Hi
My laptop has Nvidia 750M along with 4th gen integrated Intel graphics and is on Manjaro-KDE-minimal. I have video-hybrid-intel-nvidia-390xx-bumblebee
installed. The problem that if I launch nvidia-settings
from application launcher it just doesn’t open. If do it from terminal, I don’t even get any output. Same behaviour with nvidia-smi
also.
As an after effect, shutdown or restart takes extremely long and displays Waiting for process: nvidia-settings, Xorg
Whats even weird is that this is not happen every-time! Roughly once every 20 reboots, everything just works fine. I can launch nvidia-settings and the shutdown/reboot is also smooth. Please help me with this.
I am not very experienced with his but I still tried to poke around, try solutions and carry out an investigation to the best of my knowledge as detailed below:
If I execute
pgrep nvidia-settings
to get pid to try to kill it withkill -9 pid
, it just does not get killed! -
Adding
nouveau.modeset=0
toGRUB_CMDLINE_LINUX_DEFAULT=" "
does nothing for me so reverted. -
I have tried ditching bumblebee and using
optimus-manager
but if I switch to nvidia withoptimus-manager --switch nvidia
, the screen goes blank after login screen. -
Tried running
nvidia-settings -pm 1
at boot as a systemd service. This also did nothing for me but there is an interesting observation. If I check the status of the service I created, it mostly displays it was successful and nothing special. Remember I mentioned once every few reboots, everything just works fine. Whenever that happens, the service status is populated additionally with an output saying persistence mode is already enabled. -
If I comment out
blacklist nvidia-drm
from/lib/modprobe.d/bumblebee.conf
the issue is resolved. Now,nvidia-settings
andnvidia-smi
works fine. But now some apps won’t launch. E.g, if I launchkitty
, I get,
$ kitty
[286 13:33:58.376165] [glfw error 65542]: GLX: GLX extension not found
[286 13:33:58.376211] Failed to create GLFW temp window! This usually happens because of old/broken OpenGL drivers. kitty requires working OpenGL 3.3 drivers.
But if execute optirun kitty
it just works!!
I recently switched to manjaro KDE from Manjaro gnome as some gnome extensions were giving me stability issues but now this is giving a whole new headache. Btw, these issue was non existent in gnome. I have spent a lot of time and effort on this and I don’t want ot switch back to gnome because I love this.
I am a student and want to get started with learning cuda. So, this is kinda necessary. The hardware is getting somewhat old and have started saving for a new device but this gets most of the job done and i think it is wiser to keep going as long as it can as the gpu prices are yet to get reasonable.
Here is the output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.4.150-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=861afff4-8652-4a6a-b469-c5a1836e69d0 rw udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Portable System: Dell product: Inspiron 7737 v: N/A serial: <filter>
Chassis: type: 8 v: 0.1 serial: <filter>
Mobo: Dell model: 00V878 v: A00 serial: <filter> UEFI: Dell v: A16
date: 05/24/2018
RAM: total: 7.67 GiB used: 5.18 GiB (67.5%)
Info: Dual Core model: Intel Core i7-4510U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
L2: 4 MiB bogomips: 15968
Speed: 2239 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 2239 2: 2133
3: 2229 4: 1771
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: Dell driver: nvidia
v: 390.144 alternate: nouveau,nvidia_drm bus-ID: 04:00.0 chip-ID: 10de:0fe4
class-ID: 0302
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-2:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-4: Microdia Integrated HD Webcam type: USB driver: uvcvideo
bus-ID: 2-5:8 chip-ID: 0c45:6705 class-ID: 0e02
loaded: intel display-ID: :0 screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.4.150-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:08b1 class-ID: 0280
vendor: Dell driver: r8169 v: kernel port: 4000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
bus-ID: 2-6:5 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 1.35 TiB used: 727.92 GiB (52.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM014-1EJ164
type: HDD rpm: 5400 serial: <filter> rev: DEMA scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0102 scheme: GPT
ID-1: / raw-size: 108 GiB size: 105.75 GiB (97.91%) used: 13.28 GiB (12.6%)
fs: ext4 dev: /dev/sdb6 maj-min: 8:22 label: N/A
uuid: 861afff4-8652-4a6a-b469-c5a1836e69d0
ID-2: /boot/efi raw-size: 529 MiB size: 527.9 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 83C7-6256
