Hello,
I purchased Samsung Galaxy Buds 2 Pro and unfortunately have difficulties in using this on manjaro. I am able to connect to the buds using bluetoothctl
. However compared to my older earphones that are listed as “Audio Device” the new buds is listed as “Other Device” (in the screenshot below the “Galaxy Buds 2 (52E4)” is my older device, listed as “Audio Device” but the top two are the new Galaxy Buds 2 Pro which I do not know why there are two of them but both are listed as “Other device”)
As a result, I cannot direct audio output to the wireless buds – there is simply no such option available in the Settings > Audio
tab.
I found a possibly-related issue in here but I use manjaro-pipewire
so I do not think this is applicable.
I have attached all my inxi -F
outputs below
Host: jxu-omenbyhplaptop17ck1xxx Kernel: 6.1.38-1-MANJARO arch: x86_64
bits: 64 Desktop: KDE Plasma v: 5.27.6 Distro: Manjaro Linux
Type: Laptop System: HP product: OMEN by HP Laptop 17-ck1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8A17 v: 32.25 serial: <superuser required> UEFI: AMI
v: F.15 date: 04/21/2023
ID-1: BAT0 charge: 79.0 Wh (100.0%) condition: 79.0/83.0 Wh (95.1%)
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP cache: L2: 11.5 MiB
Speed (MHz): avg: 1735 min/max: 400/4600:4700:3500 cores: 1: 915 2: 2700
3: 1007 4: 2700 5: 656 6: 2700 7: 842 8: 2700 9: 471 10: 2700 11: 541
12: 2700 13: 814 14: 920 15: 909 16: 640 17: 2700 18: 2700 19: 2700
20: 2700
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] driver: nvidia
v: 535.54.03
Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting,nvidia
unloaded: nouveau dri: iris gpu: i915 resolution: 2560x1440
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2)
Device-1: Intel Alder Lake PCH-P High Definition Audio
driver: sof-audio-pci-intel-tgl
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api
Server-1: PipeWire v: 0.3.74 status: active
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi
IF: wlp0s20f3 state: up mac: f4:c8:8a:e3:a7:4c
driver: r8169
IF: eno1 state: down mac: 7c:4d:8f:9b:c3:31
Device-1: Intel driver: btusb type: USB
Local Storage: total: 2.29 TiB used: 1.12 TiB (49.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
ID-2: /dev/nvme1n1 vendor: Samsung model: MZVL2512HCJQ-00BH1
ID-1: / size: 343.44 GiB used: 103.35 GiB (30.1%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 300.4 MiB used: 23.5 MiB (7.8%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 491.08 GiB used: 345.54 GiB (70.4%) fs: ext4
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p2
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1765 fan-2: 0
Processes: 437 Uptime: 22m Memory: total: 32 GiB note: est.
available: 31.02 GiB used: 10.88 GiB (35.1%) Shell: Zsh inxi: 3.3.28
Any help is greatly appreciated. Thanks!
