PolGZ
3 April 2022 15:53
1
Hi,
Yesterday I was running low on battery so I decided to change the refresh rate from 120hz to 60hz (using the kde system settings) (I’ve done that many times without any issue). It went to a black screen and now I when I log in graphically it only shows a black screen
I read this post about refresh rate, black screen with nvidia drivers , but I wasn’t using nvidia graphics.
My laptop is an asus flow x13. It is running only amd graphics. I tried changing to nvidia graphics with optimus-manager but it also shows the black screen.
I am running KDE
I don’t have any other DE installed. Also, I can’t connect to my wifi from tty with iw
because it is WPA2 to update anything (this laptop doesn’t have ethernet…). I know I din’t do the last stable branch update, and I was hoping updating would solve something.
I read the /var/log/Xorg.0.log
but I don’t read anything that I would understand as a cause (but my knowledge is very reduced).
What can I do?
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi
in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
PolGZ
3 April 2022 16:13
3
Here is the output:
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=0eb5b762-52aa-428b-829d-e29fae0cdae4 rw quiet
cryptdevice=UUID=a8804b83-f3d4-47c1-ab1a-a7882ae0bb65:luks-a8804b83-f3d4-47c1-ab1a-a7882ae0bb65
root=/dev/mapper/luks-a8804b83-f3d4-47c1-ab1a-a7882ae0bb65
udev.log_priority=3 acpi_backlight=vendor
Console: tty 3 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Flow X13 GV301QH_GV301QH v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GV301QH v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GV301QH.407 date: 05/31/2021
ID-1: BAT0 charge: 36.4 Wh (60.1%) condition: 60.6/62.0 Wh (97.8%)
volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging
Device-1: hid-0018:04F3:2C82.0005-battery model: ELAN9008:00 04F3:2C82
serial: N/A charge: N/A status: N/A
RAM: total: 15.1 GiB used: 1.09 GiB (7.2%)
RAM Report:
Info: model: AMD Ryzen 7 5800HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1444 high: 2161 min/max: 1200/3200 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2161 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1396 8: 1397 9: 1397 10: 1397 11: 1396
12: 1397 13: 1397 14: 1396 15: 1397 16: 1397 bogomips: 102243
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0302
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638
class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
Display: server: X.org v: 1.21.1.3 driver: X: loaded: modesetting
gpu: amdgpu tty: 240x75
Monitor-1: eDP-1 model: Sharp LQ134N1JW52 built: 2020 res: 1920x1200
dpi: 169 gamma: 1.2 size: 288x180mm (11.34x7.09") diag: 340mm (13.4")
ratio: 16:10 modes: max: 1920x1200 min: 640x480
Message: GL data unavailable in console. Try -G --display
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Device-1: luks-a8804b83-f3d4-47c1-ab1a-a7882ae0bb65 maj-min: 254:0
type: LUKS dm: dm-0 size: 338.87 GiB
Components:
p-1: nvme0n1p6 maj-min: 259:6 size: 338.87 GiB
Local Storage: total: 506.66 GiB used: 101.85 GiB (20.1%)
model: PC SN530 SDBPTPZ-512G-1002 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Generic
model: MassStorageClass size: 29.72 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1536 scheme: MBR
ID-1: / raw-size: 338.87 GiB size: 332.48 GiB (98.12%)
used: 86.52 GiB (26.0%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a8804b83-f3d4-47c1-ab1a-a7882ae0bb65 label: N/A
uuid: 0eb5b762-52aa-428b-829d-e29fae0cdae4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 42.1 MiB (16.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: F06E-B916
ID-3: /mnt raw-size: 29.72 GiB size: 29.71 GiB (99.98%)
used: 15.28 GiB (51.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2FC0-131A
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 117.67 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 650 MiB fs: ntfs label: RECOVERY
uuid: 0A341CBA341CAB29
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 19.5 GiB fs: ntfs label: RESTORE
uuid: B096E2C196E28766
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:19b6 class-ID: 0301
Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: Genesys Logic SD Card Reader and Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 896mA chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c6e class-ID: 0000
Device-2: 3-4:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3100
GPU: device: nvidia screen: :0.0 temp: 51 C device: amdgpu temp: 51.0 C
Processes: 335 Uptime: 27m wakeups: 4 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1456 pacman: 1424 lib: 380
flatpak: 32 Shell: Bash (login) v: 5.1.16 running-in: tty 3 inxi: 3.3.14
PolGZ
3 April 2022 16:19
4
Reading this part
PolGZ:
class-ID: 0300
especially the line with DP-1,DP-2,HDMI-A-1 bus-ID
made me think that right know, I could connect it to an external HDMI display. So I went to the tv on the living room, connected it, opened system settings and change the laptop display to 120fps, and voilà!
But now I don’t understand why changing it to 60fps makes it go black. This didn’t use to happen!
What should I try to check what error is happening?
EDIT: I tried again selecting 60fps and it goes black indeed. Only, this time I didn’t panic and shut down and it reverted to 120fps. Where is this change supposed to be written on the system?
~/.local/share/kscreen/
either the file there,
or the one in the directory /.local/share/kscreen/outputs
Both have the refresh rate in them.
I was going to recommend to delete this directory or just the two files
but you had found another way in the meantime.
PolGZ
3 April 2022 17:12
6
Thanks.
I understand those are where KDE saves the values. And, for what you say, that deleting them would make it default to 120hz.
Now we would need to understand why selecting 60 hz doesn’t work.
From those files, I see the 60hz option is:
"refresh": 60,
whereas in the 120hz option it says
"120.003173828125.
Could it be the lack of “decimals”?
I followed this Arch Wiki article and added a new mode:
Get the modeline for the resolution: cvt 1920 1200 60
created a new mode: xrandr --newmode "1920x1200_60.00" 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync
listed my monitors, it was eDP-1
added it xrandr --addmode eDP-1 1920x1200_60.00
selected it xrandr --output eDP-1 --mode 1920x1200_60.00
, and bum! black screen again.
So it doesn’t seem that KDE is doing anything wrong… don’t you think?
I don’t think so
but I actually do not know.
… I just looked for and found the place where the refresh rate was mentioned and specified …
PolGZ
3 April 2022 17:18
8
(I was updating the reply, sorry. Check my new try)
