Nvidia upset when upgrading today 10/30
To wit:
Replace linux71-nvidia-open with extra/linux-nvidia-open-meta? [Y/n]
resolving dependencies...
warning: removing 'nvidia-utils-615.71.09-2' from target list because it conflicts with 'nvidia-470xx-utils-470.256.02-22'
:: nvidia-470xx-utils-470.256.02-22 and nvidia-utils-610.57.04-1 are in conflict (nvidia-libgl). Remove nvidia-utils? [y/N] y
:: unable to satisfy dependency 'nvidia-utils=615.71.09' required by lib32-nvidia-utils
:: unable to satisfy dependency 'nvidia-utils=615.71.09' required by linux612-nvidia-open
:: unable to satisfy dependency 'nvidia-utils=615.71.09' required by linux618-nvidia-open
:: unable to satisfy dependency 'nvidia-utils=615.71.09' required by linux66-nvidia-open
:: unable to satisfy dependency 'nvidia-utils=615.71.09' required by linux72-nvidia-open
Does anything need to be done here..?
Mod edit: Removed unnecessary text at start of output and the “hidden” part.
You’ve been around long enough to know better, we need more information.
What branch? There was a Stable Update a couple days ago and a Testing Update today.
Please see:
Please post your system info as outlined here: [HowTo] Find system information
Also the output of the following:
mhwd --listinstalled
nvidia-driver-assistant
pacman -Qs nvidia
As requested:
👉[ljohnson@KISE-007 ~]$ mhwd --listinstalled
> Installed PCI configs:
          video-nvidia            2026.03.05               false            PCI
           video-linux            2024.05.06                true            PCI
👉[ljohnson@KISE-007 ~]$ nvidia-driver-assistant
Detected GPUs:
  NVIDIA GeForce RTX 3060 - (pci_id 0x2504)
Detected system:
  Manjaro Linux
Please copy and paste the following command to install the open kernel module flavour:
  sudo pacman -S linux71-nvidia-open
👉[ljohnson@KISE-007 ~]$ pacman -Qs nvidia
local/cuda 13.3.1-1
    NVIDIA's GPU programming toolkit
local/egl-gbm 1.1.4-1
    The GBM EGL external platform library
local/egl-wayland 4:1.1.22-1
    EGLStream-based Wayland external platform
local/egl-wayland2 1.0.2-1
    EGLStream-based Wayland external platform (2)
local/egl-x11 1.0.6-1
    NVIDIA XLib and XCB EGL Platform Library
local/lib32-nvidia-utils 610.57.04-1
    NVIDIA drivers utilities (32-bit)
local/lib32-vulkan-nouveau 1:26.2.2-1
    Open-source Vulkan driver for Nvidia GPUs - 32-bit
local/libvdpau 1.5-4
    Nvidia VDPAU library
local/libxnvctrl 610.57.04-1
    NVIDIA NV-CONTROL X extension
local/linux-firmware-nvidia 20260810-2
    Firmware files for Linux - Firmware for NVIDIA GPUs and SoCs
local/linux-nvidia-470xx-meta 7.1-1
    Recommended stable nvidia-470xx kernel module
local/linux612-nvidia-open 610.57.04-10 (linux612-extramodules)
    NVIDIA open kernel modules for linux612
local/linux618-nvidia-open 610.57.04-12 (linux618-extramodules)
    NVIDIA open kernel modules for linux618
local/linux66-nvidia-open 610.57.04-11 (linux66-extramodules)
    NVIDIA open kernel modules for linux66
local/linux71-nvidia-open 610.57.04-12 (linux71-extramodules)
    NVIDIA open kernel modules for linux71
local/mhwd-nvidia 610.57.04-1
    MHWD module-ids for nvidia 610.57.04
local/mhwd-nvidia-390xx 390.157-33
    MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.256.02-21
    MHWD module-ids for nvidia 470.256.02
local/mhwd-nvidia-580xx 580.178.04-1
    MHWD module-ids for nvidia 580.178.04
local/nsight-compute 2026.2.1.5-1
    Interactive profiler for NVIDIA CUDA and OptiX
local/nvidia-driver-assistant 0.23.48.01-7
    Detect and install the best NVIDIA driver packages for the system
local/nvidia-settings 610.57.04-1
    Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 610.57.04-1
local/opencl-nvidia 610.57.04-1
    OpenCL implemention for NVIDIA
local/vulkan-nouveau 1:26.2.2-1
local/xf86-video-nouveau 1.0.18-1 (xorg-drivers)
    Open Source 3D acceleration driver for nVidia cards
and…
👉[ljohnson@KISE-007 ~]$ sudo pacman -S linux71-nvidia-open
error: target not found: linux71-nvidia-open
This is an unfancy but powerful Manjaro Linux system, kept simple to avoid these situations. I remember the old days when an upgrade of video drivers was a major undertaking. This system is upgraded at first boot daily, unlike olden days when done at shutdown. After 30+ years of Linux and being 83+ years old, some of my marbles have rolled away - fortunately the Linux community is very supportive.
