OBS Virtual Camera not working on Manjaro KDE
Hi everyone,
I’m experiencing issues with the OBS Virtual Camera on Manjaro KDE (Wayland session). The virtual camera fails to start, and OBS logs show the following error:
Failed to start streaming on '/dev/video2' (Invalid argument)
Failed to start virtual camera.
In the graphical interface in OBS displays this error:
Output failed. Please check the log for details.
Note: If you are using NVENC or AMD encoders, make sure you have the latest video drivers installed.
I’ve tried so far:
  1. Reinstalled and loaded v4l2loopback with parameters like exclusive_caps=0.
  2. Checked that /dev/video2 exists and is accessible.
  3. Changed kernels.
  4. Reinstalled obs, including flatpak
  5. Changed users
Additional details:
  • I noticed the problem after the latest system update, but it might have occurred earlier as I hadn’t used the virtual camera for a couple of weeks.
  • My system uses an integrated AMD GPU.
  • The issue persists across kernels (6.6 and 6.12).
inxi info
Any ideas on how to fix this? Let me know if you need more logs or system details.
Ok, I managed to fix the issue.
It seems the problem lies in the new version of v4l2loopback-dkms .
Downgrading to version 0.13.2 resolves the issue.
This is, of course, a temporary workaround, so let’s hope for updates soon!
The source
