There is no such folder in my system. Logs from /var/log/Xorg.0.log
$ cat /var/log/Xorg.0.log
[ 3.283] (--) Log file renamed from "/var/log/Xorg.pid-612.log" to "/var/log/Xorg.0.log"
[ 3.284]
X.Org X Server 1.20.8
[ 3.284] Build Operating System: Linux Manjaro Linux
[ 3.284] Current Operating System: Linux manjaro 5.8.6-1-MANJARO #1 SMP PREEMPT Thu Sep 3 14:19:36 UTC 2020 x86_64
[ 3.284] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=2d07bc7e-c35e-4708-955e-d0f05409dca4 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 3.284] Build Date: 01 August 2020 07:25:56AM
[ 3.284]
[ 3.284] Current version of pixman: 0.40.0
[ 3.284] Before reporting problems, check http://wiki.x.org
[ 3.284] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3.284] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 21 11:45:52 2020
[ 3.285] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.285] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.286] (==) ServerLayout "layout"
[ 3.286] (**) |-->Screen "nvidia" (0)
[ 3.286] (**) | |-->Monitor "<default monitor>"
[ 3.286] (**) | |-->Device "nvidia"
[ 3.286] (**) | |-->GPUDevice "intel"
[ 3.286] (==) No monitor specified for screen "nvidia".
[ 3.286] (==) Automatically adding devices
[ 3.286] (==) Automatically enabling devices
[ 3.286] (==) Automatically adding GPU devices
[ 3.286] (==) Automatically binding GPU devices
[ 3.286] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.286] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 3.286] Entry deleted from font path.
[ 3.286] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 3.287] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 3.287] Entry deleted from font path.
[ 3.287] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 3.287] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 3.287] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 3.287] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 3.287] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 3.287] (==) FontPath set to:
[ 3.287] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.287] (II) The server relies on udev to provide the list of input devices.
[ 3.287] (II) Module ABI versions:
[ 3.287] X.Org ANSI C Emulation: 0.4
[ 3.287] X.Org Video Driver: 24.1
[ 3.287] X.Org XInput driver : 24.1
[ 3.287] X.Org Server Extension : 10.0
[ 3.287] (++) using VT number 1
[ 3.287] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 3.288] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 3.288] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 3.290] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 3.290] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 3.291] (--) PCI: (0@0:2:0) 8086:1912:1043:8694 rev 6, Mem @ 0xf5000000/16777216, 0xd0000000/268435456, I/O @ 0x0000f000/64
[ 3.291] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 3.291] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3.291] (II) LoadModule: "glx"
[ 3.292] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.296] (II) Module glx: vendor="X.Org Foundation"
[ 3.296] compiled for 1.20.8, module version = 1.0.0
[ 3.296] ABI class: X.Org Server Extension, version 10.0
[ 3.296] (II) LoadModule: "nvidia"
[ 3.297] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 3.300] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 3.300] compiled for 1.6.99.901, module version = 1.0.0
[ 3.300] Module class: X.Org Video Driver
[ 3.301] (II) LoadModule: "modesetting"
[ 3.301] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.302] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.302] compiled for 1.20.8, module version = 1.20.8
[ 3.302] Module class: X.Org Video Driver
[ 3.302] ABI class: X.Org Video Driver, version 24.1
[ 3.302] (II) NVIDIA dlloader X Driver 450.66 Wed Aug 12 19:44:12 UTC 2020
[ 3.302] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 3.302] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.303] (II) Loading sub module "fb"
[ 3.303] (II) LoadModule: "fb"
[ 3.303] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3.303] (II) Module fb: vendor="X.Org Foundation"
[ 3.303] compiled for 1.20.8, module version = 1.0.0
[ 3.303] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.303] (II) Loading sub module "wfb"
[ 3.303] (II) LoadModule: "wfb"
[ 3.303] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 3.304] (II) Module wfb: vendor="X.Org Foundation"
[ 3.304] compiled for 1.20.8, module version = 1.0.0
[ 3.304] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.304] (II) Loading sub module "ramdac"
[ 3.304] (II) LoadModule: "ramdac"
[ 3.304] (II) Module "ramdac" already built-in
[ 3.307] (II) modeset(G0): using drv /dev/dri/card1
[ 3.307] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 3.307] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 3.307] (==) NVIDIA(0): RGB weight 888
[ 3.307] (==) NVIDIA(0): Default visual is TrueColor
[ 3.307] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3.307] (**) Option "AllowNVIDIAGpuScreens"
[ 3.307] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 3.307] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 3.307] (**) NVIDIA(0): Enabling 2D acceleration
[ 3.307] (II) Loading sub module "glxserver_nvidia"
[ 3.307] (II) LoadModule: "glxserver_nvidia"
[ 3.307] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 3.323] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 3.323] compiled for 1.6.99.901, module version = 1.0.0
[ 3.323] Module class: X.Org Server Extension
[ 3.324] (II) NVIDIA GLX Module 450.66 Wed Aug 12 19:41:37 UTC 2020
[ 3.324] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 4.125] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 4.125] (--) NVIDIA(0): CRT-0
[ 4.125] (--) NVIDIA(0): DFP-0
[ 4.125] (--) NVIDIA(0): DFP-1
[ 4.125] (--) NVIDIA(0): DFP-2 (boot)
[ 4.125] (--) NVIDIA(0): DFP-3
[ 4.125] (--) NVIDIA(0): DFP-4
[ 4.126] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[ 4.126] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 4.126] (--) NVIDIA(0): VideoBIOS: 84.04.36.00.f1
[ 4.126] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 4.219] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): connected
[ 4.219] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): 400.0 MHz maximum pixel clock
[ 4.295] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4.295] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 4.295] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 4.295] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4.295] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 4.295] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 4.437] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): connected
[ 4.437] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): Internal DisplayPort
[ 4.437] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): 960.0 MHz maximum pixel clock
[ 4.439] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 4.439] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 4.439] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 4.439] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4.439] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 4.439] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 4.442] (==) NVIDIA(0):
[ 4.442] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 4.442] (==) NVIDIA(0): will be used as the requested mode.
