJARO
β”œβ”€β”€ 6.10.5-4-MANJARO
β”œβ”€β”€ 6.10.6-10-MANJARO
β”œβ”€β”€ 6.10.6-11-MANJARO
β”œβ”€β”€ 6.10.6-12-MANJARO
β”œβ”€β”€ 6.10.6-1-MANJARO
β”œβ”€β”€ 6.10.6-2-MANJARO
β”œβ”€β”€ 6.10.6-3-MANJARO
β”œβ”€β”€ 6.10.6-7-MANJARO
β”œβ”€β”€ 6.10.6-8-MANJARO
β”œβ”€β”€ 6.10.7-1-MANJARO
β”œβ”€β”€ 6.10.7-2-MANJARO
β”œβ”€β”€ 6.10.7-3-MANJARO
β”œβ”€β”€ 6.10.7-4-MANJARO
β”œβ”€β”€ 6.10.8-1-MANJARO
β”œβ”€β”€ 6.10.8-3-MANJARO
β”œβ”€β”€ 6.10.8-4-MANJARO
β”œβ”€β”€ 6.10.9-1-MANJARO
β”œβ”€β”€ 6.10.9-2-MANJARO
β”œβ”€β”€ 6.11.0-7-MANJARO
β”œβ”€β”€ 6.6.52-1-MANJARO
β”œβ”€β”€ extramodules-5.15-MANJARO
└── extramodules-6.6-MANJARO
Aha.
I think I found it. In my case at least.
@ydar @MAYBL8
And anyone else who has this effect while using kernel-modules-hook.
Have you started or enabled linux-modules-cleanup.service ?
Give it a go and then review your directories again.
(if you use something like systemctl start linux-modules-cleanup you may need to wait a while for it to complete … especially if you have many old modules directories)
Users may need to install the kernel-modules-hook package to access that service:
pamac list -f kernel-modules-hook        ξ‚² βœ”
/usr/lib/systemd/system/linux-modules-cleanup.service
/usr/lib/tmpfiles.d/linux-modules-cleanup.conf
/usr/share/libalpm/hooks/10-linux-modules-post.hook
/usr/share/libalpm/hooks/10-linux-modules-pre.hook
/usr/share/licenses/kernel-modules-hook/UNLICENSE
pamac info kernel-modules-hook        ξ‚² βœ”
Version               : 0.1.7-3
Description           : Keeps your system fully functional after a kernel upgrade
URL                   : https://github.com/saber-nyan/kernel-modules-hook
Licenses              : UNLICENSE
Repository            : extra
Installed Size        : 2.4 kB
Groups                : --
Depends On            : rsync
Optional Dependencies : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : T.J. Townsend <blakkheim@archlinux.org>
Build Date            : Sat 13 Jul 2024 05:06:11
Validated By          : MD5 Sum  SHA-256 Sum  Signature
It isn’t part of the default installation (at least it wasn’t when I set up my new PC a year ago), and is aimed at users who do not immediately reboot after a kernel update.
Of course.
That is the subject.
It is a remedy for in the case of using it and therefor experiencing the old modules folder.
(added extra bold)
Rechecking the progress of this thread, I got curious …
I always reboot my system after maintenance tasks involving the kernel.
I remember all the issues surrounding the - at the time - hot topic that prompted for inclusion of the hooks which should keep the kernel alive by holding kernel modules until reboot.
