NVIDIA GeForce GTX 1060 not starting on Dell G5 laptop
#1
Hello, all. :slightly_smiling_face:
So, straight to the point: although my NVIDIA graphics card is recognised by bumblebee, it refuses to run. I have searched the Net and spent considerable time in hopes of solving this issue, to no avail. Now, I turn to the community.
  1. I will post my specs and printouts that I think might help out.
  2. Then, I will post which solutions did not work for me. I will link and paste them here. [sudo applied in commands where necessary, left out here].
  3. Finally, I will list two solutions I did not try, and tell my reasoning behind why I did not try those.
Right now I reverted all the changes, as none of them did the trick. Details below. Let me know if I can add more info.
Note: as my account is new, I cannot post more than one link. Thus, here is a Teknik paste link, I marked the links in this post and You can follow them from here. Don’t worry, all relevant info is pasted in the post (and sorry for the inconvenience!):
https://p.teknik.io/Pom0s
  1. System Specifications:
    Dell G5 5587 5587FI7UC1
    Linux Manjaro KDE, Kernel 4.19.6-1
    Driver: proprietary β€œvideo-hybrid-intel-nvidia-bumblebee” with β€œlinux419-bbswitch” (installed automatically)
    My user is in the β€œbumblebee” group.
inxi -Fxz:
Summary
System:    Host: Aton Kernel: 4.19.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: KDE Plasma 5.14.4
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: G5 5587 v: N/A serial: <filter>
           Mobo: Dell model: 0M2MWX v: A00 serial: <filter> UEFI: Dell v: 1.3.0 date: 05/24/2018
Battery:   ID-1: BAT0 charge: 36.0 Wh condition: 56.0/56.0 Wh (100%) model: Samsung SDI DELL W7NKD88 status: Discharging
CPU:       Topology: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 9216 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 53004
           Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
           9: 900 10: 900 11: 900 12: 900
Graphics:  Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: N/A bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.3 driver: intel resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2) v: 4.5 Mesa 18.2.6 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k4.19.6-1-MANJARO
Network:   Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
           Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Dell driver: alx v: kernel port: 3000
           bus ID: 3c:00.0
           IF: enp60s0 state: down mac: <filter>
Drives:    Local Storage: total: 1.14 TiB used: 97.46 GiB (8.3%)
           ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG30ZMS256G NVMe 256GB size: 238.47 GiB
           ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
Partition: ID-1: / size: 216.79 GiB used: 36.44 GiB (16.8%) fs: ext4 dev: /dev/dm-0
           ID-2: swap-1 size: 16.91 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-1
Sensors:   System Temperatures: cpu: 32.0 C mobo: N/A
Info:      Processes: 282 Uptime: 21m Memory: 15.37 GiB used: 2.70 GiB (17.6%) Init: systemd Compilers: gcc: 8.2.1 Shell: bash
           v: 4.4.23 inxi: 3.0.27
screenfetch:
Summary
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     mozzribo@Aton
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     OS: Manjaro 18.0 Illyria
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Kernel: x86_64 Linux 4.19.6-1-MANJARO
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Uptime: 22m
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Packages: 1316
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Shell: bash 4.4.23
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Resolution: 1920x1080
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     DE: KDE 5.52.0 / Plasma 5.14.4
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     WM: KWin
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     GTK Theme: Breath [GTK2/3]
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Icon Theme: maia
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Font: Noto Sans Regular
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     CPU: Intel Core i7-8750H @ 12x 4.1GHz [32.0Β°C]
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     GPU: Unknown
                                  RAM: 2946MiB / 15741MiB
dmesg (as much as it is displayed):
Summary
[    1.022238] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    1.022240] pci_bus 0000:00: root bus resource [mem 0x7e800000-0xefffffff window]
[    1.022241] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    1.022244] pci_bus 0000:00: root bus resource [bus 00-7e]
[    1.022254] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[    1.022458] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    1.022515] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    1.022862] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[    1.022877] pci 0000:00:02.0: reg 0x10: [mem 0xeb000000-0xebffffff 64bit]
[    1.022885] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[    1.022891] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    1.022912] pci 0000:00:02.0: BAR 2: assigned to efifb
[    1.023126] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    1.023140] pci 0000:00:04.0: reg 0x10: [mem 0xed410000-0xed417fff 64bit]
[    1.023423] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    1.023437] pci 0000:00:08.0: reg 0x10: [mem 0xed42c000-0xed42cfff 64bit]
[    1.023728] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    1.023776] pci 0000:00:12.0: reg 0x10: [mem 0xed42b000-0xed42bfff 64bit]
[    1.024180] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    1.024227] pci 0000:00:14.0: reg 0x10: [mem 0xed400000-0xed40ffff 64bit]
[    1.024394] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    1.024708] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    1.024747] pci 0000:00:14.2: reg 0x10: [mem 0xed422000-0xed423fff 64bit]
[    1.024768] pci 0000:00:14.2: reg 0x18: [mem 0xed42a000-0xed42afff 64bit]
[    1.025093] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    1.025270] pci 0000:00:14.3: reg 0x10: [mem 0xed41c000-0xed41ffff 64bit]
[    1.025852] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    1.026465] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    1.027193] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.029960] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    1.030688] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.033259] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    1.033306] pci 0000:00:16.0: reg 0x10: [mem 0xed427000-0xed427fff 64bit]
[    1.033440] pci 0000:00:16.0: PME# supported from D3hot
[    1.033791] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[    1.033834] pci 0000:00:17.0: reg 0x10: [mem 0xed420000-0xed421fff]
[    1.033851] pci 0000:00:17.0: reg 0x14: [mem 0xed426000-0xed4260ff]
[    1.033868] pci 0000:00:17.0: reg 0x18: [io  0x5090-0x5097]
[    1.033885] pci 0000:00:17.0: reg 0x1c: [io  0x5080-0x5083]
[    1.033902] pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
[    1.033917] pci 0000:00:17.0: reg 0x24: [mem 0xed425000-0xed4257ff]
[    1.034025] pci 0000:00:17.0: PME# supported from D3hot
