OBS stopped recognizing Input audio devices after Sep 16 Stable Update
Hi,
just installed the Sep 16 update and now OBS doesn’t see any audio input devices anymore. Everything worked great before the update.
Now, the list of input devices (in the dropdown) is just empty and say “Device not connected or available”. Input devices are listed in Volume control and seem to work. Also, Skype sees the input devices. Audio playback (e.g. in VLC) work, so it’s likely different from the other report
Kernel 5.10.63-1 with XFCE 4.16
Audio is pipewire 0.3.35
OBS 27.0.1-2
Did a full reboot.
Any ideas for approaching this, since OBS didn’t receive an update during this update cycle.
  Kernel: 5.10.63-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64 root=/dev/mapper/cryptVG-root rw
  acpi=force irqpoll pci=nomsi
  cryptdevice=/dev/disk/by-uuid/562dd93b-6f0c-4501-8597-63d86186f4fe:cryptVG:allow-discards
  root=/dev/disk/by-uuid/b45a13f2-16da-44d4-90d9-4670f408813e rw quiet splash
  rcutree.rcu_idle_gp_delay=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Portable System: Dell product: Dell System XPS L502X v: N/A
  serial: <filter> Chassis: type: 8 v: 0.1 serial: <filter>
  Mobo: Dell model: 0NJT03 v: A00 serial: <filter> UEFI-[Legacy]: Dell v: A12
  date: 09/07/2012
  ID-1: BAT0 charge: 43.8 Wh (100.0%) condition: 43.8/48.8 Wh (89.7%)
  volts: 12.3 min: 11.1 model: SDI Dell type: Li-ion serial: <filter>
  status: Full
  Device-1: hidpp_battery_0 model: Logitech M705 serial: <filter> charge: 65%
  rechargeable: yes status: Discharging
  RAM: total: 15.53 GiB used: 3.48 GiB (22.4%)
  RAM Report:
  missing: Required tool dmidecode not installed. Check --recommends
  Info: Dual Core model: Intel Core i7-2620M bits: 64 type: MT MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 4 MiB bogomips: 21561
  Speed: 2723 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 2723 2: 2648
  3: 2295 4: 2762
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
  mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep smx ssbd sse sse2
  sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
  vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0126
  class-ID: 0300
  Device-2: NVIDIA GF108M [GeForce GT 540M] driver: N/A
  alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:0df4
  class-ID: 0300
  Device-3: Quanta Laptop_Integrated_Webcam_2HDM type: USB driver: uvcvideo
  bus-ID: 1-1.4:3 chip-ID: 0408:2fb1 class-ID: 0e02
  Device-4: Logitech HD Pro Webcam C920 type: USB
  driver: snd-usb-audio,uvcvideo bus-ID: 2-1.2.2:6 chip-ID: 046d:082d
  class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x286mm (34.2x11.3")
  s-diag: 915mm (36")
  Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
  diag: 598mm (23.5")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
  v: 3.3 Mesa 21.2.1 compat-v: 3.0 direct render: Yes
  vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
  Device-3: Blue Microphones Yeti Stereo Microphone type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-1.2.1:5
  chip-ID: b58e:9e84 class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.10.63-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.35 running: yes
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: efa0
  bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
  vendor: Dell driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 2000
  bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  bus-ID: 2-1.5:3 chip-ID: 8087:07dc class-ID: e001
  Message: Unable to run lvs. Root privileges required.
  Device-1: cryptVG maj-min: 254:0 type: LUKS dm: dm-0 size: 237.97 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 237.97 GiB
  Device-2: sdc2_crypt maj-min: 254:3 type: LUKS dm: dm-3 size: 931.51 GiB
  Components:
  p-1: sdb maj-min: 8:16 size: 931.51 GiB
  Local Storage: total: 4.78 TiB used: 1.63 TiB (34.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 256GB
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 1B6Q scheme: MBR
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10JPLX-00MBPT0
  type: HDD rpm: 7200 serial: <filter> rev: 1H01
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
  model: WD My Passport 260D size: 3.64 TiB block-size: physical: 4096 B
  logical: 512 B type: N/A serial: <filter> rev: 2003
  SMART Message: A mandatory SMART command failed. Various possible causes.
  ID-1: / raw-size: 70 GiB size: 68.78 GiB (98.25%) used: 62.71 GiB (91.2%)
  fs: ext4 block-size: 4096 B dev: /dev/dm-1 maj-min: 254:1
  mapped: cryptVG-root label: N/A uuid: N/A
  ID-2: /boot raw-size: 512 MiB size: 503.9 MiB (98.43%)
  used: 240.5 MiB (47.7%) fs: ext2 block-size: 4096 B dev: /dev/sda1
  maj-min: 8:1 label: boot uuid: a6f7bd88-1650-45e8-8b3a-f8369ccf6a52
  ID-3: /home raw-size: 167.97 GiB size: 165.21 GiB (98.36%)
  used: 123 GiB (74.5%) fs: ext4 block-size: 4096 B dev: /dev/dm-2
  maj-min: 254:2 mapped: cryptVG-home label: N/A uuid: N/A
  ID-4: /home/<filter>/Synced raw-size: N/A size: 915.89 GiB
  used: 741.46 GiB (81.0%) fs: fuse.encfs source: ERR-102
  ID-5: /media/hdd_data raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
  used: 741.46 GiB (81.0%) fs: ext4 block-size: 4096 B dev: /dev/dm-3
  maj-min: 254:3 mapped: sdc2_crypt label: N/A uuid: N/A
  Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: file size: 12 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.4:3 info: Quanta Laptop_Integrated_Webcam_2HDM type: Video
  driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 250mA
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Hub-5: 2-1.2:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 2-1.2.1:5 info: Blue Microphones Yeti Stereo Microphone
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
  rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: b58e:9e84 class-ID: 0300
  serial: <filter>
  Device-2: 2-1.2.2:6 info: Logitech HD Pro Webcam C920 type: Video,Audio
  power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Device-3: 2-1.2.3:7 info: Western Digital My Passport 260D
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
  speed: 480 Mb/s power: 500mA chip-ID: 1058:260d class-ID: 0806
  serial: <filter>
  Device-4: 2-1.2.4:8 info: Logitech Unifying Receiver
  type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
  rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-5: 2-1.5:3 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 60.0 C mobo: 50.0 C
  Processes: 316 Uptime: 28m wakeups: 7 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2794 lib: 601
  Shell: Zsh v: 5.8 running-in: terminator inxi: 3.3.06
Ok, so I rolled back the updates of these packages back to 0.3.34
pipewire-1
pipewire-jack-1
pipewire-alsa-1
pipewire-pulse-1
pipewire-media-session-1
That resolved the issue for now.
sudo pacman -U /var/cache/pacman/pkg/pipewire-1:0.3.34-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/pipewire-jack-1:0.3.34-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/pipewire-alsa-1:0.3.34-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/pipewire-pulse-1:0.3.34-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/pipewire-media-session-1:0.3.34-1-x86_64.pkg.tar.zst
Had a problem with audio. The fix is simple.
