I’d like to have full control over when my computer says it can accept the myriad protocols currently being multicasted on the network.
- After a tcpdump, I’m trying to work out where the multicasts for things like AirPlay, airport, REDlink, printers, scanners etc were coming from.
- Couldn’t see that avahi was running. Eg.
ps -ef | grep avahi
??? Nope. Nothing. - Renamed gvfsd-dnssd and gvfsd-network in /usr/lib/ folder, and killed the processes
pkill -9 {gvfsd-dnssd,gvfsd-network}
, and restarted the NetworkManager. - Concluded the multicasts did not come from those processes.
- Opened the “nm-connection-editor” (Advanced Network Configuration in the Whisker menu) and crudely just disabled IPv6 completely, hit Save and closed the window, restarted the NetworkManager with
sudo systemctl restart NetworkManager
but alas the IPv6 multicasts are still being sent out.
What is the proper way, to ideally “disable” the multicasts without completely uninstalling avahi?
