Okami had been working fine on my setup until I tried to change the resolution after I realized I had it on low settings. It crashed and now won’t run via proton. My log from running steam through the command line is:
~ >>> steam
Running Steam on manjarolinux 20.2 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client's requirements are satisfied
/home/sir-alien-the-great/.local/share/Steam/ubuntu12_32/steam
[2020-12-14 15:43:47] Startup - updater built Dec 7 2020 18:04:23
Installing breakpad exception handler for appid(steam)/version(1607372145)
[2020-12-14 15:43:47] Loading cached metrics from disk (/home/sir-alien-the-great/.local/share/Steam/package/steam_client_metrics.bin)
[2020-12-14 15:43:47] Using the following download hosts for Public, Realm steamglobal
[2020-12-14 15:43:47] 1. http://media4.steampowered.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2020-12-14 15:43:47] Verifying installation...
[2020-12-14 15:43:47] Verification complete
Loaded SDL version 2.0.13-6246010
(steam:98247): Gtk-WARNING **: 15:43:48.817: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Matcha-dark-sea/gtk-2.0/main.rc:1113: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Matcha-dark-sea/gtk-2.0/apps.rc:91: error: unexpected identifier 'direction', expected character '}'
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[1214/154349.053954:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[1214/154349.072026:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1214/154349.072076:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1607364283
[1214/154349.072079:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1214/154349.072082:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
/usr/lib/gio/modules/libdconfsettings.so: undefined symbol: g_log_structured_standard
Failed to load module: /usr/lib/gio/modules/libdconfsettings.so
GLib-GIO-Message: Using the 'memory' GSettings backend. Your settings will not be saved or shared with other applications.
[1214/154349.100190:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1214/154349.100236:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1607364283
[1214/154349.100239:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1214/154349.100241:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[1214/154349.100861:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[1214/154349.164046:ERROR:sandbox_linux.cc(372)] InitializeSandbox() called with multiple threads in process gpu-process.
[1214/154349.188832:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1214/154349.188880:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1607364283
[1214/154349.188883:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1214/154349.188885:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[1214/154349.189361:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CAppInfoCacheReadFromDiskThread took 33 milliseconds to initialize
CApplicationManagerPopulateThread took 90 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
Proceed to auto login
** (steam:98247): WARNING **: 15:43:49.454: Unknown device type 16
** (steam:98247): WARNING **: 15:43:49.454: Could not create object for /org/freedesktop/NetworkManager/Devices/15: unknown object type
** (steam:98247): WARNING **: 15:43:49.454: handle_property_changed: failed to update property 'devices' of object type NMActiveConnection.
** (steam:98247): WARNING **: 15:43:49.458: Unknown device type 14
** (steam:98247): WARNING **: 15:43:49.458: Could not create object for /org/freedesktop/NetworkManager/Devices/1: unknown object type
** (steam:98247): WARNING **: 15:43:49.460: Unknown device type 16
** (steam:98247): WARNING **: 15:43:49.460: Could not create object for /org/freedesktop/NetworkManager/Devices/15: unknown object type
Opted-in Controller Mask for AppId 0: c
** (steam:98247): WARNING **: 15:43:49.723: Ignoring invalid property 'autoconnect-priority'
** (steam:98247): WARNING **: 15:43:49.723: Ignoring invalid property 'interface-name'
** (steam:98247): WARNING **: 15:43:49.723: Unknown setting 'proxy'
** (steam:98247): WARNING **: 15:43:49.723: Ignoring invalid property 'route-data'
** (steam:98247): WARNING **: 15:43:49.723: Ignoring invalid property 'address-data'
** (steam:98247): WARNING **: 15:43:49.723: Unknown setting 'tun'
** (steam:98247): WARNING **: 15:43:49.723: Ignoring invalid property 'dns-priority'
** (steam:98247): WARNING **: 15:43:49.723: replace_settings: error updating connection /org/freedesktop/NetworkManager/Settings/13 settings: (3) type
** (steam:98247): WARNING **: 15:43:49.724: Ignoring invalid property 'autoconnect-priority'
** (steam:98247): WARNING **: 15:43:49.724: Ignoring invalid property 'interface-name'
** (steam:98247): WARNING **: 15:43:49.724: Unknown setting 'proxy'
** (steam:98247): WARNING **: 15:43:49.724: Ignoring invalid property 'route-data'
** (steam:98247): WARNING **: 15:43:49.724: Ignoring invalid property 'address-data'
** (steam:98247): WARNING **: 15:43:49.724: Unknown setting 'tun'
** (steam:98247): WARNING **: 15:43:49.724: Ignoring invalid property 'dns-priority'
** (steam:98247): WARNING **: 15:43:49.724: replace_settings: error updating connection /org/freedesktop/NetworkManager/Settings/13 settings: (3) type
(steam:98247): Gtk-WARNING **: 15:43:49.760: gtk_disable_setlocale() must be called before gtk_init()
roaming config store loaded successfully - 2575 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 15ms
[1214/154351.169469:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1214/154351.227308:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1214/154351.301711:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/sir-alien-the-great/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 3.78 seconds