Does anything need to be done about this little kerfuffle..?
(often these issues go away at the next update)
In addition:
👉[ljohnson@KISE-007 ~]$ inxi -zv8
  Kernel: 7.1.13-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.1-x86_64
    root=UUID=ac0e8f6a-e01b-4457-b0b1-56bc2d9ff830 rw quiet splash apparmor=1
    security=apparmor resume=UUID=e93bd051-31f0-445f-b015-26abe26f9687
    udev.log_priority=3
  Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.33.1
  Type: Desktop System: Dell product: Precision 3650 Tower v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 0NDYHG v: A00 serial: <superuser required> part-nu: 0A58
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.48.0
    date: 05/27/2026
  System RAM: total: 64 GiB available: 62.52 GiB used: 16.7 GiB (26.7%)
  Array-1: capacity: 128 GiB note: est. slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: DIMM1 type: DDR4 detail: synchronous size: 32 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 04CB000002B5 part-no: N/A serial: <filter>
  Device-3: ChannelA-DIMM1 type: no module installed
  Device-4: DIMM2 type: DDR4 detail: synchronous size: 32 GiB
  Info: model: 11th Gen Intel Core i9-11900 bits: 64 type: MT MCP
    arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
    process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
    microcode: 0x66
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4011 min/max: 800/5000:5200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4011 2: 4011 3: 4011
    4: 4011 5: 4011 6: 4011 7: 4011 8: 4011 9: 4011 10: 4011 11: 4011 12: 4011
    13: 4011 14: 4011 15: 4011 16: 4011 bogomips: 79872
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    erms est f16c flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb
    pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
    rep_good sdbg sep sha_ni smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip vaes vme vpclmulqdq x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Dell
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: none empty: DP-1, DP-2, DP-3, HDMI-A-1,
    HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0380
  Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 610.57.04 alternate: nouveau,nvidia_drm
    non-free: 550-6xx.xx+ status: current (as of 2026-07) arch: Ampere
    code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: none off: HDMI-A-4 empty: DP-4,DP-5,DP-6 bus-ID: 01:00.0
    chip-ID: 10de:2504 class-ID: 0300
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:4 chip-ID: 046d:0825
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.24 with: Xwayland v: 24.1.13
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: nvidia
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1017x572mm (40.04x22.52")
    s-diag: 1167mm (45.94") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-4 model: Samsung U32R59x serial: <filter> built: 2018
    res: 3840x2160 dpi: 140 gamma: 1.2 chroma: red: x: 0.651 y: 0.341 green:
    x: 0.298 y: 0.624 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 95 3: parse_edid: unhandled CEA mode 96 4: parse_edid:
    unhandled CEA mode 93 5: parse_edid: unhandled CEA mode 94
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 610.57.04
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
    gpu: nvidia-settings,nvidia-smi x11: xdpyinfo,xprop
  Device-1: Intel 500 Series Family HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-3: C-Media CM106 Like Sound Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0d8c:0102 class-ID: 0300
  Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k7.1.13-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Intel 500 Series Family GbE vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15f9 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  Device-2: TP-Link Archer T3U [Realtek RTL8812BU] driver: rtw88_8822bu
    type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-5:3
    chip-ID: 2357:012d class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u5 state: down mac: <filter>
  Info: services: systemd-networkd,systemd-timesyncd
  Local Storage: total: 3.64 TiB used: 404.25 GiB (10.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800 GOLD
    lanes: 4 tech: SSD serial: <filter> fw-rev: V1122B0 temp: 46.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 1TB SSD
    tech: SSD serial: <filter> fw-rev: 0702 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
    tech: SSD serial: <filter> fw-rev: 091 scheme: GPT
  ID-1: / raw-size: 862.45 GiB size: 847.84 GiB (98.31%)
    used: 404.25 GiB (47.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: ac0e8f6a-e01b-4457-b0b1-56bc2d9ff830
    used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 8668-EEE2
  ID-1: swap-1 type: partition size: 68.77 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: e93bd051-31f0-445f-b015-26abe26f9687
