Please post the most recent Xorg log file again.
/var/log/Xorg.0.log
[ 6.771] (--) Log file renamed from "/var/log/Xorg.pid-1014.log" to "/var/log/Xorg.0.log"
[ 6.773]
X.Org X Server 1.20.9
[ 6.773] Build Operating System: Linux Manjaro Linux
[ 6.773] Current Operating System: Linux eduardolac-pc 5.4.67-1-MANJARO #1 SMP PREEMPT Wed Sep 23 14:20:18 UTC 2020 x86_64
[ 6.773] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=7abcb41b-d995-4a47-a321-516698868208 rw quiet apparmor=1 security=apparmor resume=UUID=86ff1135-7def-48a4-8a4c-69c0e1b70056 udev.log_priority=3
[ 6.773] Build Date: 02 September 2020 07:39:17AM
[ 6.773]
[ 6.773] Current version of pixman: 0.40.0
[ 6.773] Before reporting problems, check http://wiki.x.org
[ 6.773] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.773] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Oct 3 16:37:04 2020
[ 6.777] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.777] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.778] (==) ServerLayout "layout"
[ 6.778] (**) |-->Screen "intel" (0)
[ 6.778] (**) | |-->Monitor "<default monitor>"
[ 6.779] (**) | |-->Device "intel"
[ 6.779] (**) | |-->GPUDevice "intel"
[ 6.779] (**) | |-->GPUDevice "nvidia"
[ 6.779] (==) No monitor specified for screen "intel".
[ 6.779] (==) Automatically adding devices
[ 6.779] (==) Automatically enabling devices
[ 6.779] (==) Automatically adding GPU devices
[ 6.779] (==) Automatically binding GPU devices
[ 6.779] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.781] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 6.781] Entry deleted from font path.
[ 6.781] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.782] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 6.782] Entry deleted from font path.
[ 6.782] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 6.782] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 6.782] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 6.782] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 6.782] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.782] (II) The server relies on udev to provide the list of input devices.
[ 6.782] (II) Module ABI versions:
[ 6.782] X.Org ANSI C Emulation: 0.4
[ 6.782] X.Org Video Driver: 24.1
[ 6.782] X.Org XInput driver : 24.1
[ 6.782] X.Org Server Extension : 10.0
[ 6.783] (++) using VT number 1
[ 6.783] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.783] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.783] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 6.803] (--) PCI:*(0@0:2:0) 8086:3ea0:17aa:3f19 rev 2, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 6.803] (--) PCI: (1@0:0:0) 10de:174e:17aa:3f19 rev 162, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00003000/128
[ 6.803] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.803] (II) LoadModule: "glx"
[ 6.805] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.813] (II) Module glx: vendor="X.Org Foundation"
[ 6.813] compiled for 1.20.9, module version = 1.0.0
[ 6.813] ABI class: X.Org Server Extension, version 10.0
[ 6.813] (II) LoadModule: "modesetting"
[ 6.813] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 6.816] (II) Module modesetting: vendor="X.Org Foundation"
[ 6.816] compiled for 1.20.9, module version = 1.20.9
[ 6.816] Module class: X.Org Video Driver
[ 6.816] ABI class: X.Org Video Driver, version 24.1
[ 6.816] (II) LoadModule: "nvidia"
[ 6.816] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 6.819] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 6.819] compiled for 1.6.99.901, module version = 1.0.0
[ 6.819] Module class: X.Org Video Driver
[ 6.820] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 6.820] (II) NVIDIA dlloader X Driver 450.66 Wed Aug 12 19:44:12 UTC 2020
[ 6.820] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 6.834] (II) modeset(0): using drv /dev/dri/card0
[ 6.834] (WW) Falling back to old probe method for modesetting
[ 6.851] (II) Loading sub module "fb"
[ 6.851] (II) LoadModule: "fb"
[ 6.851] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 6.852] (II) Module fb: vendor="X.Org Foundation"
[ 6.852] compiled for 1.20.9, module version = 1.0.0
[ 6.852] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.852] (II) Loading sub module "wfb"
[ 6.852] (II) LoadModule: "wfb"
[ 6.852] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 6.853] (II) Module wfb: vendor="X.Org Foundation"
[ 6.853] compiled for 1.20.9, module version = 1.0.0
[ 6.853] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.853] (II) Loading sub module "ramdac"
[ 6.853] (II) LoadModule: "ramdac"
[ 6.853] (II) Module "ramdac" already built-in
[ 7.193] (EE) Screen 1 deleted because of no matching config section.