07:33:53 β—‹ [fh@tiger] ~
 $ mhwd-kernel -li
Currently running: 6.11.0-7-MANJARO (linux611)
   * linux611
07:34:00 β—‹ [fh@tiger] ~
 $ tree /usr/lib/modules -L2
/usr/lib/modules
β”‚   └── modules.weakdep
└── 6.11.0-7-MANJARO
    β”œβ”€β”€ build
    β”œβ”€β”€ kernel
    β”œβ”€β”€ kernelbase
    β”œβ”€β”€ modules.alias
    β”œβ”€β”€ modules.alias.bin
    β”œβ”€β”€ modules.builtin
    β”œβ”€β”€ modules.builtin.alias.bin
    β”œβ”€β”€ modules.builtin.bin
    β”œβ”€β”€ modules.builtin.modinfo
    β”œβ”€β”€ modules.dep
    β”œβ”€β”€ modules.dep.bin
    β”œβ”€β”€ modules.devname
    β”œβ”€β”€ modules.order
    β”œβ”€β”€ modules.softdep
    β”œβ”€β”€ modules.symbols
    β”œβ”€β”€ modules.symbols.bin
    β”œβ”€β”€ modules.weakdep
    β”œβ”€β”€ pkgbase
    β”œβ”€β”€ updates
    └── vmlinuz
6 directories, 18 files
07:35:19 β—‹ [fh@tiger] ~
 $ pamac search kernel-modules-hook --no-aur
kernel-modules-hook  0.1.7-3        extra
07:35:34 β—‹ [fh@tiger] ~
 $ pamac search -f modules.weakdep --no-aur
/usr/lib/modules/6.1.110-1-MANJARO/modules.weakdep is owned by linux61
/usr/lib/modules/6.10.10-2-MANJARO/modules.weakdep is owned by linux610
/usr/lib/modules/6.6.49-2-rt41-MANJARO/modules.weakdep is owned by linux66-rt
/usr/lib/modules/6.6.51-1-MANJARO/modules.weakdep is owned by linux66
/usr/lib/modules/6.10.2-5-rt14-MANJARO/modules.weakdep is owned by linux610-rt
/usr/lib/modules/5.4.284-1-MANJARO/modules.weakdep is owned by linux54
/usr/lib/modules/5.10.226-1-MANJARO/modules.weakdep is owned by linux510
/usr/lib/modules/4.19.322-1-MANJARO/modules.weakdep is owned by linux419
/usr/lib/modules/5.15.167-1-MANJARO/modules.weakdep is owned by linux515
/usr/lib/modules/6.1.108-2-rt40-MANJARO/modules.weakdep is owned by linux61-rt
/usr/lib/modules/6.11.0-rc7-3-MANJARO/modules.weakdep is owned by linux611
What I find strange here, is the fact that the file does not get removed when removing the kernel.
My system does not have the kernel-modules-hook synced - so the remnants on my system cannot be related to that.
If you are not using kernel-modules-hook then yes its different.
I think we have at least 2 different issues here.
  • kernel-modules-hook users with fully populated past kernel modules directories
  • Non-users of kernel-modules-hook that somehow retain /usr/lib/modules/*/modules.weakdep
In the first case I believe it is solved by the related service (linux-modules-cleanup).
Which of course makes total sense … If you have some script that fires to copy the modules for the current kernel and the newly installed version - making sure that your current session does not lose modules - when is it going to remove the old kernel modules? Obviously not during the current session - that would defeat the purpose of the script. The script itself cant do the removal now, or on next boot when its no longer running, etc. So there is a service that if ran will clean up the old modules. Or if enabled will check for and remove them on next session.
I dont know about the second case. Its not reflected in my current situation - I am of the first group.
Yup - the latter confuses me - the file left behind clearly belongs to the package in question - why does pacman leave it behind?
The behaviour is recent as I have had all the previous kernels at some point - but only 6.10 leaves the file behind?
One is speculating if the pacman release candidate is causing this?
I wonder about hooks maybe.
uhmm …?
pacman -Qo /usr/share/libalpm/hooks/*
grep -l modules /usr/share/libalpm/hooks/*
And then some manual cats to see what they do.
I also slapped together this bash line …
_hooks2review="./hooks_to_review.txt"; printf '\n Searching and compiling hooks for review.\n\n Please open %s'"$_hooks2review"'\n\n'; printf '\n# These hooks contain reference to "modules."\n# Please Review.\n\n' > $_hooks2review && grep -l modules /usr/share/libalpm/hooks/* | while IFS= read -r line; do printf "\n\n%s""${line}""\n\n" && cat "${line}"; done >> $_hooks2review
here are the hooks to review
# Please Review.
/usr/share/libalpm/hooks/60-depmod.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/modules/*/
Target = !usr/lib/modules/*/?*
[Action]
Description = Updating module dependencies...
When = PostTransaction
Exec = /usr/share/libalpm/scripts/depmod
NeedsTargets
/usr/share/libalpm/hooks/60-mkinitcpio-remove.hook
[Trigger]
Type = Path
Operation = Remove
Target = usr/lib/modules/*/vmlinuz
[Trigger]
Type = Package
Operation = Remove
Target = mkinitcpio
Target = mkinitcpio-git
[Action]
Description = Removing linux initcpios...
When = PreTransaction
Exec = /usr/share/libalpm/scripts/mkinitcpio remove
NeedsTargets
/usr/share/libalpm/hooks/90-mkinitcpio-install.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/initcpio/*
Target = usr/lib/firmware/*
Target = usr/src/*/dkms.conf
Target = usr/lib/systemd/systemd
Target = usr/bin/cryptsetup
Target = usr/bin/lvm
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
[Trigger]
Type = Package
Operation = Install
Operation = Upgrade
Target = mkinitcpio
[Action]
Description = Updating linux initcpios...
