Odroid N2 + Manjaro ARM 19.10
Hi,
Manjaro arm 19.10 bug report. I created for the third time an image for the n2
$ sudo buildarmoem -d on2 -e kde-plasma -v 19.10 -n
What device are you using?
odroid n2
What edition of Manjaro-ARM is installed? (eg minimal, server, etc.)
19.10 kde-plasma
When did you last run updates and reboot?
today 2019.10.21, see below
[nln2@n2 ~]$ su
Mot de passe :
[root@n2 nln2]# pacman -Syuu
:: Synchronisation des bases de données de paquets…
core est à jour 0,0 B 0,00B/s 00:00 [-------------------] 0%
extra est à jour 0,0 B 0,00B/s 00:00 [-------------------] 0%
community est à jour 0,0 B 0,00B/s 00:00 [-------------------] 0%
:: Début de la mise à jour complète du système…
il n’y a rien à faire // the system is up to date !
What package contains the bug?
Describe the bug the best you can. What where you doing when the bug happened?
I follow the setup, reboot and nothing happen, black screen (I did it 3 time with 3 different image, Saturday 19, Sunday 20 and Monday 21)
Any workarounds or known fixes?
I can ssh the n2, see below
[nicolas@nls-pc ~]$ ssh nln2@192.168.1.50
nln2@192.168.1.50's password:
Welcome to Manjaro-ARM
~~Website: https://manjaro.org
~~Forum: https://forum.manjaro.org/c/manjaro-arm
~~IRC: #manjaro-arm on irc.freenode.net
~~Matrix: #manjaro-arm-public:matrix.org
[nln2@n2 ~]$ uname -a
Linux n2.19.10 4.9.177-2-MANJARO-ARM #1 SMP PREEMPT Sun Jun 2 21:24:06 UTC 2019 aarch64 GNU/Linux
[nln2@n2 ~]$ inxi -b
Host: n2.19.10 Kernel: 4.9.177-2-MANJARO-ARM aarch64 bits: 64
Console: tty 0 Distro: Manjaro ARM
Type: ARM Device System: Hardkernel ODROID-N2 rev: 0400
serial: ...
6-Core (2-Die): Model N/A type: MCP MCM speed: 1896 MHz
min/max: 100/1896:1800 MHz
Device-1: amhdmitx driver: amhdmitx v: N/A
Device-2: meson-g12b driver: meson_fb v: N/A
Display: server: X.org 1.20.5 driver: meson_fb tty: 77x26
Device-1: g12a-eth-dwmac driver: meson6_dwmac
Local Storage: total: 58.24 GiB used: 4.60 GiB (7.9%)
Processes: 141 Uptime: 13m Memory: 3.62 GiB used: 190.2 MiB (5.1%)
Init: systemd Shell: bash inxi: 3.0.36
The n2 is working well with the 19.08 kde installed, flash and install on an other emmc module
(except corekeyboard, see my post with the corekeyboard bug report)
have a good day.
We have made no change to the Odroid N2 setup between 19.08 and 19.10 release.
Did you try updating the 19.08 install and reboot?
Thank's for your answer.
The n2 is working well with the actual 19.08 up to date.
Ok, I'll flash and install a new 19.08 to test it on an other emmc module.
If that works, then it's recommended to just use that, since we didn't do 19.10 images for the Odroid N2.
ok, the 19.08 n2 image boot without problem after install.
Your last n2 image is the 19.08
Your last c2 image is the 19.06
my c2 is running with a 19.06 image, I created a 19.10 c2 image not tested
I don't have the 19.08 c2 image...
Someone tested the 19.08 c2 image ?
There is no 19.08 C2 image.
People would have to build a new image (which would be 19.10 based now) themselves with the Manjaro ARM Tools or make an install with the Manjaro ARM Installer.
As I note in my release posts, we can't make images for all supported devices.
Hi,
There's no problem, I understand, You can't create image for all device, but we can create the image we need, it's the goal of Contributing to Manjaro-ARM
Now my question is :
Someone tested the 19.10 n2 image created with the Manjaro ARM Tools or make an install with the Manjaro ARM Installer ?
I haven't heard of any that as tested it. I don't have an Odroid N2 myself, but one of our other devs do.
But since we haven't really changed anything I can't imagine something breaking.
ok, wait and see for a test doing by the manjaro dev team
If I create an image for the c2 with this command :
[nicolas@nls-pc ~]$ sudo buildarmoem -d oc2 -e kde-plasma -v 19.08 -n
It will create an 19.08 c2 image or an image with the last manjaro improvement? I mean the 19.10
It will create an image from the current packages in the repo. The image will just be named 19.08, but will contain the newest packages. :slight_smile:
ok, have a good day.