[ 4.442] (II) NVIDIA(0): Validated MetaModes:
[ 4.442] (II) NVIDIA(0): "DFP-2:nvidia-auto-select,CRT-0:nvidia-auto-select"
[ 4.442] (II) NVIDIA(0): Virtual screen size determined to be 3200 x 1080
[ 4.444] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[ 4.444] (--) NVIDIA(0): option
[ 4.444] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 4.444] (==) modeset(G0): RGB weight 888
[ 4.444] (==) modeset(G0): Default visual is TrueColor
[ 4.444] (II) Loading sub module "glamoregl"
[ 4.444] (II) LoadModule: "glamoregl"
[ 4.444] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 4.449] (II) Module glamoregl: vendor="X.Org Foundation"
[ 4.449] compiled for 1.20.8, module version = 1.0.1
[ 4.449] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.594] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 530 (SKL GT2)
[ 4.594] (II) modeset(G0): glamor initialized
[ 4.598] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 4.603] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[ 4.603] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 4.607] (II) modeset(G0): Output HDMI-1-3 has no monitor section
[ 4.608] (II) modeset(G0): Output DP-1-2 has no monitor section
[ 4.612] (II) modeset(G0): EDID for output HDMI-1-1
[ 4.617] (II) modeset(G0): EDID for output HDMI-1-2
[ 4.617] (II) modeset(G0): EDID for output DP-1-1
[ 4.622] (II) modeset(G0): EDID for output HDMI-1-3
[ 4.622] (II) modeset(G0): EDID for output DP-1-2
[ 4.622] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.622] (==) modeset(G0): DPI set to (96, 96)
[ 4.622] (II) Loading sub module "fb"
[ 4.622] (II) LoadModule: "fb"
[ 4.622] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 4.622] (II) Module fb: vendor="X.Org Foundation"
[ 4.622] compiled for 1.20.8, module version = 1.0.0
[ 4.622] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.622] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 4.622] (II) NVIDIA: access.
[ 4.624] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 4.624] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 4.624] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 4.624] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 4.624] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 4.624] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 4.624] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 4.624] (II) NVIDIA(0): Config Options in the README.
[ 4.636] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select,CRT-0:nvidia-auto-select"
[ 4.717] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 4.717] (==) NVIDIA(0): Backing store enabled
[ 4.717] (==) NVIDIA(0): Silken mouse disabled
[ 4.717] (==) NVIDIA(0): DPMS enabled
[ 4.717] (II) Loading sub module "dri2"
[ 4.717] (II) LoadModule: "dri2"
[ 4.717] (II) Module "dri2" already built-in
[ 4.717] (II) NVIDIA(0): [DRI2] Setup complete
[ 4.717] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 4.725] (==) modeset(G0): Backing store enabled
[ 4.725] (==) modeset(G0): Silken mouse disabled
[ 4.725] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 4.725] (==) modeset(G0): DPMS enabled
[ 4.725] (II) modeset(G0): [DRI2] Setup complete
[ 4.725] (II) modeset(G0): [DRI2] DRI driver: iris
[ 4.725] (II) modeset(G0): [DRI2] VDPAU driver: va_gl
[ 4.725] (II) Initializing extension Generic Event Extension
[ 4.726] (II) Initializing extension SHAPE
[ 4.726] (II) Initializing extension MIT-SHM
[ 4.726] (II) Initializing extension XInputExtension
[ 4.726] (II) Initializing extension XTEST
[ 4.726] (II) Initializing extension BIG-REQUESTS
[ 4.726] (II) Initializing extension SYNC
[ 4.726] (II) Initializing extension XKEYBOARD
[ 4.726] (II) Initializing extension XC-MISC
[ 4.726] (II) Initializing extension SECURITY
[ 4.726] (II) Initializing extension XFIXES
[ 4.726] (II) Initializing extension RENDER
[ 4.726] (II) Initializing extension RANDR
[ 4.727] (II) Initializing extension COMPOSITE
[ 4.727] (II) Initializing extension DAMAGE
[ 4.727] (II) Initializing extension MIT-SCREEN-SAVER
[ 4.727] (II) Initializing extension DOUBLE-BUFFER
[ 4.727] (II) Initializing extension RECORD
[ 4.727] (II) Initializing extension DPMS
[ 4.727] (II) Initializing extension Present
[ 4.727] (II) Initializing extension DRI3
[ 4.727] (II) Initializing extension X-Resource
[ 4.727] (II) Initializing extension XVideo
[ 4.727] (II) Initializing extension XVideo-MotionCompensation
[ 4.727] (II) Initializing extension GLX
[ 4.727] (II) Indirect GLX disabled.