[    1.034405] pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
[    1.034636] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    1.034684] pci 0000:00:1b.0: PTM enabled (root), 4dns granularity
[    1.035097] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    1.035328] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    1.035380] pci 0000:00:1d.0: PTM enabled (root), 4dns granularity
[    1.035743] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[    1.035972] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[    1.036023] pci 0000:00:1d.5: PTM enabled (root), 4dns granularity
[    1.036369] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    1.036781] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    1.036862] pci 0000:00:1f.3: reg 0x10: [mem 0xed418000-0xed41bfff 64bit]
[    1.036939] pci 0000:00:1f.3: reg 0x20: [mem 0xed100000-0xed1fffff 64bit]
[    1.037109] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    1.037562] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    1.037746] pci 0000:00:1f.4: reg 0x10: [mem 0xed424000-0xed4240ff 64bit]
[    1.037960] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[    1.038435] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    1.038466] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    1.038802] pci 0000:01:00.0: [10de:1c20] type 00 class 0x030000
[    1.038819] pci 0000:01:00.0: reg 0x10: [mem 0xec000000-0xecffffff]
[    1.038829] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    1.038838] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[    1.038845] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    1.038852] pci 0000:01:00.0: reg 0x30: [mem 0xed000000-0xed07ffff pref]
[    1.039060] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.039063] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    1.039066] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    1.039070] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    1.039309] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
[    1.039320] pci 0000:00:1b.0:   bridge window [mem 0xd4000000-0xea0fffff]
[    1.039330] pci 0000:00:1b.0:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    1.039672] pci 0000:3b:00.0: [1179:0113] type 00 class 0x010802
[    1.039728] pci 0000:3b:00.0: reg 0x10: [mem 0xed300000-0xed303fff 64bit]
[    1.039949] pci 0000:3b:00.0: PME# supported from D0 D3hot
[    1.040170] pci 0000:00:1d.0: PCI bridge to [bus 3b]
[    1.040181] pci 0000:00:1d.0:   bridge window [mem 0xed300000-0xed3fffff]
[    1.040437] pci 0000:3c:00.0: [1969:e0a1] type 00 class 0x020000
[    1.040488] pci 0000:3c:00.0: reg 0x10: [mem 0xed200000-0xed23ffff 64bit]
[    1.040505] pci 0000:3c:00.0: reg 0x18: [io  0x3000-0x307f]
[    1.040684] pci 0000:3c:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.040748] pci 0000:3c:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:1d.5 (capable of 7.876 Gb/s with 8 GT/s x1 link)
[    1.040882] pci 0000:00:1d.5: PCI bridge to [bus 3c]
[    1.040888] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    1.040894] pci 0000:00:1d.5:   bridge window [mem 0xed200000-0xed2fffff]
[    1.044207] ACPI: PCI Interrupt Link [LNKA] (IRQs) *0
[    1.044273] ACPI: PCI Interrupt Link [LNKB] (IRQs) *1
[    1.044341] ACPI: PCI Interrupt Link [LNKC] (IRQs) *0
[    1.044404] ACPI: PCI Interrupt Link [LNKD] (IRQs) *0
[    1.044466] ACPI: PCI Interrupt Link [LNKE] (IRQs) *0
[    1.044527] ACPI: PCI Interrupt Link [LNKF] (IRQs) *0
[    1.044587] ACPI: PCI Interrupt Link [LNKG] (IRQs) *0
[    1.044648] ACPI: PCI Interrupt Link [LNKH] (IRQs) *0
[    1.050979] ACPI: EC: interrupt unblocked
[    1.051009] ACPI: EC: event unblocked
[    1.051057] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    1.051059] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as boot DSDT EC to handle transactions and events
[    1.051196] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    1.051196] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    1.051196] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    1.051196] pci 0000:01:00.0: vgaarb: bridge control possible
[    1.051196] pci 0000:00:02.0: vgaarb: no bridge control possible
[    1.051196] vgaarb: loaded
[    1.051424] ACPI: bus type USB registered
[    1.051442] usbcore: registered new interface driver usbfs
[    1.051449] usbcore: registered new interface driver hub
[    1.051489] usbcore: registered new device driver usb
[    1.051521] pps_core: LinuxPPS API ver. 1 registered
[    1.051522] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.051525] PTP clock support registered
[    1.051533] EDAC MC: Ver: 3.0.0
[    1.052019] Registered efivars operations
[    1.091357] PCI: Using ACPI for IRQ routing
[    1.115125] PCI: pci_cache_line_size set to 64 bytes
[    1.115505] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    1.115506] e820: reserve RAM buffer [mem 0x5dc7e000-0x5fffffff]
[    1.115508] e820: reserve RAM buffer [mem 0x6d72a000-0x6fffffff]
[    1.115509] e820: reserve RAM buffer [mem 0x78600000-0x7bffffff]
[    1.115511] e820: reserve RAM buffer [mem 0x47f800000-0x47fffffff]
[    1.115623] NetLabel: Initializing
[    1.115624] NetLabel:  domain hash size = 128
[    1.115624] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.115640] NetLabel:  unlabeled traffic allowed by default
[    1.118205] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    1.118213] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    1.122032] clocksource: Switched to clocksource tsc-early
[    1.133069] VFS: Disk quotas dquot_6.6.0
[    1.133088] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.133162] pnp: PnP ACPI init
[    1.133522] system 00:00: [io  0x0680-0x069f] has been reserved
[    1.133524] system 00:00: [io  0x164e-0x164f] has been reserved
[    1.133530] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.133560] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    1.133730] system 00:02: [io  0x1854-0x1857] has been reserved
[    1.133735] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    1.133894] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[    1.133918] pnp 00:04: Plug and Play ACPI device, IDs DLL0825 PNP0f13 (active)
[    1.134230] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    1.134232] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    1.134234] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    1.134236] system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
[    1.134238] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    1.134240] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[    1.134242] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[    1.134245] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    1.134249] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.134654] system 00:06: [io  0x1800-0x18fe] could not be reserved
[    1.134656] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[    1.134658] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    1.134660] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    1.134663] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    1.134665] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[    1.134667] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    1.134672] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.135200] system 00:07: [io  0x2000-0x20fe] has been reserved
