Nvidia rtx overclocking
I'm trying to overclock my rtx 2060 gpu but for some reason coolbits doesn't seem stay set at 8 because when i rebboot after doing
sudo nvidia-xconfig --cool-bits=8
Help would be much appreciated
because the default directory nvidia-xconfig uses is /etc/X11/ and the configuration file thats read by xorg is in /etc/X11/xorg.conf.d
post output of:
inxi -Fxxxz
ls -laR /etc/X11
cat /etc/X11/xorg.conf.d/*.conf
use the </> button above the post entry box when posting terminal output so it's formatted properly and not a mess.
inxi -Fxxxz
System:    Host: Xerneas Kernel: 4.19.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5
           tk: Qt 5.12.3 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: MSI model: X370 SLI PLUS (MS-7A33) v: 2.0 serial: <filter> UEFI: American Megatrends v: 3.E0
           date: 09/25/2018
CPU:       Topology: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen rev: 1 L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 93629
           Speed: 3131 MHz min/max: N/A Core speeds (MHz): 1: 3131 2: 3145 3: 3120 4: 3123 5: 3137 6: 3147 7: 3129 8: 3122
           9: 3378 10: 3817 11: 3143 12: 3123
Graphics:  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: eVga.com. driver: nvidia v: 430.14 bus ID: 29:00.0
           chip ID: 10de:1f08
           Display: x11 server: X.Org 1.20.5 driver: nvidia compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 430.14 direct render: Yes
Audio:     Device-1: NVIDIA TU106 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus ID: 29:00.1
           chip ID: 10de:10f9
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 2b:00.3 chip ID: 1022:1457
           Device-3: Roland type: USB driver: snd-usb-audio bus ID: 1-12:2 chip ID: 0582:01e0
           Sound Server: ALSA v: k4.19.49-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8168
           v: 8.047.01-NAPI port: f000 bus ID: 21:00.0 chip ID: 10ec:8168
           IF: enp33s0 state: down mac: <filter>
           Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k v: kernel port: f000 bus ID: 26:00.0
           chip ID: 168c:0030
           IF: wlp38s0 state: up mac: <filter>
Drives:    Local Storage: total: 2.77 TiB used: 1.74 TiB (62.9%)
           ID-1: /dev/sda vendor: A-Data model: SU800 size: 953.87 GiB speed: 6.0 Gb/s serial: <filter> rev: 7ANR scheme: GPT
           ID-2: /dev/sdb vendor: A-Data model: SU800 size: 953.87 GiB speed: 6.0 Gb/s serial: <filter> rev: 7ANR scheme: GPT
           ID-3: /dev/sdc vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
           serial: <filter> rev: CC49 scheme: GPT
Partition: ID-1: / size: 937.60 GiB used: 362.06 GiB (38.6%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 38.2 C mobo: N/A gpu: nvidia temp: 52 C
Info:      Processes: 275 Uptime: 1h 35m Memory: 15.67 GiB used: 2.01 GiB (12.8%) Init: systemd v: 242 Compilers: gcc: 8.3.0
           Shell: bash v: 5.0.7 running in: konsole inxi: 3.0.34
ls -laR /etc/X11
/etc/X11:
total 40
drwxr-xr-x  5 root root 4096 Jun 25 13:58 .
drwxr-xr-x 88 root root 4096 Jun 25 14:24 ..
drwxr-xr-x  2 root root 4096 Jun 15 19:19 mhwd.d
drwxr-xr-x  3 root root 4096 Mar 12 05:40 xinit
-rw-r--r--  1 root root 1230 Jun 25 13:58 xorg.conf
-rw-r--r--  1 root root 1230 Jun 25 13:58 xorg.conf.backup
drwxr-xr-x  2 root root 4096 Jun 15 19:19 xorg.conf.d
-rw-r--r--  1 root root    0 Jun 25 13:45 xorg.conf.nvidia-xconfig-original
/etc/X11/mhwd.d:
total 16
drwxr-xr-x 2 root root 4096 Jun 15 19:19 .
drwxr-xr-x 5 root root 4096 Jun 25 13:58 ..
-rw-r--r-- 1 root root 1522 Jun 15 19:19 nvidia.conf
-rw-r--r-- 1 root root    0 Jun 15 19:19 nvidia.conf.nvidia-xconfig-original
/etc/X11/xinit:
total 28
drwxr-xr-x 3 root root 4096 Mar 12 05:40 .
-rw-r--r-- 1 root root  739 Mar  4 13:31 xinitrc
drwxr-xr-x 2 root root 4096 Jun 16 00:10 xinitrc.d
-rw-r--r-- 1 root root   45 Mar  4 13:31 xserverrc
/etc/X11/xinit/xinitrc.d:
total 20
drwxr-xr-x 2 root root 4096 Jun 16 00:10 .
drwxr-xr-x 3 root root 4096 Mar 12 05:40 ..
-rwxr-xr-x 1 root root  318 Nov  9  2018 40-libcanberra-gtk-module.sh
-rwxr-xr-x 1 root root  203 May 11 07:13 50-systemd-user.sh
/etc/X11/xorg.conf.d:
total 16
-rw-r--r-- 1 root root  266 Jun 15 19:19 00-keyboard.conf
lrwxrwxrwx 1 root root   27 Jun 15 19:19 90-mhwd.conf -> /etc/X11/mhwd.d/nvidia.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "us"
        Option "XkbModel" "pc105"
EndSection
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 418.43
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
        Option "NoLogo" "1"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
ok, from terminal
sudo nvidia-xconfig -c /etc/X11/mhwd.d/nvidia.conf -o /etc/X11/mhwd.d/nvidia.conf --cool-bits=8
#then post
cat /etc/X11/mhwd.d/nvidia.conf
and coolbits should be set in the config
also, if your using GWE to do the overclocking make sure you dont set it to start on boot, if you accidentally enter a value that causes the gpu to crash it will load that value when you boot and so causing the crash during boot each time. make sure it's a stable value before commiting it to be persistent. i use the nvidia settings to do it when needed so it's not active all the time.
# nvidia-xconfig:  version 430.14
    Screen      0  "Screen0" 0 0
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
EndSection
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "NoLogo" "1"
    Option         "Coolbits" "8"
        Depth       24
    EndSubSection
EndSection
EndSection
coolbits is set, reboot and it should be all set
works thx