ID-3: /mnt/Data raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 714.64 GiB (76.7%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Data
uuid: FAFAA162FAA11BBF
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb5 maj-min: 8:21 label: N/A
uuid: 9c590295-046a-4331-b659-74d8e8417800
ID-1: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
uuid: AE96-81B1
ID-2: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb4 maj-min: 8:20 size: 330.5 GiB fs: ntfs label: N/A
uuid: E2B0A168B0A1443F
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 2-2:2 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-2: 2-4:3 info: MosArt Wireless Keyboard/Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4101 class-ID: 0301
Device-3: 2-5:8 info: Microdia Integrated HD Webcam type: Video
Device-4: 2-6:5 info: Intel Bluetooth wireless interface type: Bluetooth
Device-5: 2-7:6 info: Elan Micro Touchscreen type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04f3:031d class-ID: 0300
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 42.0 C mobo: 37.0 C
Fan Speeds (RPM): cpu: 0
Processes: 296 Uptime: 2h 10m wakeups: 2785 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1203 lib: 347
Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
Here is the output of sudo dmesg | grep -C 10 bbswitch
[ 2.749726] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 2.749727] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 2.749728] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 2.749728] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 2.779226] audit: type=1130 audit(1634085908.573:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.792649] proc: Bad value for 'hidepid'
[ 2.830593] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[ 2.846260] cryptd: max_cpu_qlen set to 1000
[ 2.953393] AVX2 version of gcm_enc/dec engaged.
[ 2.953394] AES CTR mode by8 optimization enabled
[ 2.958346] bbswitch: loading out-of-tree module taints kernel.
[ 2.959163] bbswitch: module verification failed: signature and/or required key missing - tainting kernel
[ 2.962128] bbswitch: version 0.8
[ 2.962135] bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
[ 2.962142] bbswitch: Found discrete VGA device 0000:04:00.0: \_SB_.PCI0.RP05.PEGP
[ 2.962154] ACPI Warning: \_SB.PCI0.RP05.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20190816/nsarguments-59)
[ 2.962429] bbswitch: detected an Optimus _DSM function
[ 2.962442] pci 0000:04:00.0: enabling device (0006 -> 0007)
[ 2.962520] bbswitch: disabling discrete graphics
[ 2.983424] proc: Bad value for 'hidepid'
[ 3.013511] psmouse serio1: synaptics: queried max coordinates: x [..5660], y [..4642]
[ 3.046408] psmouse serio1: synaptics: queried min coordinates: x [1366..], y [1298..]
[ 3.046416] psmouse serio1: synaptics: Your touchpad (PNP: DLL05fb SYN0600 SYN0002 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 3.056324] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/PNP0C14:00-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input8
[ 3.080124] iTCO_vendor_support: vendor-support=0
[ 3.085029] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless N 7260, REV=0x144
[ 3.103487] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 3.103618] iTCO_wdt: Found a Lynx Point_LP TCO device (Version=2, TCOBASE=0x1860)
[ 3.104200] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 3.197995] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 3.246835] r8169 0000:03:00.1 enp3s0f1: renamed from eth0
[ 3.297560] checking generic (c0000000 7f0000) vs hw (c0000000 10000000)
[ 3.297562] fb0: switching to inteldrmfb from EFI VGA
[ 3.297983] Console: switching to colour dummy device 80x25
[ 3.298027] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 3.298915] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.298916] [drm] Driver supports precise vblank timestamp query.
[ 3.299928] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.307578] intel-spi intel-spi: mx25l6405d (8192 Kbytes)
[ 3.319076] bbswitch: Succesfully loaded. Discrete card 0000:04:00.0 is off
[ 3.331414] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 3.337800] Creating 1 MTD partitions on "intel-spi":
[ 3.337805] 0x000000000000-0x000000800000 : "BIOS"
[ 3.345785] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[ 3.347104] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 3.347172] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:31/LNXVIDEO:00/input/input9
[ 3.356122] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 3.361153] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input10
[ 3.363576] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.363716] acpi device:28: Cannot transition to power state D3hot for parent in (unknown)
TIA