[    1.135204] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.137126] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.148282] pnp: PnP ACPI: found 9 devices
[    1.154385] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    1.154416] pci 0000:00:1b.0: bridge window [io  0x1000-0x0fff] to [bus 02-3a] add_size 1000
[    1.154460] pci 0000:00:15.0: BAR 0: assigned [mem 0x7e800000-0x7e800fff 64bit]
[    1.154737] pci 0000:00:15.1: BAR 0: assigned [mem 0x7e801000-0x7e801fff 64bit]
[    1.155014] pci 0000:00:1b.0: BAR 13: assigned [io  0x6000-0x6fff]
[    1.155017] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.155020] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    1.155023] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    1.155026] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    1.155031] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
[    1.155040] pci 0000:00:1b.0:   bridge window [io  0x6000-0x6fff]
[    1.155048] pci 0000:00:1b.0:   bridge window [mem 0xd4000000-0xea0fffff]
[    1.155054] pci 0000:00:1b.0:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    1.155065] pci 0000:00:1d.0: PCI bridge to [bus 3b]
[    1.155073] pci 0000:00:1d.0:   bridge window [mem 0xed300000-0xed3fffff]
[    1.155088] pci 0000:00:1d.5: PCI bridge to [bus 3c]
[    1.155092] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    1.155099] pci 0000:00:1d.5:   bridge window [mem 0xed200000-0xed2fffff]
[    1.155115] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    1.155117] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    1.155119] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    1.155121] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    1.155122] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    1.155124] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    1.155126] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    1.155128] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    1.155129] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    1.155131] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    1.155133] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    1.155135] pci_bus 0000:00: resource 15 [mem 0x7e800000-0xefffffff window]
[    1.155136] pci_bus 0000:00: resource 16 [mem 0xfc800000-0xfe7fffff window]
[    1.155138] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    1.155140] pci_bus 0000:01: resource 1 [mem 0xec000000-0xed0fffff]
[    1.155142] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    1.155144] pci_bus 0000:02: resource 0 [io  0x6000-0x6fff]
[    1.155145] pci_bus 0000:02: resource 1 [mem 0xd4000000-0xea0fffff]
[    1.155147] pci_bus 0000:02: resource 2 [mem 0x90000000-0xb1ffffff 64bit pref]
[    1.155149] pci_bus 0000:3b: resource 1 [mem 0xed300000-0xed3fffff]
[    1.155151] pci_bus 0000:3c: resource 0 [io  0x3000-0x3fff]
[    1.155153] pci_bus 0000:3c: resource 1 [mem 0xed200000-0xed2fffff]
[    1.155415] NET: Registered protocol family 2
[    1.155575] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[    1.155640] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    1.155844] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.155962] TCP: Hash tables configured (established 131072 bind 65536)
[    1.156004] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    1.156053] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    1.156141] NET: Registered protocol family 1
[    1.156147] NET: Registered protocol family 44
[    1.156159] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    1.156477] PCI: CLS 64 bytes, default 64
[    1.156518] Unpacking initramfs...
[    1.373372] Freeing initrd memory: 12592K
[    1.373424] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.373426] software IO TLB: mapped [mem 0x63601000-0x67601000] (64MB)
[    1.373465] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fd3b81b95f, max_idle_ns: 440795257325 ns
[    1.373494] clocksource: Switched to clocksource tsc
[    1.373722] Scanning for low memory corruption every 60 seconds
[    1.374509] Initialise system trusted keyrings
[    1.374520] Key type blacklist registered
[    1.374556] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    1.375943] zbud: loaded
[    1.376323] pstore: using zstd compression
[    1.377688] Key type asymmetric registered
[    1.377689] Asymmetric key parser 'x509' registered
[    1.377698] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    1.377747] io scheduler noop registered
[    1.377748] io scheduler deadline registered
[    1.377778] io scheduler cfq registered (default)
[    1.377779] io scheduler mq-deadline registered
[    1.377780] io scheduler kyber registered
[    1.377806] io scheduler bfq registered
[    1.377831] io scheduler bfq-sq registered
[    1.377832] BFQ I/O-scheduler: v9 (with cgroups support)
[    1.377833] blkcg_policy_register: BLKCG_MAX_POLS too small
[    1.379511] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.379614] efifb: probing for efifb
[    1.379627] efifb: showing boot graphics
[    1.380794] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[    1.380795] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.380796] efifb: scrolling: redraw
[    1.380798] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.380844] fbcon: Deferring console take-over
[    1.380846] fb0: EFI VGA frame buffer device
[    1.380855] intel_idle: MWAIT substates: 0x11142120
[    1.380857] intel_idle: v0.4.1 model 0x9E
[    1.381607] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.381710] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    1.381722] ACPI: Lid Switch [LID0]
[    1.381762] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    1.381770] ACPI: Power Button [PBTN]
[    1.381806] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[    1.381814] ACPI: Sleep Button [SBTN]
[    1.381852] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    1.381859] ACPI: Power Button [PWRF]
[    1.386717] thermal LNXTHERM:00: registered as thermal_zone0
[    1.386718] ACPI: Thermal Zone [THM] (25 C)
[    1.386915] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.389386] nvme nvme0: pci function 0000:3b:00.0
[    1.389415] usbcore: registered new interface driver usbserial_generic
[    1.389419] usbserial: USB Serial support registered for generic
[    1.389501] rtc_cmos 00:01: RTC can wake from S4
[    1.390841] rtc_cmos 00:01: registered as rtc0
[    1.390855] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    1.390903] intel_pstate: Intel P-state driver initializing
[    1.390944] intel_pstate: Disabling energy efficiency optimization
[    1.392278] intel_pstate: HWP enabled
[    1.392596] ledtrig-cpu: registered to indicate activity on CPUs
[    1.392639] intel_pmc_core:  initialized
[    1.392884] NET: Registered protocol family 10
[    1.397306] Segment Routing with IPv6
[    1.397337] NET: Registered protocol family 17
[    1.398615] RAS: Correctable Errors collector initialized.
