well I will check the other laptop but the new one with fresh install the octopi options main windows is looking like you are saying, without option for checking the AUR
the options in the notifier tray icon is not the same, has an option for the updates
Yes, as I told I was remembering wrong, but at that time KDE was without package manager and they was planning to adopt octopi..
Mod Edit:Merged consecutive posts. Please use the edit feature to add extra!
I installed octopi from the repo - I remember having checked it out before - but it never passed the evaluation.
This time is no differentâŚ
You demonstrate a functionality - it is obvious it exist on your system - but it does not on mine (manjaro unstable branch - octopi about says 0.19-dev).
Now this is beyond logic.
I discovered
if you open octopi
then open octopi-notifier
the option page launched by right-clicking the notifier icon is the octopi options page.
if you close both
the open octopi-notifier
the option page is octopi-notifier options - and the functionality becomes clear.
if there is any logic - it must be that the octopi-notifier is expected to be running - before you launch octopi
this is confusing at best, impossible to understand at worst.
I believe thatâs its intended purpose, though; i.e. the notifier is expected to be there.
I may well be wrong, however. ⌠but I donât see the point of having the likes of Pamac installed without also having a notifier, if one desires a GUI-centric usage scenario.
Note (as with some others here) I only use the notifier(s) as such; I always recommend using the CLI for the actual software upgrades or installations. TTY is best, of course, particularly for major updates;)
you are right, same here
one more thing, after fresh install I run octopi notifier but at reboot is not in autostart while before once you run it once it will be keep running in the tray after reboot
now Iâve to add it to autostart manually
I wiil update only the browsers or minor updates via notifier, of course big updates always TTY
Itâs in the settings for the octopi-notifier icon in the system tray, not in octopi itself.
Right-click the octopi-notifier icon in the system tray and choose âOptionsâ. Then, in the dialog window, click on âUpdatesâ. Youâll see a checkbox for the AUR at the bottom.
When this setting is active and there are AUR updates, the icon will turn yellow. When there are repo updates, itâll turn red. When there are no updates, itâll stay green.
