Thinking about getting the NVIDIA GeForce RTX 5050 Laptop GPU 8GB GDDR7: what is the appropriate driver for that GPU? How does it work on Manjaro?
I have Lenovo Legion with 5070 GPU - it runs great.
It can be leveraged using the nvidia-open driver and envy control.
I think the difference in the variations is the number of processing units.
Thank you so much. What is envy control? So the install command is sudo mhwd -i pci video-nvidia-open? Thanks again. ![]()
pacman -Si envycontrol ✔
Repositorium : extra
Version : 3.5.2-3
Beschreibung : Easy GPU switching for Nvidia Optimus laptops
Architektur : any
URL : https://github.com/bayasdev/envycontrol
Lizenzen : MIT
Gruppen : Nichts
Stellt bereit : Nichts
Hängt ab von : mkinitcpio python xorg-xrandr
Optionale Abhängigkeiten : gnome-shell-extension-gpu-profile-selector: GNOME extension
plasma6-applets-optimus-gpu-switcher: KDE Widget
In Konflikt mit : optimus-manager supergfxctl
Ersetzt : Nichts
Größe des Downloads : 23,28 KiB
Installationsgröße : 93,04 KiB
Packer : Mark Wagie <mark@manjaro.org>
Erstellt am : Sa 10 Jan 2026 21:48:10 CET
Verifiziert durch : MD5-Summe SHA-256-Summe Signatur
Thank you.
Running Manjaro from the USB – the new Nvidia display looks great. Not sure yet if I will be doing a permanent Manjaro install on my new Lenovo Yoga Aura Edition laptop or not. Nice to have an Intel Panther Lake CPU.