Exec = /usr/share/libalpm/scripts/mkinitcpio install
NeedsTargets
/usr/share/libalpm/hooks/99-update-grub.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = boot/vmlinuz*
[Action]
Description = Updating Grub-Bootmenu
Exec = /usr/bin/update-grub
/usr/share/libalpm/hooks/detect-old-perl-modules.hook
[Trigger]
Operation = Install
Operation = Upgrade
Type = Path
Target = usr/lib/perl5/*/
[Action]
Description = Warn about old perl modules
Exec = /usr/share/libalpm/scripts/detect-old-perl-modules.sh
/usr/share/libalpm/hooks/gdk-pixbuf-query-loaders-32.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib32/gdk-pixbuf-2.0/2.10.0/loaders/*.so
[Action]
Description = Probing 32-bit GDK-Pixbuf loader modules...
Exec = /usr/bin/gdk-pixbuf-query-loaders-32 --update-cache
/usr/share/libalpm/hooks/gdk-pixbuf-query-loaders.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/*.so
[Action]
Description = Probing GDK-Pixbuf loader modules...
Exec = /usr/bin/gdk-pixbuf-query-loaders --update-cache
/usr/share/libalpm/hooks/gio-querymodules-32.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib32/gio/modules/*.so
[Action]
Description = Updating 32-bit GIO module cache...
Exec = /usr/bin/gio-querymodules-32 /usr/lib32/gio/modules
/usr/share/libalpm/hooks/gio-querymodules.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/gio/modules/*.so
[Action]
Description = Updating GIO module cache...
Exec = /usr/bin/gio-querymodules /usr/lib/gio/modules
/usr/share/libalpm/hooks/gtk4-querymodules.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/gtk-4.0/4.0.0/*/
[Action]
Description = Updating GTK4 module cache...
Exec = /usr/share/libalpm/scripts/gtk4-querymodules
NeedsTargets
/usr/share/libalpm/hooks/gtk-query-immodules-2.0.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/gtk-2.0/2.10.0/immodules/*.so
[Action]
Description = Probing GTK2 input method modules...
Exec = /usr/bin/gtk-query-immodules-2.0 --update-cache
/usr/share/libalpm/hooks/gtk-query-immodules-3.0-32.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib32/gtk-3.0/3.0.0/immodules/*.so
[Action]
Description = Probing 32-bit GTK3 input method modules...
Exec = /usr/bin/gtk-query-immodules-3.0-32 --update-cache
/usr/share/libalpm/hooks/gtk-query-immodules-3.0.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/gtk-3.0/3.0.0/immodules/*.so
[Action]
Description = Probing GTK3 input method modules...
Exec = /usr/bin/gtk-query-immodules-3.0 --update-cache
I think the offending one is /usr/share/libalpm/hooks/60-depmod.hook but i cannot fully understand the script
[teo@teo-lenovo-v15 ~]$ cat /usr/share/libalpm/scripts/depmod
#!/bin/bash
while read -r f; do
  if [[ -e ${f}modules.order ]]; then
    depmod $(basename "$f")
  elif [[ -d $f ]]; then
    rm -f "${f}"modules.{alias,alias.bin,builtin.alias.bin,builtin.bin} \
          "${f}"modules.{dep,dep.bin,devname,softdep,symbols,symbols.bin}
    rmdir --ignore-fail-on-non-empty "$f"
  fi
done
# vim:set ft=sh sw=2 et:
for example modules.order should also have been left from the cleaning but it is not.
Maybe this line of /usr/share/libalpm/hooks/60-depmod.hook:
should be changed to:
"${f}"modules.{dep,dep.bin,devname,softdep,symbols,symbols.bin,weakdep}
Edit (since I can’t post 2 replies in a row):
This kernel.org thread might also be helpful in assessing what, if any, action should be taken. The thread is from the end of July, 2024:
https://lore.kernel.org/lkml/CAK7LNATMauHO_vqr+3LKyLWw9AZ2Y=dxhbgaaVNjdz_qm5Xm=w@mail.gmail.com/T/#u
It is certainly a recent change because i have only 1 old version, from August. So that must be it, but i do not fully understand what is it it and how it works so i would not touch it with a broomstick :slight_smile:
But as said, if that is the cleaning filter, another 3 files are not covered with it, and they are gone. So there is maybe something else.
You guys are the best.
