Hi,
I’ve just setup Manjaro KDE and was hoping to use it as a gaming PC. I followed the standard installation and tried running Dishonored through Proton on Steam. What I found was that MangoHUD was reporting 0% usage on GPU and the frame rate was < 1fps. I tried multiple Proton targets and didn’t seem to make a difference. nvidia-smi
reports 0% usage also and says the GPU is OFF.
Here’s inxi -GC
CPU: Info: Quad Core model: Intel Core i7-4770K bits: 64 type: MT MCP cache: L2: 8 MiB
Speed: 3498 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3498 2: 1244 3: 3498
4: 3333 5: 3300 6: 3499 7: 3498 8: 3499
Graphics: Device-1: NVIDIA GK104 [GeForce GTX 770] driver: nvidia v: 470.63.01
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution: 2560x1440~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 770/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
I’m quite new to Linux for gaming so if there’s any more info I can give to shed more light please let me know. I’ve looked at lots of forum post with similar issues but hard to pin down what is relevant and what isn’t as 90% of the time those appear to be related to hybrid drivers for laptops, I’m using desktop with discrete GPU and monitor is plugged into GPU.
Other things that might be worth mentioning…
- Steam was installed via flatpak (Manjaro didn’t seem to have Steam installed by default even though I think I read somewhere it should do?)
- GPU isn’t being utilized even for glxgears for example
- DE is running smoothly, no stutter or tearing
- nonfree drivers installed via Manjaro settings
