Well how to say I don’t want to sound greedy or anything just I need best performance for recording heavier demanding games.
I can record Screen Capture with (Xcomposite) on OBS but with all kinds of settings the quality is just not good.
Screen Capture with (Pipewire) does not even see any windows to select just blank.
So I wanted to use obs-vkcapture since people say its easier for the system to record with minimal loses of quality especially when recording heavy performance demanding games.
So yeah anyway from the inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 6.1.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=15f65287-75bf-4c55-9878-320da4bd56e1 rw quiet pci=nommconf
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop System: LENOVO product: 90RT00GAMW v: Legion T5 26IOB6
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: LENOVO model: 3733 v: SDK0T76461 WIN 3422082981805
serial: <superuser required> UEFI: LENOVO v: O54KT1CA date: 11/16/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
status: discharging
System RAM: total: 16 GiB note: est. available: 15.35 GiB
used: 3.62 GiB (23.6%)
Info: model: 11th Gen Intel Core i7-11700F bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x59
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 812 high: 900 min/max: 800/4800:4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 900 6: 900 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 bogomips: 79888
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: Lenovo
driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2488 class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: DP-0 res: 1920x1080 hz: 120 dpi: 82
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.129.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 535.129.03
device-ID: 10de:2488 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Corsair VOID ELITE Wireless Gaming Dongle
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 1b1c:0a51 class-ID: 0300
API: ALSA v: k6.1.62-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 2.29 TiB used: 348.21 GiB (14.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000L7
lanes: 4 tech: SSD serial: <filter> fw-rev: 5M2QEXF7 temp: 33.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 49.34 GiB (10.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 15f65287-75bf-4c55-9878-320da4bd56e1
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 31B5-1EE2
ID-3: /run/media/roy/LocalDisk raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 298.87 GiB (16.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: LocalDisk uuid: 44fd6518-ca0d-4eaa-ba8f-ae62983afb21
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-1.1:4 info: Logitech Cordless Mouse Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c537 class-ID: 0300
Device-2: 1-6:3 info: HP HyperX Alloy Elite 2 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 03f0:058f class-ID: 0300
Device-3: 1-8:5 info: Corsair VOID ELITE Wireless Gaming Dongle
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-4: 1-14:6 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 31 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 35%
Processes: 330 Uptime: 8m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1393
pm: pacman pkgs: 1354 libs: 455 tools: pamac pm: flatpak pkgs: 39 Shell: Zsh
v: 5.9 default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
And software encoder also does not seem to work with obs-vkcapture.
I tried to record with different resolutions and so on but same problem.
Just to let people know I tried setting launch parameters in the game as obs-gamecapture #command# and obs_vkcapture=1 #command#. And all get is black screen with sounds.