[    1.398683] microcode: sig=0x906ea, pf=0x20, revision=0x96
[    1.399185] microcode: Microcode Update Driver: v2.2.
[    1.399196] sched_clock: Marking stable (1401916604, -2735390)->(1419584268, -20403054)
[    1.399810] registered taskstats version 1
[    1.399818] Loading compiled-in X.509 certificates
[    1.402918] Loaded X.509 cert 'Build time autogenerated kernel key: feb0a7e979343029b50914b06b5d7d5c8f5abf36'
[    1.402947] zswap: loaded using pool lzo/zbud
[    1.407514] Key type big_key registered
[    1.409529]   Magic number: 14:208:188
[    1.409578] acpi device:47: hash matches
[    1.409585] acpi device:1a: hash matches
[    1.409888] rtc_cmos 00:01: setting system clock to 2018-12-10 17:11:34 UTC (1544461894)
[    1.609349] nvme nvme0: allocated 38 MiB host memory buffer.
[    1.646026]  nvme0n1: p1 p2 p3
[    1.650669] Freeing unused decrypted memory: 2040K
[    1.652352] Freeing unused kernel image memory: 1536K
[    1.652479] Write protecting the kernel read-only data: 18432k
[    1.653806] Freeing unused kernel image memory: 2008K
[    1.654195] Freeing unused kernel image memory: 404K
[    1.672621] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.672623] x86/mm: Checking user space page tables
[    1.686654] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.686656] Run /init as init process
[    1.864055] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    1.864684] i8042: Warning: Keylock active
[    1.866248] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.866290] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.884050] SCSI subsystem initialized
[    1.888607] cryptd: max_cpu_qlen set to 1000
[    1.891046] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.891057] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.892248] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x110 quirks 0x0000000000009810
[    1.892262] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.892701] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.892705] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.892708] usb usb1: Product: xHCI Host Controller
[    1.892711] usb usb1: Manufacturer: Linux 4.19.6-1-MANJARO xhci-hcd
[    1.892713] usb usb1: SerialNumber: 0000:00:14.0
[    1.892935] hub 1-0:1.0: USB hub found
[    1.893000] hub 1-0:1.0: 16 ports detected
[    1.898042] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.898051] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.898057] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.898138] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.898142] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.898145] usb usb2: Product: xHCI Host Controller
[    1.898147] usb usb2: Manufacturer: Linux 4.19.6-1-MANJARO xhci-hcd
[    1.898150] usb usb2: SerialNumber: 0000:00:14.0
[    1.898327] hub 2-0:1.0: USB hub found
[    1.898360] hub 2-0:1.0: 8 ports detected
[    1.899074] usb: port power management may be unreliable
[    1.899405] AVX2 version of gcm_enc/dec engaged.
[    1.899407] AES CTR mode by8 optimization enabled
[    1.899551] libata version 3.00 loaded.
[    1.905500] ahci 0000:00:17.0: version 3.0
[    1.905901] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[    1.905946] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    1.905952] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm clo only pio slum part ems deso sadm sds apst
[    1.906269] scsi host0: ahci
[    1.906395] ata1: SATA max UDMA/133 abar m2048@0xed425000 port 0xed425100 irq 136
[    1.913803] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    2.218913] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.227757] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[    2.234031] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    2.234039] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.234045] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    2.237200] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    2.370662] usb 1-1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[    2.370667] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.370671] usb 1-1: Product: USB Receiver
[    2.370675] usb 1-1: Manufacturer: Logitech
[    2.381048] hidraw: raw HID events driver (C) Jiri Kosina
[    2.386419] usbcore: registered new interface driver usbhid
[    2.386420] usbhid: USB HID core driver
[    2.389897] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C534.0001/input/input6
[    2.444623] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-1/input0
[    2.445164] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/input/input7
[    2.445270] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/input/input8
[    2.494424] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[    2.501197] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/input/input9
[    2.501669] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-1/input1
[    2.620006] ata1.00: ATA-10: ST1000LM035-1RK172, SDM3, max UDMA/133
[    2.620013] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.645501] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    2.645509] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.645515] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    2.645802] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    2.651445] usb 1-5: New USB device found, idVendor=0c45, idProduct=6718, bcdDevice=76.05
[    2.651451] usb 1-5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    2.651456] usb 1-5: Product: Integrated_Webcam_HD
[    2.651460] usb 1-5: Manufacturer: CN0D01JHLOG00887BACRA00
[    2.682970] ata1.00: configured for UDMA/133
[    2.684498] scsi 0:0:0:0: Direct-Access     ATA      ST1000LM035-1RK1 SDM3 PQ: 0 ANSI: 5
[    2.694505] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.694511] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    2.694524] sd 0:0:0:0: [sda] Write Protect is off
[    2.694529] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.694547] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.755614]  sda: sda1
[    2.756407] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.777737] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[    2.919575] usb 1-9: New USB device found, idVendor=27c6, idProduct=5381, bcdDevice= 1.00
[    2.919581] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.919585] usb 1-9: Product: Goodix Fingerprint Device
[    2.919589] usb 1-9: Manufacturer: HTMicroelectronics
[    2.919593] usb 1-9: SerialNumber: HTK32
[    3.035625] device-mapper: uevent: version 1.0.3
[    3.035874] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[    3.044414] usb 1-14: new full-speed USB device number 5 using xhci_hcd
[    3.185499] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    3.185501] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.610427] NET: Registered protocol family 38
[    8.307234] random: cryptsetup: uninitialized urandom read (2 bytes read)
[    8.370799] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[   13.906614] random: cryptsetup: uninitialized urandom read (2 bytes read)
[   13.984860] PM: Image not found (code -22)
[   14.006590] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[   14.047188] random: fast init done
[   14.181069] systemd[1]: systemd 239 running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[   14.198860] systemd[1]: Detected architecture x86-64.
[   14.206634] systemd[1]: Set hostname to <Aton>.
