manjaro updates your mesa amd gpu driver to 20.1.8 which was released back in september
there is already 20.2.2 with bunch of bug fixes
mesa and amdgpu are not the same thing.
But if you look on Manjaro - Branch Compare
It seems you have failed to update your system.
Stable and Testing branches are on 20.2.1-1
, while Unstable is on 20.2.2-2
is package manager broken for me? it does not seems to see new driver from mesa team. is there a way to fix this?
screenfetch saying is that my version of manjaro is 20.2 nibia
Have you sorted your mirrors?
sudo pacman-mirrors -f && pamac upgrade --force-refresh
