Hello folks, running sudo mhwd -a pci nonfree 0300
gave me the following output
> Using config 'video-nvidia' for device: 0000:01:00.0 (0300:10de:1f51) Display controller nVidia Corporation TU106BM [GeForce RTX 2060 Mobile]
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
community downloading...
multilib downloading...
error: target not found: linux514-nvidia
Error: pacman failed!
Error: script failed!
inxi -Faxi
gives this
Host: asdru Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=b7ccff9c-3ed2-4871-9171-b63a484b3dc9 rw quiet splash apparmor=1
security=apparmor resume=UUID=796ccbcb-530d-434a-8efd-c4a8a7338c8b
udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 81UH v: Lenovo Legion Y740-15IRHg
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion Y740-15IRHg
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: BVCN11WW(V1.07)
date: 07/04/2019
ID-1: BAT1 charge: 52.4 Wh (100.0%) condition: 52.4/52.4 Wh (100.0%)
volts: 13.0 min: 11.6 model: Celxpert L17L3PG1 type: Li-ion serial: 190
status: Charging
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
Type: l1tf
Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1f51 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-7:5 chip-ID: 04f2:b604 class-ID: 0e02
serial: 0001
Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: nouveau note: n/a (using device driver) - try sudo/root
failed: nvidia display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: NV166 v: 4.3 Mesa 21.3.5 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi
vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: up mac: 24:ee:9a:ee:76:b8
IP v4: 192.168.1.41/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.1.255
IP v6: fe80::5692:85f1:6561:5747/64 type: noprefixroute scope: link
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 3f:00.0
IF: enp63s0 state: down mac: 7c:8a:e1:20:86:b4
IF-ID-1: br-1bf583a11769 state: down mac: 02:42:f5:33:99:06
IP v4: 172.20.0.1/16 scope: global broadcast: 172.20.255.255
IF-ID-2: br-3a91208e20c8 state: down mac: 02:42:b2:23:d1:cd
IP v4: 172.19.0.1/16 scope: global broadcast: 172.19.255.255
IF-ID-3: br-c504c002828b state: down mac: 02:42:03:a3:0d:27
IP v4: 172.18.0.1/16 scope: global broadcast: 172.18.255.255
IF-ID-4: docker0 state: down mac: 02:42:54:e6:cd:9b
IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
WAN IP: 206.62.162.253
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 158.79 GiB (16.6%)
model: MZVLB1T0HALR-000L2 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: S3RSNX0M903911
rev: 5L1QEXA7 temp: 35.9 C scheme: MBR
ID-1: / raw-size: 919.45 GiB size: 903.95 GiB (98.31%)
used: 158.79 GiB (17.6%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 57.0 C pch: 62.0 C mobo: N/A gpu: nouveau
temp: 48.0 C
Processes: 318 Uptime: 23m wakeups: 1 Memory: 31.27 GiB
used: 3.27 GiB (10.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1448 pacman: 1434 lib: 357 flatpak: 0
snap: 14 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
From here I tried running sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
and then run again the first command but it didn’t fix the issue
Any clues?
Thanks in advance