I stay tuned for a 19.10 n2 image feedback from the manjaro dev team.
Hi,
I tried to build a new image today 26/10, the issue is the same, I follow the setup, reboot and nothing happen, black screen
I created an image for the n2
$ sudo buildarmoem -d on2 -e kde-plasma -v 19.10_26-1 -n
I can ssh the n2...
Now I try with xfce
XFCE 19.10 run with the n2
Does HW acc work on N2 with their custom kernel?
How to check it ?
with the command inxi ?
if yes, which inxi command ?
Try opening any browser like Chromium or Firefox
For chromium type this in address bar.
chrome://gpu
For Firefox
about:support
We tried building an internal Odroid N2 kde-plasma image for testing. And it booted for our dev without issue, with HDMI screen etc.
So we can't reproduce your issue. Sorry.
Thanks for your test
Strange, it's works with xfce and not with kde...
I tested the 2 image on the same emmc module and then on 2 different emmc module.
Spykerguy, is it what you need?
n2 19.10 xfce about:support
GPU #1
Active	Yes
Description	llvmpipe (LLVM 9.0, 128 bits)
Vendor ID	0xffff
Device ID	0xffff
Driver Vendor	mesa/llvmpipe
Driver Version	19.2.2.0
RAM	3710MB
n2 19.10 kde about:support
GPU #1
Active	Yes
Vendor ID	0xffff
Device ID	0xffff
RAM	3710MB
[root@n2 nln2]# systemctl list-units | grep -i manager
init.scope        loaded active running   System and Service Manager
NetworkManager.service        loaded active running   Network Manager
sddm.service        loaded active running   Simple Desktop Display Manager
systemd-udevd.service        loaded active running   udev Kernel Device Manager
user@1000.service        loaded active running   User Manager for UID 1000
[root@n2 nln2]# startx
xauth:  file /root/.Xauthority does not exist
X.Org X Server 1.20.5
Build Operating System: Linux Arch Linux
Current Operating System: Linux n2.19.10 4.9.177-2-MANJARO-ARM #1 SMP PREEMPT Sun Jun 2 21:24:06 UTC 2019 aarch64
Kernel command line: root=/dev/mmcblk0p2 rootwait rw console=ttyS0,115200n8  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100  monitor_onoff=false logo=osd0,loaded hdmitx=cec3f
Build Date: 26 October 2019  06:18:57AM
Current version of pixman: 0.38.4
        Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Oct 26 20:25:49 2019
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/4.9.177-2-MANJARO-ARM
Failed to connect to bus: Opération non permise
dbus-update-activation-environment: error: unable to connect to D-Bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
/etc/X11/xinit/xinitrc: ligne 53: xterm : commande introuvable
/etc/X11/xinit/xinitrc: ligne 55 : exec: xterm : non trouvé
/etc/X11/xinit/xinitrc: ligne 52: xclock : commande introuvable
/etc/X11/xinit/xinitrc: ligne 54: xterm : commande introuvable
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Hi,
I build a new n2 19.10 image, it is working now :slight_smile:
I keep this image !
I note a difference with the fbturbo tty
  Host: n2.19.10 Kernel: 4.9.177-2-MANJARO-ARM aarch64 bits: 64 Console: tty 0
  Distro: Manjaro ARM
  serial: 61a9b756-c5c4-4e29-8a78-001e064204e1
  Display: server: X.org 1.20.5 driver: fbturbo tty: 87x30
  Local Storage: total: 58.24 GiB used: 5.44 GiB (9.3%)
  Processes: 178 Uptime: 41m Memory: 3.62 GiB used: 712.9 MiB (19.2%) Init: systemd
[nln2@n2 ~]$ screenfetch
                             nln2@n2.19.10
                             OS: Manjaro-ARM 19.10
                             Kernel: aarch64 Linux 4.9.177-2-MANJARO-ARM
         #####               Uptime: 59m
        #######              Packages: Unknown
        ##O#O##              Shell: bash 5.0.11
        #######              Resolution: 1920x1080
      ###########            DE: KDE 5.64.0 / Plasma 5.17.2
     #############           WM: KWin
    ###############          GTK Theme: Matcha-light-sea [GTK2/3]
    ################         Icon Theme: breeze
   #################         Disk: 5,5G / 59G (10%)
 #####################       CPU: Hardkernel ODROID-N2 @ 6x 1.896GHz
 #####################       RAM: 845MiB / 3710MiB