[ 4.727] (II) GLX: Another vendor is already registered for screen 0
[ 4.727] (II) Initializing extension XFree86-VidModeExtension
[ 4.727] (II) Initializing extension XFree86-DGA
[ 4.728] (II) Initializing extension XFree86-DRI
[ 4.728] (II) Initializing extension DRI2
[ 4.728] (II) Initializing extension NV-GLX
[ 4.728] (II) Initializing extension NV-CONTROL
[ 4.728] (II) Initializing extension XINERAMA
[ 4.730] (II) modeset(G0): Damage tracking initialized
[ 4.768] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 4.768] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4.768] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.768] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.768] (II) LoadModule: "libinput"
[ 4.768] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 4.770] (II) Module libinput: vendor="X.Org Foundation"
[ 4.770] compiled for 1.20.8, module version = 0.30.0
[ 4.770] Module class: X.Org XInput Driver
[ 4.770] ABI class: X.Org XInput driver, version 24.1
[ 4.770] (II) Using input driver 'libinput' for 'Power Button'
[ 4.770] (**) Power Button: always reports core events
[ 4.770] (**) Option "Device" "/dev/input/event2"
[ 4.770] (**) Option "_source" "server/udev"
[ 4.773] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 4.773] (II) event2 - Power Button: device is a keyboard
[ 4.773] (II) event2 - Power Button: device removed
[ 4.800] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 4.800] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 4.800] (**) Option "xkb_model" "pc105"
[ 4.800] (**) Option "xkb_layout" "pl"
[ 4.814] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 4.814] (II) event2 - Power Button: device is a keyboard
[ 4.814] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 4.814] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 4.814] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 4.814] (**) Video Bus: Applying InputClass "system-keyboard"
[ 4.814] (II) Using input driver 'libinput' for 'Video Bus'
[ 4.814] (**) Video Bus: always reports core events
[ 4.814] (**) Option "Device" "/dev/input/event3"
[ 4.814] (**) Option "_source" "server/udev"
[ 4.815] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 4.815] (II) event3 - Video Bus: device is a keyboard
[ 4.815] (II) event3 - Video Bus: device removed
[ 4.880] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3/event3"
[ 4.880] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 4.880] (**) Option "xkb_model" "pc105"
[ 4.880] (**) Option "xkb_layout" "pl"
[ 4.884] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 4.884] (II) event3 - Video Bus: device is a keyboard
[ 4.886] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 4.886] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4.886] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.886] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.886] (II) Using input driver 'libinput' for 'Power Button'
[ 4.886] (**) Power Button: always reports core events
[ 4.886] (**) Option "Device" "/dev/input/event1"
[ 4.886] (**) Option "_source" "server/udev"
[ 4.889] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.889] (II) event1 - Power Button: device is a keyboard
[ 4.889] (II) event1 - Power Button: device removed
[ 4.906] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 4.906] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 4.907] (**) Option "xkb_model" "pc105"
[ 4.907] (**) Option "xkb_layout" "pl"
[ 4.910] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.910] (II) event1 - Power Button: device is a keyboard
[ 4.912] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 4.912] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 4.912] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 4.912] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 4.912] (II) Using input driver 'libinput' for 'Sleep Button'
[ 4.912] (**) Sleep Button: always reports core events
[ 4.912] (**) Option "Device" "/dev/input/event0"
[ 4.912] (**) Option "_source" "server/udev"
[ 4.915] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 4.916] (II) event0 - Sleep Button: device is a keyboard
[ 4.916] (II) event0 - Sleep Button: device removed
[ 4.946] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 4.946] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 4.946] (**) Option "xkb_model" "pc105"
[ 4.947] (**) Option "xkb_layout" "pl"
[ 4.950] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 4.950] (II) event0 - Sleep Button: device is a keyboard
[ 4.954] (II) config/udev: Adding input device SINOWEALTH Game Mouse (/dev/input/event7)
[ 4.954] (**) SINOWEALTH Game Mouse: Applying InputClass "evdev pointer catchall"
