Stuck at loading screen after installing proprietary nvidia drivers
Hi, new linux user here (from windows 10). After numerous amounts of formatting from the live usb, I found out that installing prop. nvidia drivers makes my system stuck at the three dots before the login screen. I’m currently writing this on my newly formatted, no-proprietary driver manjaro.
What I’ve tried?
  • searching the forums & reddit for my problem, no solutions (that I understood)
  • Installing prop. drivers from system settings/hardware configuration. Result: stuck at loading screen & had to format
  • Installing prop. drivers using “$ sudo mhwd -a pci nonfree 0300”. Result: stuck at loading screen & had to format
  • installing prop. drivers using “$ sudo mhwd --install pci video-hybrid-intel-nvidia-prime”. Result: stuck at loading screen & had to format
Can you please help me? I really want to use & daily drive manjaro but this driver issue is driving me crazy. I need to utilize my GPU on my master’s thesis computations & try some gaming on linux.
Thank you beforehand,
Nazif
My system info:
    ~  inxi --admin --verbosity=7 --filter --width
  Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=5f1a879f-9581-4754-a977-c945b2052af6 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GD_X571GD
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X571GD v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X571GD.313 date: 05/03/2022
  ID-1: BAT1 charge: 1.8 Wh (94.7%) condition: 1.9/42.3 Wh (4.5%) volts: 12.6
    min: 11.6 model: ASUS A32-K55 type: Li-ion serial: N/A status: charging
  RAM: total: 15.48 GiB used: 4.59 GiB (29.6%)
  Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 900 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
    8: 900 bogomips: 38408
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
    driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2023-02)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:1c92 class-ID: 0302 temp: 37.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-7:5 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris,nouveau gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1315 s-dpi: 96 s-size: 1013x347mm (39.88x13.66")
    s-diag: 1071mm (42.16")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,top-left
    model: Samsung LC24RG50 serial: <filter> built: 2021 res: 1920x1080 hz: 60
    dpi: 92 gamma: 1.2 size: 532x304mm (20.94x11.97") diag: 613mm (24.1")
    ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 pos: bottom-r model: LG Display 0x0563 built: 2018
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
    chip-ID: 10ec:c821 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-14:6 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 704.24 GiB used: 219.45 GiB (31.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
    rev: 80001C00 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 10.41 GiB (2.3%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 5f1a879f-9581-4754-a977-c945b2052af6
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 8A31-6A6B
  ID-3: /run/media/nazif/1A40739E40737EF7 raw-size: 237.86 GiB
    size: 237.86 GiB (100.00%) used: 209.04 GiB (87.9%) fs: ntfs
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 1A40739E40737EF7
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 926B-005E
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
    uuid: A4C201C3C2019AA6
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-1:2 info: SiGma Micro Keyboard type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 98mA
    chip-ID: 1c4f:0026 class-ID: 0300
  Device-2: 1-5:3 info: Logitech Gaming Mouse G300 type: Mouse,Keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 200mA
    chip-ID: 046d:c246 class-ID: 0300
  Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-4: 1-7:5 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-5: 1-14:6 info: IMC Networks Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 50.0 C pch: 51.0 C mobo: N/A gpu: nouveau
    temp: 37.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 251 Uptime: 30m wakeups: 7 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1116 libs: 319 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
    ~  mhwd -l         ✔
> 0000:01:00.0 (0302:10de:1c92) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2021.11.04               false            PCI
video-hybrid-intel-nvidia-470xx-prime            2021.11.04               false            PCI
          video-nvidia            2021.11.04               false            PCI
    video-nvidia-470xx            2021.11.04               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
    ~  mhwd -li         ✔  4s 
> Installed PCI configs:
   ~  mhwd -l -d --pci         ✔
> PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0302:10de:1c92)
  Display controller nVidia Corporation GP107M [GeForce GTX 1050 Mobile]
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2018.05.04
   INFO:        Standard open source drivers.
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300 0380 0302
   VENDORIDS:   1002 8086 10de
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2021.11.04
   INFO:        Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY:    8
   FREEDRIVER:  false
   DEPENDS:     video-modesetting
   CONFLICTS:   video*nvidia*
   CLASSIDS:    0300 0302 0300
   VENDORIDS:   10de 8086
   ATTACHED:    PCI
   VERSION:     2021.11.04
   PRIORITY:    7
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2021.11.04
   INFO:        Closed source NVIDIA drivers for linux.
   PRIORITY:    5
   FREEDRIVER:  false
   DEPENDS:     -
   CLASSIDS:    0300 0302
   VENDORIDS:   10de
   ATTACHED:    PCI
   VERSION:     2021.11.04
   PRIORITY:    4
   FREEDRIVER:  false
   DEPENDS:     -
   CLASSIDS:    0300 0302
   VENDORIDS:   10de
   ATTACHED:    PCI
   VERSION:     2018.05.04
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
> PCI Device: /devices/pci0000:00/0000:00:1d.6/0000:04:00.0 (0200:10ec:8168)
  Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2016.04.20
   INFO:        RealTek RTL-8168 Gigabit Ethernet driver
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0200
   VENDORIDS:   1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:3e9b)
  Display controller Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2018.05.04
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2021.11.04
   PRIORITY:    8
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2021.11.04
   PRIORITY:    7
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2018.05.04
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   ATTACHED:    PCI
   VERSION:     2020.01.13
   INFO:        X.org modesetting video driver.
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2017.03.12
   INFO:        X.org vesa video driver.
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
try adding the ibt parameter:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
ibt=off
dont remove anything from there!, just add it to existing parameters, save the file, update grub:
sudo update-grub
enable early loading:
kate /etc/mkinitcpio.conf
and edit the modules section to look like this:
MODULES=(i915 nvidia nvidia_drm nvidia_uvm nvidia_modeset)
save it and update it:
sudo mkinitcpio -P
update your system:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
install nvidia:
reboot and test
Brahma, thank you very much. It solved my problem.
I want to learn more about the issue. If you have the time, would you mind explaining what was the problem here & how these steps helped it?
the ibt is needed if you are using nvidia+intel and kernels newer than 5.18… (but only some generetion of intel cpus is affected, se we added it, just in case);
the early loading just enables early loading of the specific modules that we added into mkinitcpio… more info here;
and since this was a fresh install and i didnt know if you are up to date to the latest, we did that too… and thats it…