[   14.402123] random: systemd: uninitialized urandom read (16 bytes read)
[   14.405078] systemd[1]: Created slice system-systemd\x2dcryptsetup.slice.
[   14.405132] random: systemd: uninitialized urandom read (16 bytes read)
[   14.405182] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   14.405322] systemd[1]: Listening on Journal Audit Socket.
[   14.405585] systemd[1]: Created slice system-getty.slice.
[   14.405707] systemd[1]: Listening on Journal Socket.
[   14.406556] systemd[1]: Mounting Kernel Debug File System...
[   14.408034] systemd[1]: Starting Load Kernel Modules...
[   14.423100] EXT4-fs (dm-0): re-mounted. Opts: (null)
[   14.433473] audit: type=1130 audit(1544461907.519:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.434073] audit: type=1130 audit(1544461907.519:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.434737] audit: type=1130 audit(1544461907.523:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.444752] audit: type=1130 audit(1544461907.533:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.445817] audit: type=1130 audit(1544461907.533:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.447541] audit: type=1130 audit(1544461907.533:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.453233] audit: type=1130 audit(1544461907.539:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.460133] audit: type=1130 audit(1544461907.546:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.490747] audit: type=1130 audit(1544461907.576:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.501222] systemd-journald[380]: Received request to flush runtime journal from PID 1
[   14.530176] audit: type=1130 audit(1544461907.616:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.583215] ACPI: AC Adapter [AC] (off-line)
[   14.599235] input: Intel HID events as /devices/platform/INT33D5:00/input/input12
[   14.602383] intel-hid INT33D5:00: platform supports 5 button array
[   14.602480] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input13
[   14.629724] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[   14.629869] wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
[   14.629873] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[   14.666418] input: PC Speaker as /devices/platform/pcspkr/input/input14
[   14.674333] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[   14.679064] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[   14.679175] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[   14.693304] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[   14.693308] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   14.693310] RAPL PMU: hw unit of domain package 2^-14 Joules
[   14.693311] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   14.693313] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   14.693315] RAPL PMU: hw unit of domain psys 2^-14 Joules
[   14.695903] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[   14.708632] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   14.713195] alx 0000:3c:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [3c:2c:30:9b:65:98]
[   14.731257] idma64 idma64.0: Found Intel integrated DMA 64-bit
[   14.733670] Linux agpgart interface v0.103
[   14.803763] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.818819] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.825066] mousedev: PS/2 mouse device common for all mice
[   14.895929] media: Linux media interface: v0.10
[   14.897994] cdc_acm 1-9:1.0: ttyACM0: USB ACM device
[   14.898259] usbcore: registered new interface driver cdc_acm
[   14.898262] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   14.945228] Bluetooth: Core ver 2.22
[   14.945257] NET: Registered protocol family 31
[   14.945259] Bluetooth: HCI device and connection manager initialized
[   14.945264] Bluetooth: HCI socket layer initialized
[   14.945269] Bluetooth: L2CAP socket layer initialized
[   14.945291] Bluetooth: SCO socket layer initialized
[   14.950571] Intel(R) Wireless WiFi driver for Linux
[   14.950573] Copyright(c) 2003- 2015 Intel Corporation
[   14.950665] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[   14.953318] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   14.977821] random: crng init done
[   14.977825] random: 6 urandom warning(s) missed due to ratelimiting
[   14.985081] iwlwifi 0000:00:14.3: loaded firmware version 38.755cfdd8.0 op_mode iwlmvm
[   14.998059] videodev: Linux video capture interface: v2.00
[   15.011653] VFIO - User Level meta-driver version: 0.3
[   15.038496] usbcore: registered new interface driver btusb
[   15.038998] intel_rapl: Found RAPL domain package
[   15.039001] intel_rapl: Found RAPL domain core
[   15.039004] intel_rapl: Found RAPL domain uncore
[   15.039006] intel_rapl: Found RAPL domain dram
[   15.039071] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[   15.040046] Bluetooth: hci0: Device revision is 2
[   15.040049] Bluetooth: hci0: Secure boot is enabled
[   15.040051] Bluetooth: hci0: OTP lock is enabled
[   15.040053] Bluetooth: hci0: API lock is enabled
[   15.040055] Bluetooth: hci0: Debug lock is disabled
[   15.040058] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   15.043212] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[   15.052544] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0c45:6718)
[   15.061388] uvcvideo 1-5:1.0: Entity type for entity Extension 4 was not initialized!
[   15.061394] uvcvideo 1-5:1.0: Entity type for entity Extension 3 was not initialized!
[   15.061397] uvcvideo 1-5:1.0: Entity type for entity Processing 2 was not initialized!
[   15.061401] uvcvideo 1-5:1.0: Entity type for entity Camera 1 was not initialized!
[   15.061543] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input16
[   15.061672] usbcore: registered new interface driver uvcvideo
[   15.061674] USB Video Class driver (1.1.1)
[   15.072375] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[   15.122750] input: Dell WMI hotkeys as /devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input17
[   15.131256] Adding 17729000k swap on /dev/mapper/luks-41756e7b-2706-4075-b27f-d20355523aba.  Priority:-2 extents:1 across:17729000k SSFS
[   15.131876] alx 0000:3c:00.0 enp60s0: renamed from eth0
[   15.196508] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[   15.248348] iwlwifi 0000:00:14.3: base HW address: 48:a4:72:53:3e:9b
[   15.303187] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[   15.303189] fb: switching to inteldrmfb from EFI VGA
[   15.303340] [drm] Replacing VGA console driver
[   15.322383] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   15.322782] thermal thermal_zone8: failed to read out thermal zone (-61)
[   15.325027] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[   15.345029] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   15.346197] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   15.346199] [drm] Driver supports precise vblank timestamp query.
[   15.387147] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[   15.388349] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[   15.399272] battery: ACPI: Battery Slot [BAT0] (battery present)
[   15.469812] psmouse serio1: synaptics: queried max coordinates: x [..5664], y [..4648]
[   15.497960] psmouse serio1: synaptics: queried min coordinates: x [1278..], y [1206..]