[ 4.954] (**) SINOWEALTH Game Mouse: Applying InputClass "libinput pointer catchall"
[ 4.954] (II) Using input driver 'libinput' for 'SINOWEALTH Game Mouse'
[ 4.954] (**) SINOWEALTH Game Mouse: always reports core events
[ 4.955] (**) Option "Device" "/dev/input/event7"
[ 4.955] (**) Option "_source" "server/udev"
[ 5.014] (II) event7 - SINOWEALTH Game Mouse: is tagged by udev as: Mouse
[ 5.015] (II) event7 - SINOWEALTH Game Mouse: device is a pointer
[ 5.015] (II) event7 - SINOWEALTH Game Mouse: device removed
[ 5.066] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-14/1-14:1.0/0003:258A:0017.0003/input/input7/event7"
[ 5.066] (II) XINPUT: Adding extended input device "SINOWEALTH Game Mouse" (type: MOUSE, id 10)
[ 5.067] (**) Option "AccelerationScheme" "none"
[ 5.067] (**) SINOWEALTH Game Mouse: (accel) selected scheme none/0
[ 5.067] (**) SINOWEALTH Game Mouse: (accel) acceleration factor: 2.000
[ 5.067] (**) SINOWEALTH Game Mouse: (accel) acceleration threshold: 4
[ 5.127] (II) event7 - SINOWEALTH Game Mouse: is tagged by udev as: Mouse
[ 5.128] (II) event7 - SINOWEALTH Game Mouse: device is a pointer
[ 5.130] (II) config/udev: Adding input device SINOWEALTH Game Mouse (/dev/input/mouse0)
[ 5.130] (II) No input driver specified, ignoring this device.
[ 5.130] (II) This device may have been added with another device file.
[ 5.132] (II) config/udev: Adding input device SINOWEALTH Game Mouse Keyboard (/dev/input/event8)
[ 5.132] (**) SINOWEALTH Game Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 5.133] (**) SINOWEALTH Game Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 5.133] (**) SINOWEALTH Game Mouse Keyboard: Applying InputClass "system-keyboard"
[ 5.133] (II) Using input driver 'libinput' for 'SINOWEALTH Game Mouse Keyboard'
[ 5.133] (**) SINOWEALTH Game Mouse Keyboard: always reports core events
[ 5.133] (**) Option "Device" "/dev/input/event8"
[ 5.133] (**) Option "_source" "server/udev"
[ 5.137] (II) event8 - SINOWEALTH Game Mouse Keyboard: is tagged by udev as: Keyboard
[ 5.138] (II) event8 - SINOWEALTH Game Mouse Keyboard: device is a keyboard
[ 5.139] (II) event8 - SINOWEALTH Game Mouse Keyboard: device removed
[ 5.160] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-14/1-14:1.1/0003:258A:0017.0004/input/input8/event8"
[ 5.160] (II) XINPUT: Adding extended input device "SINOWEALTH Game Mouse Keyboard" (type: KEYBOARD, id 11)
[ 5.160] (**) Option "xkb_model" "pc105"
[ 5.160] (**) Option "xkb_layout" "pl"
[ 5.165] (II) event8 - SINOWEALTH Game Mouse Keyboard: is tagged by udev as: Keyboard
[ 5.166] (II) event8 - SINOWEALTH Game Mouse Keyboard: device is a keyboard
[ 5.169] (II) config/udev: Adding input device CM Storm Keyboard -- QuickFire XT (/dev/input/event4)
[ 5.169] (**) CM Storm Keyboard -- QuickFire XT: Applying InputClass "evdev keyboard catchall"
[ 5.169] (**) CM Storm Keyboard -- QuickFire XT: Applying InputClass "libinput keyboard catchall"
[ 5.169] (**) CM Storm Keyboard -- QuickFire XT: Applying InputClass "system-keyboard"
[ 5.169] (II) Using input driver 'libinput' for 'CM Storm Keyboard -- QuickFire XT'
[ 5.169] (**) CM Storm Keyboard -- QuickFire XT: always reports core events
[ 5.169] (**) Option "Device" "/dev/input/event4"
[ 5.169] (**) Option "_source" "server/udev"
[ 5.174] (II) event4 - CM Storm Keyboard -- QuickFire XT: is tagged by udev as: Keyboard
[ 5.174] (II) event4 - CM Storm Keyboard -- QuickFire XT: device is a keyboard
[ 5.175] (II) event4 - CM Storm Keyboard -- QuickFire XT: device removed
[ 5.200] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:2516:001A.0001/input/input4/event4"
[ 5.200] (II) XINPUT: Adding extended input device "CM Storm Keyboard -- QuickFire XT" (type: KEYBOARD, id 12)
[ 5.200] (**) Option "xkb_model" "pc105"
[ 5.200] (**) Option "xkb_layout" "pl"
[ 5.205] (II) event4 - CM Storm Keyboard -- QuickFire XT: is tagged by udev as: Keyboard
[ 5.205] (II) event4 - CM Storm Keyboard -- QuickFire XT: device is a keyboard
[ 5.208] (II) config/udev: Adding input device CM Storm Keyboard -- QuickFire XT Consumer Control (/dev/input/event5)
[ 5.208] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 5.209] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 5.209] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: Applying InputClass "system-keyboard"
[ 5.209] (II) Using input driver 'libinput' for 'CM Storm Keyboard -- QuickFire XT Consumer Control'
[ 5.209] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: always reports core events
[ 5.209] (**) Option "Device" "/dev/input/event5"
[ 5.209] (**) Option "_source" "server/udev"
[ 5.214] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: is tagged by udev as: Keyboard
[ 5.214] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: device is a keyboard
