Nvidia scores much lower than Intel in glmark2
I installed Manjaro KDE on my Lenovo Legion 7 laptop this morning. After fully updating the system and rebooting, I ran glmark2 to test out the performance difference between my Intel and Nvidia GPUs. The results were surprising to me when Intel scored 436 and Nvidia scored 250.
Here is the head of the Intel run:
    glmark2 2021.12
    OpenGL Information
    GL_VENDOR:     Intel
    GL_RENDERER:   Mesa Intel(R) UHD Graphics (CML GT2)
    GL_VERSION:    4.6 (Compatibility Profile) Mesa 22.0.3
[build] use-vbo=false: FPS: 352 FrameTime: 2.841 ms
[build] use-vbo=true: FPS: 788 FrameTime: 1.269 ms
                                  glmark2 Score: 436
Here is the head of the Nvidia run:
    glmark2 2021.12
    OpenGL Information
    GL_VENDOR:     NVIDIA Corporation
    GL_RENDERER:   NVIDIA GeForce RTX 2070 Super with Max-Q Design/PCIe/SSE2
    GL_VERSION:    4.6.0 NVIDIA 510.68.02
[build] use-vbo=false: FPS: 253 FrameTime: 3.953 ms
[build] use-vbo=true: FPS: 277 FrameTime: 3.610 ms
                                  glmark2 Score: 250
Did I run this incorrectly, is this a known issue, or is there something else that could be causing this poor performance with my Nvidia card?
Thank you for the reply and info @megavolt. My monitor’s refresh rate is 240 Hz. I ran the command you provided and the results are actually worse.
> vblank_mode=0 prime-run glmark2
    glmark2 2021.12
    OpenGL Information
[build] use-vbo=false: FPS: 227 FrameTime: 4.405 ms
[build] use-vbo=true: FPS: 273 FrameTime: 3.663 ms
                                  glmark2 Score: 244
I will check about using a game for this testing.