[ 7.193] (II) UnloadModule: "nvidia"
[ 7.193] (II) UnloadSubModule: "wfb"
[ 7.193] (II) UnloadSubModule: "fb"
[ 7.193] (II) modeset(0): Creating default Display subsection in Screen section
"intel" for depth/fbbpp 24/32
[ 7.193] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 7.193] (==) modeset(0): RGB weight 888
[ 7.193] (==) modeset(0): Default visual is TrueColor
[ 7.193] (II) Loading sub module "glamoregl"
[ 7.193] (II) LoadModule: "glamoregl"
[ 7.193] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 7.201] (II) Module glamoregl: vendor="X.Org Foundation"
[ 7.201] compiled for 1.20.9, module version = 1.0.1
[ 7.201] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.478] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 620 (WHL GT2)
[ 7.478] (II) modeset(0): glamor initialized
[ 7.479] (II) modeset(0): Output eDP-1 has no monitor section
[ 7.494] (II) modeset(0): Output HDMI-1 has no monitor section
[ 7.495] (II) modeset(0): EDID for output eDP-1
[ 7.495] (II) modeset(0): Manufacturer: AUO Model: 61ed Serial#: 0
[ 7.495] (II) modeset(0): Year: 2018 Week: 0
[ 7.495] (II) modeset(0): EDID Version: 1.4
[ 7.495] (II) modeset(0): Digital Display Input
[ 7.495] (II) modeset(0): 8 bits per channel
[ 7.495] (II) modeset(0): Digital interface is DisplayPort
[ 7.495] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 7.495] (II) modeset(0): Gamma: 2.20
[ 7.496] (II) modeset(0): No DPMS capabilities specified
[ 7.496] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 7.496] (II) modeset(0): First detailed timing is preferred mode
[ 7.496] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 7.496] (II) modeset(0): Display is continuous-frequency
[ 7.496] (II) modeset(0): redX: 0.573 redY: 0.343 greenX: 0.351 greenY: 0.569
[ 7.496] (II) modeset(0): blueX: 0.163 blueY: 0.131 whiteX: 0.313 whiteY: 0.329
[ 7.496] (II) modeset(0): Manufacturer's mask: 0
[ 7.496] (II) modeset(0): Supported detailed timing:
[ 7.496] (II) modeset(0): clock: 141.0 MHz Image Size: 344 x 194 mm
[ 7.496] (II) modeset(0): h_active: 1920 h_sync: 2028 h_sync_end 2076 h_blank_end 2100 h_border: 0
[ 7.496] (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1118 v_border: 0
[ 7.496] (II) modeset(0): Unknown vendor-specific block f
[ 7.496] (II) modeset(0): AUO
[ 7.496] (II) modeset(0): B156HTN06.1
[ 7.496] (II) modeset(0): EDID (in hex):
[ 7.496] (II) modeset(0): 00ffffffffffff0006afed6100000000
[ 7.496] (II) modeset(0): 001c0104a522137803ffe59257599129
[ 7.496] (II) modeset(0): 21505400000001010101010101010101
[ 7.496] (II) modeset(0): 010101010101143780b4703826406c30
[ 7.496] (II) modeset(0): aa0058c2100000180000000f00000000
[ 7.496] (II) modeset(0): 00000000000000000020000000fe0041
[ 7.496] (II) modeset(0): 554f0a202020202020202020000000fe
[ 7.496] (II) modeset(0): 004231353648544e30362e31200a00d2
[ 7.496] (II) modeset(0): Printing probed modes for output eDP-1
[ 7.496] (II) modeset(0): Modeline "1920x1080"x60.1 141.00 1920 2028 2076 2100 1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[ 7.496] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 7.496] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 7.496] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 7.496] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 7.496] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 7.496] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 7.496] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 7.496] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 7.496] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 7.496] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 7.496] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 7.496] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 7.496] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 7.496] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 7.496] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 7.496] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 7.496] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 7.496] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 7.496] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 7.496] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 7.496] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 7.496] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 7.496] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 7.496] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 7.496] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 7.496] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 7.496] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 7.497] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 7.497] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.497] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 7.497] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.497] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 