octopi can't upgrade system
When I try upgrade my system I get a conflict whit the package mesa-git, its an older build. new mesa-git wont build because it need new llvm which is in the update I can't install..
when I try to remove mesa-git it "would like to remove 999 dependence".
I can't build mesa-git and I can't remove it
I can't upgrade my system to be able to build mesa-git
I can't install normal arch mesa package
Can you please post the errors you get when installing llvm?
when upgrading only llvm with octopi
sudo /usr/lib/octopi/octphelper -ts
resolving dependencies...
:: installing lib32-llvm-libs (9.0.1-1) breaks dependency 'lib32-llvm-libs=9.0.0' required by lib32-mesa-git
:: installing llvm-libs (9.0.1-1) breaks dependency 'llvm-libs=9.0.0' required by mesa-git
Press any key to continue...
Have you tried running the update in normal pacman?
sudo pacman -Syu
If that doesn't work, try
sudo pacman -Syu mesa lib32-mesa
If it asks you to remove mesa-git, select yes.
that work thank you :smiley:
Marking @ben81's post as the solution to the OP's update issue.
there is a little aftermath question here
in aur I have xf86-input-mouse and xf86-input-keyboard leftovers from mesa-git
should I keep them? why are they in aur?
A search in the forum for xf86-input-mouse :
50+ results for xf86-input-mouse
Looks as if those packages have been dropped from Manjaro's repo. So I guess if nothing else is dependent on them, they could be removed.
