On Manjaro KDE I installed OBS Studio (some times ago), and it was working as expected.
Today after some time of not using it, I run it again, and it started, but I get no window.
It shows in my System monitor.
And it shows in my system tray that it’s using my microphone.
Other than that, I don’t see OBS studio main window, nor is there OBS icon in task manager.
Anyone got any idea, what should I do?
There is a fresh obs-studio build from Jan. 05th in testing branch, so update your system if you are running on testing branch (or unstable) by
sudo pacman-mirrors -f && sudo pacman -Syyu
Otherwise, wait until it reaches stable branch - or switch to testing branch.
Thank you for the help.
Yes, I’m on stable branch now, so I’ll wait untill it’ll be released on stable.
Meanwhile, I installed flatpak version, and it runs fine, as long as I use software encoding, NVENC somehow don’t work (I got RTX2060).