[ 5.215] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: device removed
[ 5.266] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:2516:001A.0002/input/input5/event5"
[ 5.266] (II) XINPUT: Adding extended input device "CM Storm Keyboard -- QuickFire XT Consumer Control" (type: KEYBOARD, id 13)
[ 5.266] (**) Option "xkb_model" "pc105"
[ 5.266] (**) Option "xkb_layout" "pl"
[ 5.272] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: is tagged by udev as: Keyboard
[ 5.272] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: device is a keyboard
[ 5.275] (II) config/udev: Adding input device CM Storm Keyboard -- QuickFire XT System Control (/dev/input/event6)
[ 5.275] (**) CM Storm Keyboard -- QuickFire XT System Control: Applying InputClass "evdev keyboard catchall"
[ 5.275] (**) CM Storm Keyboard -- QuickFire XT System Control: Applying InputClass "libinput keyboard catchall"
[ 5.275] (**) CM Storm Keyboard -- QuickFire XT System Control: Applying InputClass "system-keyboard"
[ 5.275] (II) Using input driver 'libinput' for 'CM Storm Keyboard -- QuickFire XT System Control'
[ 5.275] (**) CM Storm Keyboard -- QuickFire XT System Control: always reports core events
[ 5.275] (**) Option "Device" "/dev/input/event6"
[ 5.275] (**) Option "_source" "server/udev"
[ 5.280] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: is tagged by udev as: Keyboard
[ 5.280] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: device is a keyboard
[ 5.281] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: device removed
[ 5.306] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:2516:001A.0002/input/input6/event6"
[ 5.306] (II) XINPUT: Adding extended input device "CM Storm Keyboard -- QuickFire XT System Control" (type: KEYBOARD, id 14)
[ 5.307] (**) Option "xkb_model" "pc105"
[ 5.307] (**) Option "xkb_layout" "pl"
[ 5.312] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: is tagged by udev as: Keyboard
[ 5.312] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: device is a keyboard
[ 5.314] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event11)
[ 5.314] (II) No input driver specified, ignoring this device.
[ 5.314] (II) This device may have been added with another device file.
[ 5.315] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[ 5.315] (II) No input driver specified, ignoring this device.
[ 5.315] (II) This device may have been added with another device file.
[ 5.316] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event13)
[ 5.316] (II) No input driver specified, ignoring this device.
[ 5.316] (II) This device may have been added with another device file.
[ 5.317] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event14)
[ 5.317] (II) No input driver specified, ignoring this device.
[ 5.317] (II) This device may have been added with another device file.
[ 5.318] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event15)
[ 5.318] (II) No input driver specified, ignoring this device.
[ 5.318] (II) This device may have been added with another device file.
[ 5.319] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event16)
[ 5.319] (II) No input driver specified, ignoring this device.
[ 5.319] (II) This device may have been added with another device file.
[ 5.320] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event17)
[ 5.320] (II) No input driver specified, ignoring this device.
[ 5.320] (II) This device may have been added with another device file.
[ 5.321] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event18)
[ 5.321] (II) No input driver specified, ignoring this device.
[ 5.321] (II) This device may have been added with another device file.
[ 5.322] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event19)
[ 5.322] (II) No input driver specified, ignoring this device.
[ 5.322] (II) This device may have been added with another device file.
[ 5.323] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event20)
[ 5.323] (II) No input driver specified, ignoring this device.
[ 5.323] (II) This device may have been added with another device file.
[ 5.324] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event21)
[ 5.324] (II) No input driver specified, ignoring this device.
[ 5.324] (II) This device may have been added with another device file.
[ 5.326] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event22)
[ 5.326] (II) No input driver specified, ignoring this device.
[ 5.326] (II) This device may have been added with another device file.
[ 5.327] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event23)
[ 5.327] (II) No input driver specified, ignoring this device.
[ 5.327] (II) This device may have been added with another device file.
