Octopi: search on description don't work
Hi all,
I’m trying to use octopi but I’m not able to search for packages using words in descriptions.
As an example searching for a prometheus exporter for SNMP:
Searching prometheus find it (among a lot of other packages) and the description contains the 2 words: prometheus and SNMP
The search is set on description
Now searching for “prometheus SNMP” it finds nothing
How can I search for packages whose names I don’t know?
I can reproduce it. It would be better to create an upstream issue so the developer can look into it.
maybe because in Arch is
anyway if you type one name or the other you will find
is like if you search for manjaro-settings-manager
I don’t know if it is a bug. Maybe intended?
It only accepts one keyword.
Does prometheus-snmp qualify as one word?
:point_right: “-”
Yes, it does.