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 484B-7C17
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.82 TiB fs: ntfs label: N/A
    uuid: 1A3C4C453C4C1E5F
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 854 MiB fs: ntfs label: N/A
    uuid: 6A3C2A983C2A5EF7
  ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sdb2 maj-min: 8:18 size: 931.5 GiB fs: ntfs
    label: Extension Disk uuid: 066C33876C337093
  Device-1: 1-2:2 info: C-Media CM106 Like Sound Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-2: 1-8:3 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 30fa:0300 class-ID: 0301
  Device-3: 1-9:4 info: Logitech Webcam C270 type: video,audio
    chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Device-4: 1-10:5 info: Microsoft Wired Keyboard 200 type: keyboard
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 70mA
    chip-ID: 045e:07b9 class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Device-1: 2-5:3 info: TP-Link Archer T3U [Realtek RTL8812BU] type: Network
    driver: rtw88_8822bu interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 504mA chip-ID: 2357:012d class-ID: 0000
    serial: <filter>
  Device-2: 2-9:2 info: Realtek USB3.0-CRW type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0328 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 80.0 C mobo: 37.0 C gpu: nvidia temp: 51 C
  Fan Speeds (rpm): cpu: 1498 fan-2: 1001 fan-3: 1584 gpu: nvidia fan: 0%
  Packages: 1961 pm: pacman pkgs: 1938 libs: 464
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 12 pm: snap pkgs: 11
    1: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 513
  1: cpu: 96.9% command: brave pid: 156189 mem: 2009.9 MiB (3.1%)
  2: cpu: 11.6% command: firefox pid: 47664 mem: 3192.6 MiB (4.9%)
  3: cpu: 7.4% command: firefox pid: 257259 mem: 374.5 MiB (0.5%)
  4: cpu: 4.6% command: Xorg pid: 1124 mem: 580.5 MiB (0.9%)
  5: cpu: 4.5% command: firefox pid: 48810 mem: 772.4 MiB (1.2%)
  Memory top: 5 of 513
  1: mem: 3192.6 MiB (4.9%) command: firefox pid: 47664 cpu: 11.6%
  2: mem: 2009.9 MiB (3.1%) command: brave pid: 156189 cpu: 96.9%
  3: mem: 1437.1 MiB (2.2%) command: pamac-manager pid: 24588 cpu: 0.3%
  4: mem: 949.4 MiB (1.4%) command: firefox pid: 145851 cpu: 0.4%
  5: mem: 772.4 MiB (1.2%) command: firefox pid: 48810 cpu: 4.5%
  Processes: 513 Power: uptime: 1h 29m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.91 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 261
  Compilers: clang: 22.1.8 gcc: 16.2.1 alt: 15 Shell: Bash v: 5.3.15
    running-in: xfce4-terminal inxi: 3.3.41
and
👉ljohnson@KISE-007 ~]$ LANG=C lscpu
Architecture:                x86_64
  CPU op-mode(s):            32-bit, 64-bit
  Address sizes:             39 bits physical, 48 bits virtual
  Byte Order:                Little Endian
CPU(s):                      16
  On-line CPU(s) list:       0-15
Vendor ID:                   GenuineIntel
  Model name:                11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz
    CPU family:              6
    Model:                   167
    Thread(s) per core:      2
    Core(s) per socket:      8
    Socket(s):               1
    Stepping:                1
    Microcode version:       0x66
    CPU(s) scaling MHz:      59%
    CPU max MHz:             5200.0000
    CPU min MHz:             800.0000
    BogoMIPS:                4992.00
    Flags:                   fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pg
                             e mca cmov pat pse36 clflush dts acpi mmx fxsr sse
                             sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm cons
                             tant_tsc art arch_perfmon pebs bts rep_good nopl xt
                             opology nonstop_tsc cpuid aperfmperf tsc_known_freq
                              pni pclmulqdq dtes64 monitor ds_cpl smx est tm2 ss
                             se3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2ap
                             ic movbe popcnt tsc_deadline_timer aes xsave avx f1
                             6c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb
                              ssbd ibrs ibpb stibp ibrs_enhanced fsgsbase tsc_ad
                             just bmi1 avx2 smep bmi2 erms invpcid mpx avx512f a
                             vx512dq rdseed adx smap avx512ifma clflushopt intel
                             _pt avx512cd sha_ni avx512bw avx512vl xsaveopt xsav
                             ec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_n
                             otify hwp_act_window hwp_epp hwp_pkg_req avx512vbmi
                              umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq a
                             vx512_vnni avx512_bitalg avx512_vpopcntdq rdpid fsr