[   15.497967] psmouse serio1: synaptics: Your touchpad (PNP: DLL0825 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[   15.540916] bbswitch: loading out-of-tree module taints kernel.
[   15.541003] bbswitch: module verification failed: signature and/or required key missing - tainting kernel
[   15.541336] bbswitch: version 0.8
[   15.541407] bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
[   15.541455] bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.PEGP
[   15.541603] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180810/nsarguments-66)
[   15.541869] bbswitch: detected an Optimus _DSM function
[   15.541884] pci 0000:01:00.0: enabling device (0006 -> 0007)
[   15.542014] bbswitch: disabling discrete graphics
[   15.564459] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.2, id: 0x1e2a1, caps: 0xf00223/0x840300/0x12e800/0x0, board id: 3240, fw id: 2374689
[   15.596482] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.596485] Bluetooth: BNEP filters: protocol multicast
[   15.596489] Bluetooth: BNEP socket layer initialized
[   15.600953] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input15
[   15.672157] iTCO_vendor_support: vendor-support=0
[   15.676773] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   15.676820] iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5ffff]
[   15.676828] iTCO_wdt: probe of iTCO_wdt failed with error -16
[   15.789327] bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
[   15.850800] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[   15.851444] idma64 idma64.1: Found Intel integrated DMA 64-bit
[   15.858880] IPv6: ADDRCONF(NETDEV_UP): enp60s0: link is not ready
[   15.860120] IPv6: ADDRCONF(NETDEV_UP): enp60s0: link is not ready
[   15.865186] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   15.987495] i2c_hid i2c-DELL0825:00: i2c-DELL0825:00 supply vdd not found, using dummy regulator
[   15.987515] i2c_hid i2c-DELL0825:00: Linked as a consumer to regulator.0
[   15.987517] i2c_hid i2c-DELL0825:00: i2c-DELL0825:00 supply vddl not found, using dummy regulator
[   16.014642] input: DELL0825:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-9/i2c-DELL0825:00/0018:06CB:7E92.0003/input/input18
[   16.014777] input: DELL0825:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-9/i2c-DELL0825:00/0018:06CB:7E92.0003/input/input19
[   16.014887] hid-generic 0018:06CB:7E92.0003: input,hidraw2: I2C HID v1.00 Mouse [DELL0825:00 06CB:7E92] on i2c-DELL0825:00
[   16.074438] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[   16.074970] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   16.202711] input: DELL0825:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-9/i2c-DELL0825:00/0018:06CB:7E92.0003/input/input22
[   16.202863] hid-multitouch 0018:06CB:7E92.0003: input,hidraw2: I2C HID v1.00 Mouse [DELL0825:00 06CB:7E92] on i2c-DELL0825:00
[   16.236358] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[   16.246181] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   16.253065] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input24
[   16.253185] ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
[   16.253251] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input25
[   16.253474] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   16.296274] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[   16.296912] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   16.413537] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   16.433252] fbcon: inteldrmfb (fb0) is primary device
[   16.433254] fbcon: Deferring console take-over
[   16.433259] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   16.439099] Bluetooth: hci0: Waiting for firmware download to complete
[   16.439102] Bluetooth: hci0: Firmware loaded in 1367828 usecs
[   16.439174] Bluetooth: hci0: Waiting for device to boot
[   16.454103] Bluetooth: hci0: Device booted in 14606 usecs
[   16.454469] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[   16.457154] Bluetooth: hci0: Applying Intel DDC parameters completed
[   16.559049] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3246: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   16.559053] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   16.559057] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   16.559059] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   16.559061] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   16.559064] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[   16.559067] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
[   16.559069] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   16.702936] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[   16.705173] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[   16.705409] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[   16.705573] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[   16.707759] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[   16.707920] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[   16.708167] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[   20.324349] kauditd_printk_skb: 31 callbacks suppressed
[   20.324353] audit: type=1131 audit(1544461913.409:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.446180] audit: type=1006 audit(1544461913.533:44): pid=918 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   20.461934] audit: type=1130 audit(1544461913.549:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.470708] audit: type=1006 audit(1544461913.556:46): pid=923 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   20.533270] audit: type=1130 audit(1544461913.619:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.353394] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[   21.354286] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   23.857193] audit: type=1130 audit(1544461916.943:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.007817] audit: type=1130 audit(1544461917.093:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.010815] audit: type=1130 audit(1544461917.096:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.149886] fuse init (API version 7.27)
[   24.432139] Bluetooth: RFCOMM TTY layer initialized
[   24.432148] Bluetooth: RFCOMM socket layer initialized
[   24.432157] Bluetooth: RFCOMM ver 1.11
[   24.894255] audit: type=1130 audit(1544461917.979:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.909819] audit: type=1131 audit(1544461917.996:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.008282] audit: type=1131 audit(1544461919.096:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   27.622743] audit: type=1130 audit(1544461920.709:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   43.015881] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   43.015912] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   43.016254] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   43.016468] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   43.016679] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   43.017041] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   43.017277] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   43.174045] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   43.174090] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   43.174460] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   43.174803] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   43.175219] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   43.175643] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   43.175973] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   43.342346] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   43.342376] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   43.342716] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   43.343025] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   43.343228] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   43.343426] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   43.343633] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   43.502993] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   43.503012] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   43.503192] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   43.503303] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   43.503412] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   43.503521] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   43.503635] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   43.653943] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   43.653988] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   43.654432] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   43.654809] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   43.655120] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   43.655487] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   43.655825] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   43.822672] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   43.822703] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   43.823059] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   43.823285] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   43.823695] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   