Nvidia graphic drivers problem
I installed graphic drivers from the hardware manager but when I go and check if the drivers are installed nvidia shows n/a
I installed video hybrid intel bumblebee
I have both intel hd graphics and gtx950m nvidia driver
Thanks for the help.
Use the search Luke. The search is with you.
Depending on which DE you're using, pick one.
So, for KDE, use the SDDM, For Gnome, use GDM, etc...
If you mean inxi… it is normal for bumblebee to have nvidia N/A.
Try with optirun inxi -Gxxx