[1214/154351.642856:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1214/154351.658112:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
BuildCompleteAppOverviewChange: 101
RegisterForAppOverview 1: 3ms
RegisterForAppOverview 2: 3ms
[587620]Non-Steam Controller Configs Enabled: 1
Opted-in Controller Mask for AppId 587620: f
GameAction [AppID 587620, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
File "/home/sir-alien-the-great/.local/share/Steam/compatibilitytools.d/Proton-5.9-GE-8-ST/proton", line 716, in <module>
g_session.init_session()
File "/home/sir-alien-the-great/.local/share/Steam/compatibilitytools.d/Proton-5.9-GE-8-ST/proton", line 550, in init_session
g_compatdata.setup_prefix()
File "/home/sir-alien-the-great/.local/share/Steam/compatibilitytools.d/Proton-5.9-GE-8-ST/proton", line 347, in setup_prefix
try_copy(g_proton.lib_dir + "wine/dxvk/openvr_api_dxvk.dll", self.prefix_dir + "/drive_c/windows/syswow64/")
File "/home/sir-alien-the-great/.local/share/Steam/compatibilitytools.d/Proton-5.9-GE-8-ST/proton", line 59, in try_copy
shutil.copy(src, dst)
File "/usr/lib/python3.8/shutil.py", line 415, in copy
copyfile(src, dst, follow_symlinks=follow_symlinks)
File "/usr/lib/python3.8/shutil.py", line 261, in copyfile
with open(src, 'rb') as fsrc, open(dst, 'wb') as fdst:
IsADirectoryError: [Errno 21] Is a directory: '/home/sir-alien-the-great/.local/share/Steam/steamapps/compatdata/587620/pfx//drive_c/windows/syswow64/'
src/clientdll/installscript_posix.cpp (357) : Assertion Failed: strCommonRedistForeignInstallPath != ""
assert_20201214154400_26.dmp[98574]: Uploading dump (out-of-process)
/tmp/dumps/assert_20201214154400_26.dmp
src/clientdll/installscript_posix.cpp (419) : Assertion Failed: Standalone evaluator returned error code for app 587620
GameAction [AppID 587620, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 587620, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 587620, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 587620, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 587620, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Game update: AppID 587620 "", ProcID 98577, IP 0.0.0.0:0
ERROR: ld.so: object '/home/sir-alien-the-great/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Starting app 587620
>>> Adding process 98577 for game ID 587620
GameAction [AppID 587620, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 587620, ActionID 1] : LaunchApp changed task to Completed with ""
ProtonFixes[98578] INFO: Running protonfixes
ProtonFixes[98578] INFO: Running checks
ProtonFixes[98578] INFO: All checks successful
ProtonFixes[98578] INFO: Using global defaults for "Okami HD" (587620)
ProtonFixes[98578] INFO: No protonfix found for "Okami HD" (587620)
>>> Adding process 98578 for game ID 587620
assert_20201214154400_26.dmp[98574]: Finished uploading minidump (out-of-process): success = yes
assert_20201214154400_26.dmp[98574]: response: CrashID=bp-f33a5394-c75e-43ce-adc8-bfb1f2201214
assert_20201214154400_26.dmp[98574]: file ''/tmp/dumps/assert_20201214154400_26.dmp'', upload yes: ''CrashID=bp-f33a5394-c75e-43ce-adc8-bfb1f2201214''
Game removed: AppID 587620 "", ProcID 98577
Uploaded AppInterfaceStats to Steam
Exiting app 587620
No cached sticky mapping in ActivateActionSet.Installing breakpad exception handler for appid(steam)/version(1607372145)
I have tried proton 5.9-GE-8-ST, 5.21-GE-1, 5.13-4. and 5.0-10 and none of them work.
My system information is:
~ >>> inxi -Fazy [1]
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=d7a4733f-f10c-4101-a145-90395a346094 rw quiet apparmor=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: Z390 Phantom Gaming SLI/ac
serial: <filter> UEFI [Legacy]: American Megatrends v: P4.30
date: 12/02/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: 6-Core model: Intel Core i5-9600K bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: D (13) microcode: DE
L2 cache: 9216 KiB
bogomips: 44412
Speed: 1331 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 2264 2: 2212
3: 2087 4: 2125 5: 2248 6: 2272
Type: srbds mitigation: TSX disabled
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:7340
Display: wayland server: X.org 1.20.10 compositor: gnome-shell
driver: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: 0 resolution: <xdpyinfo missing>
OpenGL:
renderer: Radeon RX 5500 XT (NAVI14 DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 03:00.1 chip ID: 1002:ab38
Device-3: Logitech QuickCam Zoom type: USB
driver: Philips webcam,snd-usb-audio bus ID: 1-4:4 chip ID: 046d:08b4
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 4000 bus ID: 04:00.0 chip ID: 8086:24fb
IF: wlp4s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
port: 3000 bus ID: 05:00.0 chip ID: 10ec:8125
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 4.55 TiB used: 1.85 TiB (40.7%)
ID-1: /dev/sda vendor: Western Digital model: WDS100T2B0B-00YS70
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 00WD scheme: GPT
ID-2: /dev/sdb type: USB vendor: Seagate model: BUP BK size: 3.64 TiB
block size: physical: 4096 B logical: 512 B serial: <filter> rev: 0304
scheme: GPT
ID-1: / raw size: 647.61 GiB size: 636.44 GiB (98.28%)
used: 273.15 GiB (42.9%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
mem: 0.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1383
Processes: 293 Uptime: 2d 16h 40m Memory: 31.29 GiB used: 6.09 GiB (19.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1535
apt: 0 pacman: 1523 lib: 437 flatpak: 6 snap: 6 Shell: Zsh v: 5.8
running in: cool-retro-term inxi: 3.1.08
How can I fix this? Is there any way to check for corrupted proton data? I’ve validated the Okami data in steam and it can’t find anything.
Sorry if I’m doing anything wrong here.