Sorry didn’t mean to uncover a can of worms.
So to summarize for me at least.
I have kernel-modules-hook and if I run the cleanup service I should be good to go and not have this issue anymore?
Thanks
Report back (in a day or so) to confirm whether or not it worked for you.
To add to what already have been discovered, my modules folder looks like this:
> tree -L2 -v /usr/lib/modules/
/usr/lib/modules/
β”œβ”€β”€ 5.10.63-1-MANJARO
β”‚   β”œβ”€β”€ extra
β”‚   └── kernel
β”œβ”€β”€ 5.13.15-1-MANJARO
β”‚   β”œβ”€β”€ extra
β”‚   └── kernel
β”œβ”€β”€ 5.15.76-1-MANJARO
β”‚   └── updates
β”œβ”€β”€ 5.15.84-1-MANJARO
β”‚   └── updates
β”œβ”€β”€ 5.15.85-1-MANJARO
β”‚   β”œβ”€β”€ kernel
β”‚   └── updates
β”œβ”€β”€ 5.17.1-3-MANJARO
β”‚   β”œβ”€β”€ build
β”‚   β”œβ”€β”€ extramodules -> ../extramodules-5.17-MANJARO
β”‚   β”œβ”€β”€ kernelbase
β”‚   β”œβ”€β”€ modules.alias
β”‚   β”œβ”€β”€ modules.alias.bin
β”‚   β”œβ”€β”€ modules.builtin
β”‚   β”œβ”€β”€ modules.builtin.alias.bin
β”‚   β”œβ”€β”€ modules.builtin.bin
β”‚   β”œβ”€β”€ modules.builtin.modinfo
β”‚   β”œβ”€β”€ modules.dep
β”‚   β”œβ”€β”€ modules.dep.bin
β”‚   β”œβ”€β”€ modules.devname
β”‚   β”œβ”€β”€ modules.order
β”‚   β”œβ”€β”€ modules.softdep
β”‚   β”œβ”€β”€ modules.symbols
β”‚   β”œβ”€β”€ modules.symbols.bin
β”‚   β”œβ”€β”€ pkgbase
β”‚   └── vmlinuz
β”œβ”€β”€ 5.18.17-1-MANJARO
β”‚   β”œβ”€β”€ build
β”‚   β”œβ”€β”€ extra
β”‚   β”œβ”€β”€ extramodules -> ../extramodules-5.18-MANJARO
β”‚   β”œβ”€β”€ modules.weakdep
β”‚   β”œβ”€β”€ updates
β”‚   └── vmlinuz
β”œβ”€β”€ 5.19.17-1-MANJARO
β”‚   └── updates
β”œβ”€β”€ 6.0.14-1-MANJARO
β”‚   └── updates
β”œβ”€β”€ 6.6.46-1-MANJARO
β”œβ”€β”€ 6.6.47-1-MANJARO
β”‚   β”œβ”€β”€ build
β”‚   └── vmlinuz
└── 6.10.6-10-MANJARO
    β”œβ”€β”€ build
    β”œβ”€β”€ kernel
    β”œβ”€β”€ pkgbase
    β”œβ”€β”€ updates
    └── vmlinuz
38 directories, 71 files
I have a bunch of really old stuff (and only 6.6.47-1 and 6.10.6-10 are installed right now).
The older kernels seems to be about something already fixed.
The modules.weakdep thing seems to be quite recent. It only affects my previous kernels.
> grep -P '(installed|removed|upgraded) linux66 ' /var/log/pacman.log
...omitted for brevity...
[2024-07-29T07:33:43+0300] [ALPM] upgraded linux66 (6.6.40-1 -> 6.6.41-1)
[2024-08-08T19:43:18+0300] [ALPM] upgraded linux66 (6.6.41-1 -> 6.6.44-1)
[2024-08-22T19:48:50+0300] [ALPM] upgraded linux66 (6.6.44-1 -> 6.6.46-1)
[2024-09-03T08:48:11+0300] [ALPM] upgraded linux66 (6.6.46-1 -> 6.6.47-1)
> grep -P '(installed|removed|upgraded) linux610 ' /var/log/pacman.log
[2024-08-08T19:45:59+0300] [ALPM] installed linux610 (6.10.3-1)
[2024-08-22T19:48:47+0300] [ALPM] upgraded linux610 (6.10.3-1 -> 6.10.5-1)
[2024-09-03T08:48:08+0300] [ALPM] upgraded linux610 (6.10.5-1 -> 6.10.6-10)
I do NOT have installed kernel-modules-hook nor kernel-alive.