7.497] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 7.497] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 7.497] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 7.497] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 7.497] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 7.497] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 7.497] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 7.497] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 7.497] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 7.497] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 7.497] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 7.497] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 7.497] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 7.497] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 7.497] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 7.497] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 7.497] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 7.497] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 7.497] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 7.512] (II) modeset(0): EDID for output HDMI-1
[ 7.512] (II) modeset(0): Manufacturer: SAM Model: 3e1 Serial#: 1415000377
[ 7.512] (II) modeset(0): Year: 2009 Week: 7
[ 7.512] (II) modeset(0): EDID Version: 1.3
[ 7.512] (II) modeset(0): Digital Display Input
[ 7.512] (II) modeset(0): Max Image Size [cm]: horiz.: 41 vert.: 26
[ 7.512] (II) modeset(0): Gamma: 2.35
[ 7.512] (II) modeset(0): DPMS capabilities: Off
[ 7.512] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 7.512] (II) modeset(0): First detailed timing is preferred mode
[ 7.512] (II) modeset(0): redX: 0.640 redY: 0.329 greenX: 0.300 greenY: 0.600
[ 7.512] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 7.512] (II) modeset(0): Supported established timings:
[ 7.512] (II) modeset(0): 720x400@70Hz
[ 7.512] (II) modeset(0): 640x480@60Hz
[ 7.512] (II) modeset(0): 640x480@67Hz
[ 7.512] (II) modeset(0): 640x480@72Hz
[ 7.512] (II) modeset(0): 640x480@75Hz
[ 7.512] (II) modeset(0): 800x600@56Hz
[ 7.512] (II) modeset(0): 800x600@60Hz
[ 7.512] (II) modeset(0): 800x600@72Hz
[ 7.512] (II) modeset(0): 800x600@75Hz
[ 7.512] (II) modeset(0): 832x624@75Hz
[ 7.512] (II) modeset(0): 1024x768@60Hz
[ 7.512] (II) modeset(0): 1024x768@70Hz
[ 7.512] (II) modeset(0): 1024x768@75Hz
[ 7.512] (II) modeset(0): 1280x1024@75Hz
[ 7.512] (II) modeset(0): 1152x864@75Hz
[ 7.512] (II) modeset(0): Manufacturer's mask: 0
[ 7.512] (II) modeset(0): Supported standard timings:
[ 7.512] (II) modeset(0): #0: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 7.512] (II) modeset(0): #1: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 7.512] (II) modeset(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 7.512] (II) modeset(0): #3: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 7.512] (II) modeset(0): #4: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 7.512] (II) modeset(0): Supported detailed timing:
[ 7.512] (II) modeset(0): clock: 106.5 MHz Image Size: 410 x 257 mm
[ 7.512] (II) modeset(0): h_active: 1440 h_sync: 1520 h_sync_end 1672 h_blank_end 1904 h_border: 0
[ 7.512] (II) modeset(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 934 v_border: 0
[ 7.512] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 81 kHz, PixClock max 145 MHz
[ 7.512] (II) modeset(0): Monitor name: SyncMaster
[ 7.512] (II) modeset(0): Serial No: HQAS200940
[ 7.512] (II) modeset(0): EDID (in hex):
[ 7.512] (II) modeset(0): 00ffffffffffff004c2de10339315754
[ 7.512] (II) modeset(0): 0713010380291a872ade95a3544c9926
[ 7.512] (II) modeset(0): 0f5054bfef809500950f81808140714f
[ 7.512] (II) modeset(0): 0101010101019a29a0d0518422305098
[ 7.512] (II) modeset(0): 36009a011100001c000000fd00384b1e
[ 7.512] (II) modeset(0): 510e000a202020202020000000fc0053
[ 7.512] (II) modeset(0): 796e634d61737465720a2020000000ff
[ 7.512] (II) modeset(0): 00485141533230303934300a202000f0
[ 7.512] (II) modeset(0): Printing probed modes for output HDMI-1
[ 7.512] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz eP)
[ 7.512] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 7.512] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 7.512] (II) modeset(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 7.512] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 7.512] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 7.512] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 7.512] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 7.512] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 7.512] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 7.512] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 7.512] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 7.512] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 7.512] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 7.512] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 7.512] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 7.512] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 7.512] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 7.512] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 7.512] (II) modeset(0): Output eDP-1 connected
[ 7.512] (II) modeset(0): Output HDMI-1 connected
[ 7.512] (II) modeset(0): Using spanning desktop for initial modes
[ 7.512] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 7.512] (II) modeset(0): Output HDMI-1 using initial mode 1440x900 +1920+0
[ 7.512] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.512] (==) modeset(0): DPI set to (96, 96)
[ 7.512] (II) Loading sub module "fb"
[ 7.512] (II) LoadModule: "fb"
[ 7.513] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.513] (II) Module fb: vendor="X.Org Foundation"
[ 7.513] compiled for 1.20.9, module version = 1.0.0
[ 7.513] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.532] (==) modeset(0): Backing store enabled
[ 7.532] (==) modeset(0): Silken mouse disabled
[ 7.706] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 7.707] (==) modeset(0): DPMS enabled
[ 7.707] (WW) modeset(0): Option "DRI" is not used
[ 7.707] (II) modeset(0): [DRI2] Setup complete
[ 7.707] (II) modeset(0): [DRI2] DRI driver: iris
[ 7.707] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 7.707] (II) Initializing extension Generic Event Extension
[ 7.707] (II) Initializing extension SHAPE
[ 7.707] (II) Initializing extension MIT-SHM
[ 7.707] (II) Initializing extension XInputExtension
[ 7.708] (II) Initializing extension XTEST
[ 7.708] (II) Initializing extension BIG-REQUESTS
[ 7.708] (II) Initializing extension SYNC
[ 7.708] (II) Initializing extension XKEYBOARD
[ 7.709] (II) Initializing extension XC-MISC
[ 7.709] (II) Initializing extension SECURITY
[ 7.710] (II) Initializing extension XFIXES
[ 7.710] (II) Initializing extension RENDER
[ 7.710] (II) Initializing extension RANDR
[ 7.710] (II) Initializing extension COMPOSITE
[ 7.710] (II) Initializing extension DAMAGE
[ 7.711] (II) Initializing extension MIT-SCREEN-SAVER
[ 7.711] (II) Initializing extension DOUBLE-BUFFER
[ 7.711] (II) Initializing extension RECORD
[ 7.711] (II) Initializing extension DPMS
[ 7.711] (II) Initializing extension Present
[ 7.712] (II) Initializing extension DRI3
[ 7.712] (II) Initializing extension X-Resource
[ 7.712] (II) Initializing extension XVideo
[ 7.712] (II) Initializing extension XVideo-MotionCompensation
[ 7.712] (II) Initializing extension GLX
[ 7.729] (II) AIGLX: Loaded and initialized iris
[ 7.729] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 7.729] (II) Initializing extension XFree86-VidModeExtension
[ 7.729] (II) Initializing extension XFree86-DGA
[ 7.729] (II) Initializing extension XFree86-DRI
[ 7.729] (II) Initializing extension DRI2
[ 7.735] (II) modeset(0): Damage tracking initialized
[ 7.735] (II) modeset(0): Setting screen physical size to 889 x 285
[ 7.804] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 7.804] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.804] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.804] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.804] (II) LoadModule: "libinput"
[ 7.805] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.809] (II) Module libinput: vendor="X.Org Foundation"
[ 7.809] compiled for 1.20.8, module version = 0.30.0
[ 7.809] Module class: X.Org XInput Driver
[ 7.809] ABI class: X.Org XInput driver, version 24.1
[ 7.809] (II) Using input driver 'libinput' for 'Power Button'
[ 7.809] (**) Power Button: always reports core events
[ 7.809] (**) Option "Device" "/dev/input/event2"
[ 7.809] (**) Option "_source" "server/udev"
[ 7.819] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.819] (II) event2 - Power Button: device is a keyboard
[ 7.819] (II) event2 - Power Button: device removed
[ 7.847] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 7.847] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.847] (**) Option "xkb_model" "pc105"
[ 7.847] (**) Option "xkb_layout" "br"
[ 7.883] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.883] (II) event2 - Power Button: device is a keyboard
[ 7.884] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[ 7.884] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 7.884] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.884] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.884] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.884] (**) Video Bus: always reports core events
[ 7.884] (**) Option "Device" "/dev/input/event11"
[ 7.884] (**) Option "_source" "server/udev"
[ 7.885] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 7.885] (II) event11 - Video Bus: device is a keyboard
[ 7.885] (II) event11 - Video Bus: device removed
[ 7.980] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13/event11"
[ 7.980] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 7.980] (**) Option "xkb_model" "pc105"
[ 7.980] (**) Option "xkb_layout" "br"
[ 7.982] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 7.982] (II) event11 - Video Bus: device is a keyboard
[ 7.983] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 7.983] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 7.983] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.983] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.983] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.983] (**) Video Bus: always reports core events
[ 7.983] (**) Option "Device" "/dev/input/event12"
[ 7.983] (**) Option "_source" "server/udev"
[ 7.985] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 7.985] (II) event12 - Video Bus: device is a keyboard
[ 7.985] (II) event12 - Video Bus: device removed
[ 8.060] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:40/LNXVIDEO:01/input/input14/event12"
[ 8.060] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 8.060] (**) Option "xkb_model" "pc105"
[ 8.060] (**) Option "xkb_layout" "br"
[ 8.062] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 8.062] (II) event12 - Video Bus: device is a keyboard
[ 8.063] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 8.063] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 8.063] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 8.063] (**) Power Button: Applying InputClass "system-keyboard"
[ 8.063] (II) Using input driver 'libinput' for 'Power Button'
[ 8.063] (**) Power Button: always reports core events
[ 8.063] (**) Option "Device" "/dev/input/event1"
[ 8.063] (**) Option "_source" "server/udev"
[ 8.065] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 8.065] (II) event1 - Power Button: device is a keyboard
[ 8.065] (II) event1 - Power Button: device removed
[ 8.086] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 8.086] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 8.086] (**) Option "xkb_model" "pc105"
[ 8.087] (**) Option "xkb_layout" "br"
[ 8.088] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 8.088] (II) event1 - Power Button: device is a keyboard
[ 8.089] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 8.089] (II) No input driver specified, ignoring this device.
[ 8.089] (II) This device may have been added with another device file.
[ 8.091] (II) config/udev: Adding input device Logitech Wireless Keyboard PID:4023 (/dev/input/event5)
[ 8.091] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[ 8.091] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 8.091] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[ 8.091] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 8.091] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 8.091] (**) Option "Device" "/dev/input/event5"
[ 8.091] (**) Option "_source" "server/udev"
[ 8.093] (II) event5 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 8.093] (II) event5 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 8.094] (II) event5 - Logitech Wireless Keyboard PID:4023: device removed
[ 8.140] (II) libinput: Logitech Wireless Keyboard PID:4023: needs a virtual subdevice
[ 8.140] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input34/event5"
[ 8.140] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: MOUSE, id 10)
[ 8.140] (**) Option "AccelerationScheme" "none"
[ 8.140] (**) Logitech Wireless Keyboard PID:4023: (accel) selected scheme none/0
[ 8.140] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration factor: 2.000
[ 8.140] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration threshold: 4
[ 8.143] (II) event5 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 8.143] (II) event5 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 8.145] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event6)
[ 8.145] (**) Logitech Wireless Mouse: Applying InputClass "evdev pointer catchall"
[ 8.145] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 8.145] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[ 8.145] (**) Logitech Wireless Mouse: always reports core events
[ 8.145] (**) Option "Device" "/dev/input/event6"
[ 8.145] (**) Option "_source" "server/udev"
[ 8.148] (II) event6 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 8.148] (II) event6 - Logitech Wireless Mouse: device is a pointer
[ 8.148] (II) event6 - Logitech Wireless Mouse: device removed
[ 8.207] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input35/event6"
[ 8.207] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 11)
[ 8.207] (**) Option "AccelerationScheme" "none"
[ 8.207] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[ 8.207] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[ 8.207] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[ 8.210] (II) event6 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 8.210] (II) event6 - Logitech Wireless Mouse: device is a pointer
[ 8.212] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse0)
[ 8.212] (II) No input driver specified, ignoring this device.
[ 8.212] (II) This device may have been added with another device file.
[ 8.213] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event4)
[ 8.213] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[ 8.213] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 8.213] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[ 8.213] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[ 8.213] (**) Integrated Camera: Integrated C: always reports core events
[ 8.213] (**) Option "Device" "/dev/input/event4"
[ 8.213] (**) Option "_source" "server/udev"
[ 8.215] (II) event4 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 8.215] (II) event4 - Integrated Camera: Integrated C: device is a keyboard
[ 8.216] (II) event4 - Integrated Camera: Integrated C: device removed
[ 8.300] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/input/input22/event4"
[ 8.300] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 12)
[ 8.300] (**) Option "xkb_model" "pc105"
[ 8.300] (**) Option "xkb_layout" "br"
[ 8.303] (II) event4 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 8.303] (II) event4 - Integrated Camera: Integrated C: device is a keyboard
[ 8.304] (II) config/udev: Adding input device Elan Touchpad (/dev/input/event10)
[ 8.304] (**) Elan Touchpad: Applying InputClass "evdev touchpad catchall"
[ 8.304] (**) Elan Touchpad: Applying InputClass "libinput touchpad catchall"
[ 8.304] (II) Using input driver 'libinput' for 'Elan Touchpad'
[ 8.304] (**) Elan Touchpad: always reports core events
[ 8.304] (**) Option "Device" "/dev/input/event10"
[ 8.304] (**) Option "_source" "server/udev"
[ 8.306] (II) event10 - Elan Touchpad: is tagged by udev as: Touchpad
[ 8.309] (II) event10 - Elan Touchpad: device is a touchpad
[ 8.309] (II) event10 - Elan Touchpad: device removed
[ 8.381] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN0629:00/input/input12/event10"
[ 8.381] (II) XINPUT: Adding extended input device "Elan Touchpad" (type: TOUCHPAD, id 13)
[ 8.383] (**) Option "AccelerationScheme" "none"
[ 8.383] (**) Elan Touchpad: (accel) selected scheme none/0
[ 8.383] (**) Elan Touchpad: (accel) acceleration factor: 2.000
[ 8.383] (**) Elan Touchpad: (accel) acceleration threshold: 4
[ 8.385] (II) event10 - Elan Touchpad: is tagged by udev as: Touchpad
[ 8.388] (II) event10 - Elan Touchpad: device is a touchpad
[ 8.389] (II) config/udev: Adding input device Elan Touchpad (/dev/input/mouse1)
[ 8.389] (II) No input driver specified, ignoring this device.
[ 8.389] (II) This device may have been added with another device file.
[ 8.390] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event8)
[ 8.390] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[ 8.390] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 8.390] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[ 8.390] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 8.390] (**) Ideapad extra buttons: always reports core events
[ 8.390] (**) Option "Device" "/dev/input/event8"
[ 8.390] (**) Option "_source" "server/udev"
[ 8.392] (II) event8 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 8.392] (II) event8 - Ideapad extra buttons: device is a keyboard
[ 8.392] (II) event8 - Ideapad extra buttons: device removed
[ 8.447] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input10/event8"
[ 8.447] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 14)
[ 8.447] (**) Option "xkb_model" "pc105"
[ 8.447] (**) Option "xkb_layout" "br"
[ 8.449] (II) event8 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 8.449] (II) event8 - Ideapad extra buttons: device is a keyboard
[ 8.450] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[ 8.450] (II) No input driver specified, ignoring this device.
[ 8.450] (II) This device may have been added with another device file.
[ 8.450] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[ 8.451] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
[ 8.451] (II) No input driver specified, ignoring this device.
[ 8.451] (II) This device may have been added with another device file.
[ 8.451] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event16)
[ 8.452] (II) No input driver specified, ignoring this device.
[ 8.452] (II) This device may have been added with another device file.
[ 8.452] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event17)
[ 8.453] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event18)
[ 8.453] (II) No input driver specified, ignoring this device.
[ 8.453] (II) This device may have been added with another device file.
[ 8.453] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event19)
[ 8.454] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 8.454] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.454] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.454] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 8.454] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 8.454] (**) AT Translated Set 2 keyboard: always reports core events
[ 8.454] (**) Option "Device" "/dev/input/event3"
[ 8.454] (**) Option "_source" "server/udev"
[ 8.456] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.456] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.458] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 8.487] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 8.487] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
[ 8.487] (**) Option "xkb_model" "pc105"
[ 8.487] (**) Option "xkb_layout" "br"
[ 8.489] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.489] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.491] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 8.492] (II) No input driver specified, ignoring this device.
[ 8.492] (II) This device may have been added with another device file.
[ 8.508] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[ 8.508] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 8.508] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[ 8.508] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 8.508] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 8.508] (**) Option "Device" "/dev/input/event5"
[ 8.508] (**) Option "_source" "_driver/libinput"
[ 8.508] (II) libinput: Logitech Wireless Keyboard PID:4023: is a virtual subdevice
[ 8.508] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input34/event5"
[ 8.509] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: KEYBOARD, id 16)
[ 8.509] (**) Option "xkb_model" "pc105"
[ 8.509] (**) Option "xkb_layout" "br"
[ 8.609] (EE) Failed to open authorization file "/var/run/sddm/{70c1339e-9864-4354-abd6-18303d98942c}": No such file or directory
[ 98.798] (II) modeset(0): EDID vendor "SAM", prod id 993
[ 98.798] (II) modeset(0): Using EDID range info for horizontal sync
[ 98.798] (II) modeset(0): Using EDID range info for vertical refresh
[ 98.798] (II) modeset(0): Printing DDC gathered Modelines:
[ 98.798] (II) modeset(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz eP)
[ 98.798] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 98.798] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 98.798] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 98.798] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 98.798] (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 98.798] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 98.798] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 98.798] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 98.798] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 98.798] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 98.798] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 98.798] (II) modeset(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 98.798] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 98.798] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 98.798] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 98.798] (II) modeset(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 98.798] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 98.798] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 99.634] (II) modeset(0): EDID vendor "SAM", prod id 993
[ 99.634] (II) modeset(0): Using hsync ranges from config file
[ 99.634] (II) modeset(0): Using vrefresh ranges from config file
[ 99.634] (II) modeset(0): Printing DDC gathered Modelines:
[ 99.634] (II) modeset(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz eP)
[ 99.634] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 99.634] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 99.634] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 99.634] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 99.634] (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 99.634] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 99.634] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 99.634] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 99.634] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 99.634] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 99.634] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 99.634] (II) modeset(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 99.634] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 99.634] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 99.634] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 99.634] (II) modeset(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 99.634] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 99.634] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 131.131] (EE) event6 - Logitech Wireless Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 196.784] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[ 202.689] (II) modeset(0): EDID vendor "AUO", prod id 25069
[ 202.689] (II) modeset(0): Printing DDC gathered Modelines:
[ 202.689] (II) modeset(0): Modeline "1920x1080"x0.0 141.00 1920 2028 2076 2100 1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[ 203.433] (II) modeset(0): Allocate new frame buffer 3360x1080 stride
[ 260.688] (EE) event5 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 28ms, your system is too slow
[ 517.281] (EE) event6 - Logitech Wireless Mouse: client bug: event processing lagging behind by 15ms, your system is too slow
[ 610.493] (EE) event5 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 26ms, your system is too slow
[ 686.938] (EE) event5 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 28ms, your system is too slow
[ 1102.276] (EE) event6 - Logitech Wireless Mouse: client bug: event processing lagging behind by 18ms, your system is too slow
[ 1108.972] (EE) event6 - Logitech Wireless Mouse: client bug: event processing lagging behind by 16ms, your system is too slow
[ 1330.367] (EE) event5 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 27ms, your system is too slow
Unfortunately the same thing. Do you have any Xorg configuration apart from 10-prime-offload.conf? (Please upload /etc/X11/xorg.conf and every file in /etc/X11/xorg.conf.d/ [except for 10-prime-offload.conf].) Please also post the output of ls /usr/share/X11/xorg.conf.d/.
Files in /etc/X11/xorg.conf.d/…
[eduardolac-pc eduardolac]# ls /etc/X11/xorg.conf.d/
00-keyboard.conf 10-optimus-manager.conf 10-prime-offload.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
[eduardolac-pc eduardolac]# cat /etc/X11/xorg.conf.d/00-keyboard.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "br"
Option "XkbModel" "pc105"
EndSection
/etc/X11/xorg.conf.d/10-optimus-manager.conf
[eduardolac-pc eduardolac]# cat /etc/X11/xorg.conf.d/10-optimus-manager.conf
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0:2:0"
Option "DRI" "3"
EndSection
No /etc/X11/xorg.conf file exists, but we have these…
[eduardolac-pc eduardolac]# find / -iname "*xorg.conf*" -type f
/usr/share/man/man5/xorg.conf.5.gz
/usr/share/man/man5/xorg.conf.d.5.gz
/etc/bumblebee/xorg.conf.nvidia.pacsave.1
Wait, do you use optimus-manager?
You’re talk about this…
[eduardolac@eduardolac-pc ~]$ optimus-manager
ERROR: a GPU setup was initiated but Xorg post-start hook did not run.
Log at /var/log/optimus-manager/switch/switch-20201003T163703.log
If your login manager is GDM, make sure to follow those instructions:
https://github.com/Askannz/optimus-manager#important--gnome-and-gdm-users
If your display manager is neither GDM, SDDM nor LightDM, or if you don't use o
ne, read the wiki:
https://github.com/Askannz/optimus-manager/wiki/FAQ,-common-issues,-troubleshoo
ting
Cannot execute command because of previous errors.
For the time being please remove optimus-manager (10-optimus-manager.conf as well) and try again. If it still doesn’t work, try the following:
sudo systemctl set-default multi-user.target- reboot, log in
sudo modprobe nvidiasudo modprobe nvidia_modesetsudo modprobe nvidia_drm- wait 5-10 seconds, then run
nvidia-smito confirm that the GPU is recognized startx -logverbose 99 -verbose 99 -keeptty- try if
prime-runworks - log out to get back to the TTY
sudo systemctl set-default graphical.target- reboot
@pobrn Man… You’re the best!
Problem solved!
NOTE: I will still post a “reply” consolidating the whole process and with some important observations!
Thank you all!
Wait, you’re saying that it works now? Anyways, you might want to check this answer if it stops working. As mentioned on that thread, maybe this is the problem:
your system is mighty fast, and if the new nvidia driver now takes a bit longer to initialize, the Xserver doesn’t see the device. Don’t know if Arch has the possibility to embed the driver in the initrd so it’s available at an earlier point to avoid this.
I’d suggest you try to set up optimus-manager which should prevent such things from happening.
- IMPORTANT:
Handling video card drivers is always a critical process and YOU RISK RUNNING OUT OF ACCESS TO THE MANJARO’S GRAPHICAL USER INTERFACE. So, first of all WE STRONGLY RECOMMEND burning a DVD or preparing a USB stick with the Manjaro’s installer ISO ( Manjaro - Downloads ). If something goes wrong you can access your Manjaro’s installation by booting your computer with the Manjaro’s installer and then run the manjaro-chroot -a command on the terminal.
To writing a Manjaro installer ISO to a USB stick you could use the dd bs=4M if=<PATH_TO_MANJARO_ISO> of=/dev/sd<DRIVE_LETTER> status=progress oflag=sync command - use the fdisk -l command to find out the <DRIVE_LETTER>. To burn to a DVD you could use the K3b application ( https://kde.org/applications/en/k3b ).
[Refs.: Burn an ISO File - Manjaro , http://manjaro-linux.com.br/forum/topic5037.html ]
- INSTALL NVIDIA PRIME:
Find out the exact old bumblebee driver name with the command…
mhwd -li
… and, if applicable, remove with this example command…
mhwd -f -i pci video-hybrid-intel-nvidia-<VERSION_NUMBER>xx-bumblebee
If applicable, remove optimus-manager…
yay -R optimus-manager
Install new Nvidia prime driver…
mhwd -f -i pci video-modesetting
mhwd -f -i pci video-hybrid-intel-nvidia-450xx-prime
Create the 10-prime-offload.conf Xorg configuration file with this command…
read -r -d '' FILE_CONTENT << 'HEREDOC'
BEGIN
Section "ServerLayout"
Identifier "layout"
Screen 0 "intel"
Inactive "nvidia"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "intel"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
END
HEREDOC
echo -n "${FILE_CONTENT:6:-3}" > '/etc/X11/xorg.conf.d/10-prime-offload.conf'
TIP: Use the command lspci | grep -E "VGA|3D" to confirm the BusID of each device.
Run the command…
… and reboot your computer.
IMPORTANT: The systemctl set-default multi-user.target command will cause your graphical user interface to be temporarily unusable. Therefore, access this thread via another device (a smart phone, for example) as the next commands must be executed manually after reboot and login.
modprobe nvidia
modprobe nvidia_drm
reboot
Done!