43.824151] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   43.824468] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   43.982698] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   43.982742] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   43.983067] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   43.983275] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   43.983486] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   43.983694] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   43.983918] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   44.369432] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   44.369466] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   44.369811] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   44.370027] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   44.370441] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   44.370906] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   44.371229] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   45.809758] audit: type=1131 audit(1544461938.896:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.001920] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   52.226784] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[   52.227387] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   55.857582] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[   55.858226] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[   59.201017] wlp0s20f3: authenticate with ac:22:05:84:9c:a2
[   59.208997] wlp0s20f3: send auth to ac:22:05:84:9c:a2 (try 1/3)
[   59.266034] wlp0s20f3: authenticated
[   59.266336] wlp0s20f3: associating with AP with corrupt probe response
[   59.267719] wlp0s20f3: associate with ac:22:05:84:9c:a2 (try 1/3)
[   59.298959] wlp0s20f3: RX AssocResp from ac:22:05:84:9c:a2 (capab=0x511 status=0 aid=1)
[   59.300838] wlp0s20f3: associated
[   59.367322] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[   59.484900] tun: Universal TUN/TAP device driver, 1.6
[   61.097483] audit: type=1130 audit(1544461954.183:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   67.804122] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   67.804149] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   67.804548] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   67.805014] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   67.805303] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   67.805545] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   67.805741] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   67.985085] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   67.985116] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   67.985496] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   67.985729] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   67.985918] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   67.986107] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   67.986295] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   68.143957] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   68.143986] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   68.144181] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   68.144427] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   68.144743] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   68.144970] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   68.145161] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   68.291212] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   68.291240] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   68.291689] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   68.292074] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   68.292368] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   68.292610] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   68.292806] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   68.457740] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20180810/psargs-330)
[   68.457774] ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.BRT6, AE_NOT_FOUND (20180810/psparse-516)
[   68.457998] ACPI Error: Method parse/execution failed \EV5, AE_NOT_FOUND (20180810/psparse-516)
[   68.458218] ACPI Error: Method parse/execution failed \SMEE, AE_NOT_FOUND (20180810/psparse-516)
[   68.458443] ACPI Error: Method parse/execution failed \SMIE, AE_NOT_FOUND (20180810/psparse-516)
[   68.458725] ACPI Error: Method parse/execution failed \NEVT, AE_NOT_FOUND (20180810/psparse-516)
[   68.458988] ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.ECDV._Q66, AE_NOT_FOUND (20180810/psparse-516)
[   71.010116] audit: type=1131 audit(1544461964.096:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  780.331648] audit: type=1130 audit(1544462673.141:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  810.423010] audit: type=1131 audit(1544462703.235:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  901.001819] audit: type=1130 audit(1544462793.814:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  901.001829] audit: type=1131 audit(1544462793.814:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1354.282940] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=83120 end=83121) time 545 us, min 1073, max 1079, scanline start 1058, end 1095
[ 1386.371422] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=85046 end=85047) time 511 us, min 1073, max 1079, scanline start 1059, end 1093
[ 1693.941434] bbswitch: enabling discrete graphics
[ 1694.164510] pci 0000:01:00.0: Refused to change power state, currently in D3
[ 1694.225206] pci 0000:01:00.0: Refused to change power state, currently in D3
[ 1736.544144] bbswitch: enabling discrete graphics
[ 1736.544195] pci 0000:01:00.0: Refused to change power state, currently in D3
[ 1753.834046] bbswitch: enabling discrete graphics
[ 1753.834087] pci 0000:01:00.0: Refused to change power state, currently in D3
[ 1859.199698] audit: type=1130 audit(1544463752.036:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1869.259912] audit: type=1131 audit(1544463762.097:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
nvidia-settings:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
lspci | grep "NVIDIA" | cut -b -8:
01:00.0
sudo optirun -b none nvidia-settings -c :8:
[ 3280.845201] [ERROR]Cannot access secondary GPU - error: Could not enable discrete graphics card
[ 3280.845271] [ERROR]Aborting because fallback start is disabled.
/usr/bin/nvidia-settings:
nvdock:
Segmentation fault (core dumped)
systemctl status bumblebeed:
Summary
● bumblebeed.service - Bumblebee C Daemon
   Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled; vendor preset: disabled)
   Active: active (running) since Mon 2018-12-10 18:11:48 CET; 23min ago
 Main PID: 588 (bumblebeed)
    Tasks: 1 (limit: 4915)
   Memory: 1.6M
   CGroup: /system.slice/bumblebeed.service
           └─588 /usr/bin/bumblebeed --use-syslog
Dec 10 18:11:48 Aton systemd[1]: Started Bumblebee C Daemon.
Dec 10 18:11:48 Aton bumblebeed[588]: /usr/bin/bumblebeed 3.2.1-2017-02-27-Format:%h$ started
cat /proc/acpi/bbswitch:
0000:01:00.0 OFF
dmesg | grep -C10 bbswitch:
Summary
[ 2464.274679] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=149742 end=149743) time 1086 us, min 1073, max 1079, scanline start 1052, end 4
[ 2788.873437] nvdock[4066]: segfault at ffffffffbac63a40 ip 00005630ba56c568 sp 00007fff048c8a40 error 5 in nvdock[5630ba56c000+2000]
[ 2788.873454] Code: 48 98 48 89 05 e9 45 00 00 48 8d 3d 72 1b 00 00 e8 6b 0f 00 00 48 8b 15 d6 45 00 00 c1 e0 07 c0 f8 07 83 e0 01 c1 e0 06 89 c1 <0f> b6 02 83 e0 bf 09 c8 88 02 48 8d 3d 4f 1b 00 00 e8 40 0f 00 00
[ 2788.873558] audit: type=1701 audit(1544464681.689:64): auid=1000 uid=1000 gid=1001 ses=1 pid=4066 comm="nvdock" exe="/usr/bin/nvdock" sig=11 res=1
[ 2788.896055] audit: type=1130 audit(1544464681.712:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-4075-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2789.273429] audit: type=1131 audit(1544464682.089:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-4075-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3204.291222] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=194158 end=194159) time 777 us, min 1073, max 1079, scanline start 1058, end 1093
[ 3281.114269] bbswitch: enabling discrete graphics
[ 3281.114321] pci 0000:01:00.0: Refused to change power state, currently in D3
[ 3446.979463] bbswitch: enabling discrete graphics
[ 3446.979514] pci 0000:01:00.0: Refused to change power state, currently in D3
[ 3659.237817] audit: type=1130 audit(1544465552.056:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3669.279570] audit: type=1131 audit(1544465562.096:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
primusrun glxgears:
primus: fatal: Bumblebee daemon reported: error: Could not enable discrete graphics card
optirun glxgears:
[  630.874065] [ERROR]Cannot access secondary GPU - error: Could not enable discrete graphics card
[  630.874135] [ERROR]Aborting because fallback start is disabled.
primusrun glxspheres64:
#primus: fatal: Bumblebee daemon reported: error: Could not enable discrete graphics card
optirun glxspheres64:
[ 1736.294784] [ERROR]Cannot access secondary GPU - error: Could not enable discrete graphics card
[ 1736.294861] [ERROR]Aborting because fallback start is disabled.