No need to apologise for reporting an issue that may affect many users
I had a similar problem. Installed kernel-modules-hook and used linux-modules-cleanup to remove old modules
$ systemctl status linux-modules-cleanup
β—‹ linux-modules-cleanup.service - Clean up modules from old kernels
     Loaded: loaded (/usr/lib/systemd/system/linux-modules-cleanup.service; disabled; preset: disabled)
     Active: inactive (dead)
Sep 29 21:57:01 gnomic bash[6686]: + for i in /usr/lib/modules/[0-9]*
Sep 29 21:57:01 gnomic bash[6686]: + [[ 6.6.52-1-MANJARO = \6\.\1\.\1\1\1\-\1\-\M\A\N\J\A\R\O ]]
Sep 29 21:57:01 gnomic bash[6686]: + pacman -Qo /usr/lib/modules/6.6.52-1-MANJARO
Sep 29 21:57:01 gnomic bash[6705]: /usr/lib/modules/6.6.52-1-MANJARO/ is owned by linux66 6.6.52-1
Sep 29 21:57:01 gnomic bash[6705]: /usr/lib/modules/6.6.52-1-MANJARO/ is owned by linux66-headers 6.6.52-1
Sep 29 21:57:01 gnomic bash[6705]: /usr/lib/modules/6.6.52-1-MANJARO/ is owned by linux66-nvidia-470xx 470.256.02-23
Sep 29 21:57:01 gnomic bash[6686]: + continue
Sep 29 21:57:01 gnomic systemd[1]: linux-modules-cleanup.service: Deactivated successfully.
Sep 29 21:57:01 gnomic systemd[1]: Finished Clean up modules from old kernels.
Sep 29 21:57:01 gnomic systemd[1]: linux-modules-cleanup.service: Consumed 763ms CPU time, 102.6M memory peak
But … like …
The issue is that if using kernel-modules-hook … you need to also use the included service or else these fully populated modules folders continue to exist.
The other issue is users not using kernel-modules-hook that for some other reason retain modules.weakdep files (the old modules folders are not fully populated).
I suppose you can use the service from kernel-modules-hook to automatically remove the old modules folders … but thats … fixing issue 2 by introducing and then solving issue 1.
You can start the service to run it once immediately.
For β€˜never think about this again’ solution then you should enable it.
systemctl enable linux-modules-cleanup --now
(it will run each login and check for old modules folders, and delete if they exist will move them to .old in that directory, and .old will be cleaned by systemd-tmpfiles-clean.service as defined by the config file /usr/lib/tmpfiles.d/linux-modules-cleanup.conf)
Mine aren’t deleted. They were moved to a hidden folder /usr/lib/modules/.old
This really is not ideal and I’m sure it’s a bug. Anyway, I think I’m just going to manually delete them.
Sorry, I should have been more explicit.
This is controlled by /usr/lib/tmpfiles.d/linux-modules-cleanup.conf;
R! /usr/lib/modules/.old/* - - - 4w
Which is defined like here:
https://www.man7.org/linux/man-pages/man5/tmpfiles.d.5.html
And so will be taken care of according to that configuration and systemd-tmpfiles and/or the systemd-tmpfiles-clean.service and/or systemd-tmpfiles-clean.timer.
You can also run**
sudo systemd-tmpfiles --remove
** In fact this wont remove it with the default conf. Due to the ! in R! the removal can only happen during boot.
Which will do it right away - for things in .old that are older than 4 weeks, with the default conf. You can edit it to 12h for 12 hours and so on.
I did not introduce an issue. Issue occurred after latest Testing branch update
Data posted for cleanup service you suggested to confirm it works as expected
I am on Testing branch with pacman 6.1.0-7
I had old versions of modules.weakdep for kernels 6.1 and 6.6 but not for 6.10
Partner’s system on stable branch had similar issue for both installed kernels 6.1 and 6.6
$ ls -al /usr/lib/modules
total 264
drwxr-xr-x   6 root root   4096 Sep  6 11:37 .
drwxr-xr-x 244 root root 241664 Sep  6 11:37 ..
drwxr-xr-x   2 root root   4096 Sep  6 11:37 6.1.105-1-MANJARO
drwxr-xr-x   4 root root   4096 Sep  6 11:37 6.1.106-1-MANJARO
drwxr-xr-x   2 root root   4096 Sep  6 11:37 6.6.46-1-MANJARO
drwxr-xr-x   4 root root   4096 Sep  6 11:37 6.6.47-1-MANJARO
Old folders deleted manually