[ 5.328] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event10)
[ 5.328] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 5.328] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 5.328] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 5.328] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 5.328] (**) Eee PC WMI hotkeys: always reports core events
[ 5.328] (**) Option "Device" "/dev/input/event10"
[ 5.328] (**) Option "_source" "server/udev"
[ 5.331] (II) event10 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 5.331] (II) event10 - Eee PC WMI hotkeys: device is a keyboard
[ 5.332] (II) event10 - Eee PC WMI hotkeys: device removed
[ 5.386] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input12/event10"
[ 5.386] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 15)
[ 5.386] (**) Option "xkb_model" "pc105"
[ 5.386] (**) Option "xkb_layout" "pl"
[ 5.390] (II) event10 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 5.390] (II) event10 - Eee PC WMI hotkeys: device is a keyboard
[ 5.392] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 5.392] (II) No input driver specified, ignoring this device.
[ 5.392] (II) This device may have been added with another device file.
[ 5.406] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): connected
[ 5.406] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): Internal DisplayPort
[ 5.406] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): 960.0 MHz maximum pixel clock
[ 5.407] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event20)
[ 5.407] (II) No input driver specified, ignoring this device.
[ 5.407] (II) This device may have been added with another device file.
[ 5.408] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event11)
[ 5.408] (II) No input driver specified, ignoring this device.
[ 5.408] (II) This device may have been added with another device file.
[ 5.409] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event14)
[ 5.409] (II) No input driver specified, ignoring this device.
[ 5.409] (II) This device may have been added with another device file.
[ 5.409] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event16)
[ 5.410] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[ 5.410] (II) No input driver specified, ignoring this device.
[ 5.410] (II) This device may have been added with another device file.
[ 5.411] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event22)
[ 5.411] (II) No input driver specified, ignoring this device.
[ 5.411] (II) This device may have been added with another device file.
[ 5.412] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event13)
[ 5.412] (II) No input driver specified, ignoring this device.
[ 5.412] (II) This device may have been added with another device file.
[ 5.412] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event23)
[ 5.413] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event17)
[ 5.413] (II) No input driver specified, ignoring this device.
[ 5.413] (II) This device may have been added with another device file.
[ 5.414] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event15)
[ 5.414] (II) No input driver specified, ignoring this device.
[ 5.414] (II) This device may have been added with another device file.
[ 5.415] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event19)
[ 5.415] (II) No input driver specified, ignoring this device.
[ 5.415] (II) This device may have been added with another device file.
[ 5.415] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event21)
[ 5.416] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event18)
[ 5.416] (II) No input driver specified, ignoring this device.
[ 5.416] (II) This device may have been added with another device file.
[ 5.418] (II) config/udev: Adding input device SINOWEALTH Game Mouse (/dev/input/mouse0)
[ 5.418] (II) No input driver specified, ignoring this device.
[ 5.418] (II) This device may have been added with another device file.
[ 5.419] (II) config/udev: removing device CM Storm Keyboard -- QuickFire XT System Control
[ 5.419] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: device removed
[ 5.466] (II) UnloadModule: "libinput"
[ 5.468] (II) config/udev: Adding input device CM Storm Keyboard -- QuickFire XT System Control (/dev/input/event6)
[ 5.468] (**) CM Storm Keyboard -- QuickFire XT System Control: Applying InputClass "evdev keyboard catchall"
[ 5.468] (**) CM Storm Keyboard -- QuickFire XT System Control: Applying InputClass "libinput keyboard catchall"
[ 5.468] (**) CM Storm Keyboard -- QuickFire XT System Control: Applying InputClass "system-keyboard"
[ 5.468] (II) Using input driver 'libinput' for 'CM Storm Keyboard -- QuickFire XT System Control'
[ 5.468] (**) CM Storm Keyboard -- QuickFire XT System Control: always reports core events
[ 5.468] (**) Option "Device" "/dev/input/event6"
[ 5.468] (**) Option "_source" "server/udev"
[ 5.473] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: is tagged by udev as: Keyboard
[ 5.473] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: device is a keyboard
[ 5.474] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: device removed
[ 5.506] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:2516:001A.0002/input/input6/event6"
[ 5.507] (II) XINPUT: Adding extended input device "CM Storm Keyboard -- QuickFire XT System Control" (type: KEYBOARD, id 14)
[ 5.507] (**) Option "xkb_model" "pc105"
[ 5.507] (**) Option "xkb_layout" "pl"
[ 5.512] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: is tagged by udev as: Keyboard
[ 5.512] (II) event6 - CM Storm Keyboard -- QuickFire XT System Control: device is a keyboard
[ 5.513] (II) config/udev: removing device CM Storm Keyboard -- QuickFire XT
[ 5.513] (II) event4 - CM Storm Keyboard -- QuickFire XT: device removed
[ 5.546] (II) UnloadModule: "libinput"
