Hi everyone, I have recently installed manjaro kde and I have a problem with the gpu. I have a 3060 ti and the games hold up very well at 60 fps but it all seems very laggy. If I scroll down on google chrome some text seems blurry. Since I have a 4k 60Hz monitor I would like to always keep vsync active (on windows 11 I never had lag problems keeping it always on). The resolution is 1080p because I switch to another monitor and prefer to have it that way. Post my system information.
Host: PC-Gaming-Linux Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.24.4 Distro: Manjaro Linux
Type: Desktop System: Micro-Star product: MS-7B79 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: X470 GAMING PRO (MS-7B79) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.I0
date: 01/26/2022
Info: 6-core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP cache:
L2: 3 MiB
Speed (MHz): avg: 2110 min/max: 2200/3600 cores: 1: 2097 2: 1868 3: 1733
4: 1978 5: 1736 6: 3416 7: 2795 8: 1733 9: 1721 10: 1834 11: 1734 12: 2676
Device-1: NVIDIA GA103 [GeForce RTX 3060 Ti] driver: nvidia v: 510.60.02
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
gpu: nvidia resolution: 1: 1920x1080~60Hz 2: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02
Device-1: NVIDIA driver: snd_hda_intel
Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.49 running: yes
driver: r8168
IF: enp34s0 state: up speed: 1000 Mbps duplex: full
mac: 30:9c:23:e0:f3:e0
Local Storage: total: 1.14 TiB used: 513.12 GiB (44.1%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
ID-2: /dev/sdb vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
ID-1: / size: 219.22 GiB used: 95.73 GiB (43.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 49 C
Processes: 303 Uptime: 41m Memory: 15.61 GiB used: 2.88 GiB (18.5%)
Shell: Zsh inxi: 3.3.15
[ 0.410879] SPI driver ili9163 has no spi_device_id for newhaven,1.8-128160EF
[ 0.891921] ata1.00: supports DRM functions and may not be fully accessible
[ 0.896322] ata1.00: supports DRM functions and may not be fully accessible
[ 4.478426] systemd-journald[349]: File /var/log/journal/861884b3fccd483da7acf90b550cd9cc/system.journal cor
rupted or uncleanly shut down, renaming and replacing.
[ 4.546161] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on
PNP0C14:01)
[ 4.592578] razerkbd: loading out-of-tree module taints kernel.
[ 4.611785] nvidia: module license 'NVIDIA' taints kernel.
[ 4.611790] Disabling lock debugging due to kernel taint
[ 4.650639] r8168 Copyright (C) 2021 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/lic
enses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <ht
tp://www.gnu.org/licenses/>.
[ 4.695483] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.60.02 Wed Mar 16 11:24:05 UTC 2022
[ 5.116689] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 5.442767] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.451073] kauditd_printk_skb: 38 callbacks suppressed
[ 7.899705] systemd-journald[349]: File /var/log/journal/861884b3fccd483da7acf90b550cd9cc/user-1000.journal
corrupted or uncleanly shut down, renaming and replacing.
[ 15.727704] kauditd_printk_skb: 46 callbacks suppressed
[ 136.840259] show_signal_msg: 2 callbacks suppressed
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 510.60.02
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung U28E590"
HorizSync 135.0 - 135.0
VertRefresh 40.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 3060 Ti"
Option "Coolbits" "31"
Option "TripleBuffer" "on"
EndSection
Section "Screen"
# Removed Option "metamodes" "1920x1080 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}; 1920x1080 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-1"
Option "metamodes" "DP-0: 1920x1080_60 +0+0 {ForceCompositionPipeline=On}; HDMI-0: 1920x1080 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
