Nvidia P2000 installation
I recieved a new workstation which besides the Intel 630 is equipped with Nvidia Quadro P2000.
When I first booted the system I didn't have the time to install it properly so I removed it and used the Intel graphics.
Just this morning I decided to see if the fuzz on Nvidia has a merit.
The free driver don't work with this card - I got a bunch of errors on the monitors.
I rebooted using a ventoy USB and a Manjaro ISO.
Chrooted into the system and used mhwd to install the proprietary drivers.
mhwd -i pci video-nvidia-440xx
Rebooted the system - and what a pleasant surprise - it worked without hitches.
I had the trivial taskto adjust the location of the monitors by swapping the cables - and edit my polybar to display on the correct monitor.
➜  ~ inxi -G
  Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
  Device-2: NVIDIA GP106GL [Quadro P2000] driver: nvidia v: 440.82
  Display: x11 server: X.Org 1.20.8 driver: nvidia
  resolution: 1920x1080~60Hz, 1920x1080~60Hz
  OpenGL: renderer: Quadro P2000/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82
I still have to see what happens on updates - but for now :+1:
I did not have any problems with NVIDA updates, once you configured it it stays as it was.
