Hi,
Am on a new installation of the Cinnamon edition and the latest proprietary nvidia drivers.
I’ve followed Configure NVIDIA (non-free) settings and load them on Startup - Manjaro in order to persist changes in nvidia-settings (although there’s line about it/ some part of it not working with Cinnamon. Please tell me if that’s why I’m having this issue).
The /etc/X11/xorg.conf.d/90-mhwd.conf part, with the resolution and whether G-sync and refresh rate persists across reboots and wakeups.
The things in ~/.nvidia-settings-rc however do not. (in my case changes to brightness and gamma I changed under GPU-0 DP-0 in nvidia-settings)
I added
nvidia-settings --load-config-only
exec $(get_session)
to ~/.xinitrc as the wiki suggests however it doesn’t appear to ever run. I tried adding a line to that file for writing something to a file in ~/ and that doesn’t happen either. If I run nvidia-settings --load-config-only or just nvidia-settings, manually, the gamma and brightess changes immediately.
I tried running nvidia-settings as sudo however then the .nvidia-settings-rc wishes to be saved in /home/root of course and I’m logging in as me when starting the machine. But if I set a different gamma as sudo that change is applied as well when I run nvidia-settings as sudi next time. It doesn’t run automatically after a reboot or wake either.
Is there a way to persist the nvidia-settings Config of .nvidia-settings-rc?
Can I verify that .xinitrc actually executes on login?
-rw-r--r-- 1 eld eld 1963 5 dec 16.51 .nvidia-settings-rc
-rwxr-xr-x 1 eld eld 1618 5 dec 16.19 .xinitrc
Thanks for any replies.
My machine has 1 gpu and 1 display, no built in graphics and no secondary monitor.
Config:
inxi -Fzzzx
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Cinnamon 4.8.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x serial: <filter> UEFI: American Megatrends v: F10
date: 09/18/2020
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86279
Speed: 3591 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3592 2: 2073 3: 2195 4: 2196 5: 2071
6: 2194 7: 2193 8: 2190 9: 3599 10: 2071 11: 2071 12: 2195
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK driver: nvidia v: 455.45.01 bus ID: 07:00.0
Display: x11 server: X.Org 1.20.10 driver: nvidia resolution: 2560x1440
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
Audio: Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 07:00.1
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 09:00.4
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel port: f000 bus ID: 05:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus ID: 06:00.0
IF: wlp6s0 state: down mac: <filter>
Drives: Local Storage: total: 1.36 TiB used: 211.93 GiB (15.2%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD5000AACS-00G8B0 size: 465.76 GiB
ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
Partition: ID-1: / size: 440.22 GiB used: 211.89 GiB (48.1%) fs: ext4 dev: /dev/sda2
Swap: ID-1: swap-1 type: partition size: 17.21 GiB used: 0 KiB (0.0%) dev: /dev/sda3
Sensors: System Temperatures: cpu: 43.1 C mobo: N/A gpu: nvidia temp: 49 C
Info: Processes: 313 Uptime: 24m Memory: 15.64 GiB used: 2.02 GiB (12.9%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1256 Shell: Bash v: 5.0.18 inxi: 3.1.08