                             m md_clear flush_l1d arch_capabilities
Caches (sum of all):
  L1d:                       384 KiB (8 instances)
  L1i:                       256 KiB (8 instances)
  L2:                        4 MiB (8 instances)
  L3:                        16 MiB (1 instance)
NUMA:
  NUMA node(s):              1
  NUMA node0 CPU(s):         0-15
  Gather data sampling:      Mitigation; Microcode
  Ghostwrite:                Not affected
  Indirect target selection: Mitigation; Aligned branch/return thunks
  Itlb multihit:             Not affected
  L1tf:                      Not affected
  Mds:                       Not affected
  Meltdown:                  Not affected
  Mmio stale data:           Mitigation; Clear CPU buffers; SMT vulnerable
  Old microcode:             Not affected
  Reg file data sampling:    Not affected
  Retbleed:                  Mitigation; Enhanced IBRS
  Spec rstack overflow:      Not affected
  Spec store bypass:         Mitigation; Speculative Store Bypass disabled via p
                             rctl
  Spectre v1:                Mitigation; usercopy/swapgs barriers and __user poi
                             nter sanitization
  Spectre v2:                Mitigation; Enhanced / Automatic IBRS; IBPB conditi
                             onal; PBRSB-eIBRS SW sequence; BHI SW loop, KVM SW
                             loop
  Srbds:                     Not affected
  Tsa:                       Not affected
  Tsx async abort:           Not affected
  Vmscape:                   Not affected
and…
👉[ljohnson@KISE-007 ~]$ lsb_release -sirc
ManjaroLinux 26.1.2 Bian-May
👉[ljohnson@KISE-007 ~]$ mhwd-kernel -li
Currently running: 7.1.13-2-MANJARO (linux71)
   * linux612
   * linux618
   * linux66
   * linux71
👉[ljohnson@KISE-007 ~]$ free -h
               total        used        free      shared  buff/cache   available
Mem:            62Gi        17Gi        36Gi       1.9Gi        10Gi        45Gi
Swap:           68Gi          0B        68Gi
Moderator edit: Merged consecutive replies & separated command output
No idea how you ended up with that package since you do not have the 470xx drivers installed and can’t use them with an RTX 3060.
Remove linux-nvidia-470xx-meta and try updating again after.
sudo pacman -R linux-nvidia-470xx-meta
P.S. In the future, please paste the output of each command in its own code block. I’ve done it for you this time so I could read it.
As suggested…
👉[ljohnson@KISE-007 ~]$ sudo pacman -R linux-nvidia-470xx-meta
error: target not found: linux-nvidia-470xx-meta
And then
👉[ljohnson@KISE-007 ~]$ update-all
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.610 United_States  : https://cofractal-ewr.mm.fcix.net/manjaro/
  0.176 United_States  : https://irltoolkit.mm.fcix.net/manjaro/
  0.470 United_States  : https://ohioix.mm.fcix.net/manjaro/
  0.571 United_States  : https://coresite.mm.fcix.net/manjaro/
  0.638 United_States  : https://repo.ialab.dsu.edu/manjaro/
::INFO Writing mirror list
::United_States   : https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States   : https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States   : https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States   : https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
## Manjaro Linux custom mirrorlist
## Generated on 2026-10-30 12:28
## Please use 'pacman-mirrors -id' To reset custom mirrorlist
## Please use 'pacman-mirrors -c all' To reset custom mirrorlist
## To remove custom config run  'pacman-mirrors -c all'
## Country : United_States
Server = https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Server = https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
Server = https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
Server = https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
Server = https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
 core is up to date
 extra                                                    9.1 MiB  13.7 MiB/s 00:01 [################################################] 100%
 multilib is up to date
:: Replace linux71 with core/linux-meta? [Y/n] y
:: Replace linux71-nvidia-open with extra/linux-nvidia-open-meta? [Y/n] y
after which 517 upgrades were successfully updated.
It appears as if a subsequent update resolved the issue
Thanks for the support…! :slightly_smiling_face: :+1:
Well, you had installed before otherwise it wouldn’t have appeared in your pacman -Qs nvidia output. :wink:
Sorry, I have no clue
You do know kernel 7.1 is EOL, and you need to update to 7.2 or go back to 6.18 (the LTS) kernel.
These are the available kernels on stable
mhwd-kernel -l
available kernels:
   * linux61
   * linux612
   * linux618
   * linux66
   * linux72
   * linux73
   * linux61-rt
   * linux612-rt
   * linux66-rt
He had 7.1 before he updated. :wink:
