If mouse is put at far right then you left click and try to grab scrollbar to scroll down/up it will not work and you need to position your mouse pointer exactly above the scrollbar.
While other apps like Dolphin works fine
Why are you doing this?
Dolphin is a Qt5 application, Pamac is GTK+ application.
Qt5 has a larger placeholder for scrollbar, while GTK+ makes it larger on mouse over, hence why you have to have the pointer above it.
Pamac mouse grab region was working fine in previous versions. Now it’s frustrating to select that small scrollbar and scroll up or down.
There was a bug report that shows was not working properly actually.
Scroll-wheel doesn’t work for you either ?
If you change the theme, the scrollbar should size up on mouse over …
I reported that bug concerning two scrollbars and not for the mouse grab region.
