I am trying to set up my usb wifi dongle, which is listed as
Bus 001 Device 008: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
So I figured the right driver for me is
rtl8821cu-dkms-git
however I get errors when installing:
(2/3) Install DKMS modules
==> ERROR: Missing run kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing lost+found kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing lib64 kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing bin kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing lib kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing var kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing home kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing proc kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing opt kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing etc kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing mnt kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing root kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing sys kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing sbin kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing tmp kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing usr kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing srv kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing dev kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module rtl8821cu/5.4.1141ef3ff12.
==> ERROR: Missing boot kernel headers for module rtl8821cu/5.4.1141ef3ff12.
(3/3) Refreshing PackageKit...
my system info:
inxi -F ✔
Host: shmuel-manjaro Kernel: 5.16.7-1-MANJARO x86_64
bits: 64 Desktop: KDE Plasma 5.23.5 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A
v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 1203 date: 10/10/2019
Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP
cache: L2: 2 MiB
Speed (MHz): avg: 800 min/max: 800/4700 cores: 1: 800
2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
driver: i915 v: kernel
Device-2: Microdia USB Live camera type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org 1.21.1.3 driver:
loaded: modesetting resolution: 1: 1920x1080~120Hz
2: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 21.3.5
Device-1: Intel 200 Series PCH HD Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.16.7-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.45 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit
Ethernet
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full
mac: a8:5e:45:e2:87:3c
Device-2: Realtek 802.11ac NIC type: USB driver: N/A
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode)
type: USB driver: btusb
Report: rfkill ID: hci0 state: up
address: see --recommends
Local Storage: total: 2.26 TiB used: 702.3 GiB (30.4%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G
ID-2: /dev/sdb vendor: Toshiba model: HDWD120
ID-1: / size: 66.76 GiB used: 25.54 GiB (38.3%) fs: ext4
dev: /dev/sda8
ID-2: /boot/efi size: 96 MiB used: 36.9 MiB (38.5%)
fs: vfat dev: /dev/sda2
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 274 Uptime: 1h 49m Memory: 15.49 GiB
used: 8.93 GiB (57.6%) Shell: Zsh inxi: 3.3.12
So now after a careful look at the errors, it seems like this driver wants to find a 5.4 kernel, but I have a later one.
Is that the problem, and if so, do I need to downgrade my kernel in order to use the driver?