[ 5.548] (II) config/udev: Adding input device CM Storm Keyboard -- QuickFire XT (/dev/input/event4)
[ 5.548] (**) CM Storm Keyboard -- QuickFire XT: Applying InputClass "evdev keyboard catchall"
[ 5.548] (**) CM Storm Keyboard -- QuickFire XT: Applying InputClass "libinput keyboard catchall"
[ 5.548] (**) CM Storm Keyboard -- QuickFire XT: Applying InputClass "system-keyboard"
[ 5.548] (II) Using input driver 'libinput' for 'CM Storm Keyboard -- QuickFire XT'
[ 5.548] (**) CM Storm Keyboard -- QuickFire XT: always reports core events
[ 5.548] (**) Option "Device" "/dev/input/event4"
[ 5.548] (**) Option "_source" "server/udev"
[ 5.553] (II) event4 - CM Storm Keyboard -- QuickFire XT: is tagged by udev as: Keyboard
[ 5.553] (II) event4 - CM Storm Keyboard -- QuickFire XT: device is a keyboard
[ 5.554] (II) event4 - CM Storm Keyboard -- QuickFire XT: device removed
[ 5.586] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:2516:001A.0001/input/input4/event4"
[ 5.587] (II) XINPUT: Adding extended input device "CM Storm Keyboard -- QuickFire XT" (type: KEYBOARD, id 12)
[ 5.587] (**) Option "xkb_model" "pc105"
[ 5.587] (**) Option "xkb_layout" "pl"
[ 5.592] (II) event4 - CM Storm Keyboard -- QuickFire XT: is tagged by udev as: Keyboard
[ 5.592] (II) event4 - CM Storm Keyboard -- QuickFire XT: device is a keyboard
[ 5.593] (II) config/udev: removing device CM Storm Keyboard -- QuickFire XT Consumer Control
[ 5.593] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: device removed
[ 5.640] (II) UnloadModule: "libinput"
[ 5.641] (II) config/udev: Adding input device CM Storm Keyboard -- QuickFire XT Consumer Control (/dev/input/event5)
[ 5.641] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 5.641] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 5.641] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: Applying InputClass "system-keyboard"
[ 5.641] (II) Using input driver 'libinput' for 'CM Storm Keyboard -- QuickFire XT Consumer Control'
[ 5.641] (**) CM Storm Keyboard -- QuickFire XT Consumer Control: always reports core events
[ 5.641] (**) Option "Device" "/dev/input/event5"
[ 5.641] (**) Option "_source" "server/udev"
[ 5.646] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: is tagged by udev as: Keyboard
[ 5.647] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: device is a keyboard
[ 5.647] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: device removed
[ 5.706] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:2516:001A.0002/input/input5/event5"
[ 5.706] (II) XINPUT: Adding extended input device "CM Storm Keyboard -- QuickFire XT Consumer Control" (type: KEYBOARD, id 13)
[ 5.706] (**) Option "xkb_model" "pc105"
[ 5.707] (**) Option "xkb_layout" "pl"
[ 5.712] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: is tagged by udev as: Keyboard
[ 5.712] (II) event5 - CM Storm Keyboard -- QuickFire XT Consumer Control: device is a keyboard
[ 5.713] (EE) Failed to open authorization file "/var/run/sddm/{802da3e9-2146-4e26-9d77-966140a92ae6}": No such file or directory
[ 5.714] (II) config/udev: removing device SINOWEALTH Game Mouse Keyboard
[ 5.714] (II) event8 - SINOWEALTH Game Mouse Keyboard: device removed
[ 5.733] (II) UnloadModule: "libinput"
[ 5.735] (II) config/udev: Adding input device SINOWEALTH Game Mouse Keyboard (/dev/input/event8)
[ 5.735] (**) SINOWEALTH Game Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 5.735] (**) SINOWEALTH Game Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 5.735] (**) SINOWEALTH Game Mouse Keyboard: Applying InputClass "system-keyboard"
[ 5.735] (II) Using input driver 'libinput' for 'SINOWEALTH Game Mouse Keyboard'
[ 5.735] (**) SINOWEALTH Game Mouse Keyboard: always reports core events
[ 5.735] (**) Option "Device" "/dev/input/event8"
[ 5.735] (**) Option "_source" "server/udev"
[ 5.739] (II) event8 - SINOWEALTH Game Mouse Keyboard: is tagged by udev as: Keyboard
[ 5.740] (II) event8 - SINOWEALTH Game Mouse Keyboard: device is a keyboard
[ 5.741] (II) event8 - SINOWEALTH Game Mouse Keyboard: device removed
[ 5.773] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-14/1-14:1.1/0003:258A:0017.0004/input/input8/event8"
[ 5.773] (II) XINPUT: Adding extended input device "SINOWEALTH Game Mouse Keyboard" (type: KEYBOARD, id 11)
[ 5.773] (**) Option "xkb_model" "pc105"
[ 5.773] (**) Option "xkb_layout" "pl"
[ 5.778] (II) event8 - SINOWEALTH Game Mouse Keyboard: is tagged by udev as: Keyboard
[ 5.779] (II) event8 - SINOWEALTH Game Mouse Keyboard: device is a keyboard
[ 5.780] (II) config/udev: removing device SINOWEALTH Game Mouse
[ 5.780] (II) event7 - SINOWEALTH Game Mouse: device removed
[ 5.840] (II) UnloadModule: "libinput"
[ 5.841] (II) config/udev: Adding input device SINOWEALTH Game Mouse (/dev/input/event7)
[ 5.841] (**) SINOWEALTH Game Mouse: Applying InputClass "evdev pointer catchall"
[ 5.841] (**) SINOWEALTH Game Mouse: Applying InputClass "libinput pointer catchall"
[ 5.841] (II) Using input driver 'libinput' for 'SINOWEALTH Game Mouse'
[ 5.841] (**) SINOWEALTH Game Mouse: always reports core events
[ 5.841] (**) Option "Device" "/dev/input/event7"
[ 5.841] (**) Option "_source" "server/udev"
[ 5.901] (II) event7 - SINOWEALTH Game Mouse: is tagged by udev as: Mouse
[ 5.901] (II) event7 - SINOWEALTH Game Mouse: device is a pointer
[ 5.902] (II) event7 - SINOWEALTH Game Mouse: device removed
[ 5.960] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-14/1-14:1.0/0003:258A:0017.0003/input/input7/event7"
[ 5.960] (II) XINPUT: Adding extended input device "SINOWEALTH Game Mouse" (type: MOUSE, id 10)
[ 5.960] (**) Option "AccelerationScheme" "none"
[ 5.960] (**) SINOWEALTH Game Mouse: (accel) selected scheme none/0
[ 5.960] (**) SINOWEALTH Game Mouse: (accel) acceleration factor: 2.000
