Hello,
I have an Optimus Laptop with a UHD 630 and a NVIDIA 1050 TI. I recently installed optimus-manager, which works great. However if I set the boot process to go right into NVIDIA card, the screen tears at the pointer until I log out and in. I am using Cinnamon. I am guessing something is done by logging in that is skipped by just booting up. Here are outputs (in nvidia mode) one could need, If I miss any I will add as soon as I can.
Kernel: 5.12.9-1-MANJARO
Output of lspci -nnk | grep -iA2 vga
00:02.0 VGA compatible controller [0300]: Intel Corporation UHD Graphics 630 (Mobile) [8086:3e9b]
DeviceName: Onboard IGD
Subsystem: Dell Device [1028:087c]
Output of mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
Output of inxi -Fxza
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=090b69ed-1a46-4c9b-9314-4f4483d3df77 rw apparmor=1
security=apparmor udev.log_priority=3 intel_iommu=on iommu=pt
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.29 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 02MJVY v: A00 serial: <filter> UEFI: Dell v: 1.19.0
date: 03/16/2021
ID-1: BAT0 charge: 42.1 Wh (56.4%) condition: 74.6/97.0 Wh (76.9%)
volts: 12.4 min: 11.4 model: SMP DELL GPM0365 type: Li-ion
serial: <filter> status: Charging
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE cache: L2: 9 MiB
bogomips: 52815
Speed: 1648 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 1648 2: 3300
3: 3300 4: 3300 5: 3299 6: 3300 7: 3300 8: 3296 9: 3301 10: 3300 11: 3300
12: 3298
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:671d class-ID: 0e02
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 48 s-size: 2032x1143mm (80.0x45.0")
s-diag: 2331mm (91.8")
Monitor-1: eDP-1-1 res: 3840x2160 hz: 60 dpi: 284
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 465.31 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks driver: ath10k_pci v: kernel port: 3000
bus-ID: 3b:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 0cf3:e301 class-ID: e001
Local Storage: total: 476.94 GiB used: 158.09 GiB (33.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 80003E00
scheme: GPT
ID-1: / raw-size: 226.28 GiB size: 221.67 GiB (97.96%)
used: 153.38 GiB (69.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 88.5 MiB (13.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 4.01 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 61 C
Fan Speeds (RPM): cpu: 3239 fan-2: 3225
Processes: 302 Uptime: 10m wakeups: 2424 Memory: 15.27 GiB
used: 2.13 GiB (14.0%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1260 lib: 310 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: gnome-terminal inxi: 3.3.04
Output of for x in /etc/X11/xorg.conf.d/*.conf; do echo -e "---$x---\n\n $(cat $x)\n\n"; done
---/etc/X11/xorg.conf.d/00-keyboard.conf---
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
EndSection
---/etc/X11/xorg.conf.d/10-optimus-manager.conf---
Section "Files"
ModulePath "/usr/lib/nvidia"
ModulePath "/usr/lib32/nvidia"
ModulePath "/usr/lib32/nvidia/xorg/modules"
ModulePath "/usr/lib32/xorg/modules"
ModulePath "/usr/lib64/nvidia/xorg/modules"
ModulePath "/usr/lib64/nvidia/xorg"
ModulePath "/usr/lib64/xorg/modules"
EndSection
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "integrated"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "Coolbits" "28"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration"
EndSection
Section "Device"
Identifier "integrated"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Device "integrated"
EndSection
Thanks.
