Please, help. On my pc OBS is segfaulting even after reinstalling, but on notebook it works well. IDK why it happens. If you know where i can find more detailed logs, i would be pleased to know where are they
~ obs SEGV ✘
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Using EGL/X11
info: CPU Name: Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
info: CPU Speed: 3600.006MHz
info: Physical Cores: 4, Logical Cores: 4
info: Physical Memory: 32035MB Total, 27703MB Free
info: Kernel Version: Linux 6.1.19-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.4.2 (runtime), 6.4.2 (compiled)
info: Portable mode: false
qt.core.qmetaobject.connectslotsbyname: QMetaObject::connectSlotsByName: No matching signal for on_tbar_position_valueChanged(int)
info: OBS 29.0.2-1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
max buffering: 960 milliseconds
buffering type: dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce GTX 1050/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 525.89.02, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
base resolution: 1920x1080
output resolution: 1920x1080
downscale filter: Lanczos
fps: 24000/1001
format: NV12
YUV mode: Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] Available captures:
info: [pipewire] - Desktop capture
info: [pipewire] - Window capture
info: NVENC supported
zsh: segmentation fault (core dumped) obs
~ gdb obs ✔ 32s
GNU gdb (GDB) 12.1
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from obs...
This GDB supports auto-downloading debuginfo from the following URLs:
https://debuginfod.archlinux.org
Enable debuginfod for this session? (y or [n]) y
Debuginfod has been enabled.
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.
(No debugging symbols found in obs)
(gdb) run
Starting program: /usr/bin/obs
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
[New Thread 0x7fffe31ff6c0 (LWP 4699)]
[New Thread 0x7fffe29fe6c0 (LWP 4700)]
[New Thread 0x7fffe21fd6c0 (LWP 4701)]
[New Thread 0x7fffe19fc6c0 (LWP 4702)]
info: Using EGL/X11
info: CPU Speed: 3600.174MHz
info: Physical Memory: 32035MB Total, 24575MB Free
[New Thread 0x7fffe0b086c0 (LWP 4703)]
[New Thread 0x7fffcbfff6c0 (LWP 4704)]
[New Thread 0x7fffcb7fe6c0 (LWP 4705)]
[New Thread 0x7fffcaffd6c0 (LWP 4706)]
[New Thread 0x7fffca7fc6c0 (LWP 4707)]
[New Thread 0x7fffc9ffb6c0 (LWP 4708)]
speakers: 2
[New Thread 0x7fffc97fa6c0 (LWP 4709)]
fps: 24000/1001
format: NV12
[New Thread 0x7fffb15ff6c0 (LWP 4710)]
[New Thread 0x7fffa66456c0 (LWP 4711)]
[Detaching after fork from child process 4712]
[Detaching after fork from child process 4713]
[Detaching after fork from child process 4714]
[Detaching after fork from child process 4715]
[New Thread 0x7fffa5a296c0 (LWP 4716)]
[Detaching after fork from child process 4717]
[Detaching after fork from child process 4718]
[Detaching after fork from child process 4719]
[Detaching after fork from child process 4720]
[Detaching after fork from child process 4721]
[Detaching after fork from child process 4722]
[Detaching after fork from child process 4723]
[Detaching after vfork from child process 4724]
[Detaching after fork from child process 4726]
Thread 1 "obs" received signal SIGSEGV, Segmentation fault.
XDisplayString (dpy=0x0) at /usr/src/debug/libx11/libX11-1.8.4/src/Macros.c:119
119 char *XDisplayString(Display *dpy) { return (DisplayString(dpy)); }
