kirk
#1
Trying to update my system and getting the following conflict on nvidia-utils
sudo pacman -Syyu
core 166.6 KiB 62.8 KiB/s 00:03 [#########################################] 100%
extra 1859.8 KiB 6.14 MiB/s 00:00 [########################################] 100%
community 7.0 MiB 6.73 MiB/s 00:01 [#######################################] 100%
warning: python-pyqt5: local (5.15.6-7.1) is newer than extra (5.15.6-7)
resolving dependencies...
:: installing nvidia-utils (515.48.07-2) breaks dependency 'nvidia-utils=510.73.05' required by linux414-nvidia
Any solutions that don’t require uninstalling and installing a ton of stuff?
Strit
#2
Kernel 4.14 is currently not supported by Manjaro. So remove it first with sudo mhwd-kernel -r linux414
, then update.
kirk
#3
What
, why?
Unless I’m missing something, it seems that 4.14 is still supported LTS kernel.
Which still makes me wonder why did you stop supporting it so soom before its EOL?
Strit
#4
Because of changes to systemd
as far as I know. Systemd 251 only supports kernels 4.15 and above.
kirk
#5
That’s quite unfortunate and not really resembles the way things were done in the linux world.
Do you happen to have any links or reference to those systemd
changes?
Sound really weird that systemd
would not keep compatibility with still valid LTS kernels.
Strit
#6
Sure.
Sorry, was off by one kernel version. Edited my original answer.
kirk
#7
Quick question, I’m not familiar with manjaro internals but would I get into any issues on update after swapping systemd
with an alternative init