[ 5.960] (**) SINOWEALTH Game Mouse: (accel) acceleration threshold: 4
[ 6.021] (II) event7 - SINOWEALTH Game Mouse: is tagged by udev as: Mouse
[ 6.021] (II) event7 - SINOWEALTH Game Mouse: device is a pointer
[ 11.577] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): connected
[ 11.577] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): 400.0 MHz maximum pixel clock
[ 11.666] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 11.666] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 11.666] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 11.666] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 11.666] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 11.666] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 11.667] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): connected
[ 11.667] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): Internal DisplayPort
[ 11.667] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): 960.0 MHz maximum pixel clock
[ 11.668] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 11.668] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 11.668] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 11.668] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 11.668] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 11.668] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 11.763] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): connected
[ 11.763] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): 400.0 MHz maximum pixel clock
[ 11.852] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 11.852] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 11.852] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 11.852] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 11.852] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 11.852] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 11.853] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): connected
[ 11.853] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): Internal DisplayPort
[ 11.853] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): 960.0 MHz maximum pixel clock
[ 11.854] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 11.854] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 11.854] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 11.854] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 11.854] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 11.854] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 11.868] (II) event7 - SINOWEALTH Game Mouse: SYN_DROPPED event - some input events have been lost.
[ 12.665] (EE) event7 - SINOWEALTH Game Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 12.792] (II) event7 - SINOWEALTH Game Mouse: SYN_DROPPED event - some input events have been lost.
[ 13.069] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): connected
[ 13.069] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): 400.0 MHz maximum pixel clock
[ 13.158] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 13.158] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 13.158] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 13.158] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 13.158] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 13.158] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 13.159] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): connected
[ 13.159] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): Internal DisplayPort
[ 13.159] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): 960.0 MHz maximum pixel clock
[ 13.160] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 13.160] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 13.160] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 13.160] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 13.160] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 13.160] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 13.255] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): connected
[ 13.255] (--) NVIDIA(GPU-0): WYT MNT-ANALOG (CRT-0): 400.0 MHz maximum pixel clock
[ 13.332] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 13.332] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 13.332] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 13.332] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 13.332] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 13.332] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 13.332] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): connected
[ 13.332] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): Internal DisplayPort
[ 13.332] (--) NVIDIA(GPU-0): Acer Z271 T (DFP-2): 960.0 MHz maximum pixel clock
[ 13.334] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 13.334] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 13.334] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 13.334] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 13.334] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 13.334] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 13.345] (II) event7 - SINOWEALTH Game Mouse: SYN_DROPPED event - some input events have been lost.
[ 13.372] (EE) event7 - SINOWEALTH Game Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 13.479] (II) NVIDIA(0): Setting mode "DP-0: 1920x1080_144 @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DVI-I-0: nvidia-auto-select @1280x1024 +1920+0 {ViewPortIn=1280x1024, ViewPortOut=1280x1024+0+0}"
[ 15.385] (EE) event7 - SINOWEALTH Game Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 15.627] (EE) event7 - SINOWEALTH Game Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 652.243] (EE) event7 - SINOWEALTH Game Mouse: client bug: event processing lagging behind by 25ms, your system is too slow