  1. My attempts:
Bumblebee doesn’t work and screenfetch can’t find my GPU [link 01]:
Summary
Uninstalled bbswitch;
Uninstalled bumblebee;
Reboot;
(after the reboot, I could already see my GPU on the screenfetch output)
Installed bbswitch by package manager (using 4.19 kernel and I can verify that it did not work on 4.14);
Installed bumblebee as per this post; [see just beneath]
1. Install bumblebee for nonfree nvidia. Please run in terminal command in proper order:
sudo pacman -S virtualgl lib32-virtualgl lib32-primus primus
sudo mhwd -f -i pci video-hybrid-intel-nvidia-bumblebee
sudo systemctl enable bumblebeed
2. Reboot system:
sudo reboot
3. Next run:
4. Verify it is working
[it does not]
[Bumblebee] [NVIDIA] Error on Optimus Laptop [link 02]:
Summary
TLP was interferenig with the NVIDIA driver. Will add to discussion tread over at Archwiki
lspci | grep "NVIDIA" | cut -b -8 and append the output to RUNTIME_PM_BLACKLIST in `/etc/default/tlp
[didn’t work]
#1 [SOLVED] Dell XPS 9570 bbswitch not working, Nvdia won’t power off/on [link 03]:
Summary
SOLVED(kinda): I ditched Bumblebee in favor of nvidia-xrun. nvidia-xrun also utilizes bbswitch so I installed a fork of nvidia-xrun made by michelesr that uses kernel power management instead of bbswitch. Here is the full process:
LazyLucretia wrote:
Alright I gave nvidia-xrun a shot and it seems like a good solution until bumblebee is fixed for this model. Here is what I did:
  • Removed pcie_port_pm=off from kernel parameters (I think this parameter defaults to β€˜on’ when not supplied to kernel)
  • Uninstalled bumblebee(or bumblebee-forceunload) and bbswitch if they are installed.
  • Installed michelesr fork of nvidia-xrun using the PKGBUILD: https://paste.pound-python.org/show/Uax … Ve5U11ixm/ (as suggested by setzer22), this should also install nvidia drivers as dependencies.
  • Installed xf86-video-intel driver.
  • Create /etc/X11/xorg.conf.d/01-noautogpu.conf, /etc/X11/xorg.conf.d/20-intel.conf and /etc/tmpfiles.d/nvidia_pm.conf as suggested above by yaworski.
    /etc/X11/xorg.conf.d/01-noautogpu.conf :
Section "ServerFlags"
Option "AutoAddGPU" "off"
EndSection
/etc/X11/xorg.conf.d/20-intel.conf :
Section β€œDevice”
Identifier β€œIntel Graphics”
Driver β€œintel”
EndSection
/etc/tmpfiles.d/nvidia_pm.conf :
w /sys/bus/pci/devices/0000:01:00.0/power/control - - - - auto
- Now since bumblebee is uninstalled, /usr/lib/modprobe.d/bumblebee.conf file is also gone but we need it to stop nvidia drivers from loading at boot. Create /usr/lib/modprobe.d/bumblebee.conf with following contents:
blacklist nvidia
blacklist nvidia-drm
blacklist nvidia-modeset
blacklist nvidia-uvm
blacklist nouveau
- Reboot.
Now nvidia or nouveau modules should not be loaded on boot and Nvidia dGPU should be off. Loaded modules can be checked with 'lsmod | less' and power usage of dGPU and other system components can be checked with powertop. Power drain while idling should be below 10 Watts. Mine is around 4 W.
In order to use dGPU:
- Switch to another tty with Ctrl+Alt+F2 or another F key.
- Run 'nvidia-xrun &lt;application&gt;' and enter your password. I recommend installing a basic window manager such as openbox and running 'nvidia-xrun openbox' to be able to run and switch between apps in the same tty.
- In my case, when I try to run nvidia-xrun first time after boot, it throws some errors and quits after a few seconds. Run it again, it should work this time.
- When done, quit the applicatin. After entering root password for another time, it should unload modules and switch off the card.
- Exit tty (Ctrl+Alt+F1 or some other F key. Switching between tty's is also possible while nvidia-xrun is running.)
[I only have a photo of the result from the second tty:
#2 [SOLVED] Dell XPS 9570 bbswitch not working, Nvdia won’t power off/on [link 04]:
Summary
I can confirm the exact same problem happens on the new Dell G5 15 laptop. I was able to fix the issue by following the suggestions in this thread. Now I can use optirun/primusrun/nvidia-xrun and the nvidia card will get stopped when it’s not necessary anymore. I’ll leave a summary of the steps I followed because it took me a while to figure them out by just reading the thread.
I’ve found a way to prevent Xorg from loading nvidia module on boot. I’ve created a /etc/X11/xorg.conf.d/01-noautogpu.conf file with
EndSection
Then the iGPU needs to be added manually. I've created a /etc/X11/xorg.conf.d/20-intel.conf file with:
Section β€œDevice”
Driver β€œintel”
EndSection
I've tested this multiple times and now the nvidia module is not loaded by the Xorg at all.
I don't use bbswitch. Instead I've created /etc/tmpfiles.d/nvidia_pm.conf file with:
This switches on the kernel power management for the NVidia card. It depends on whether the nvidia module is loaded or not. The bumblebee loads the module, turning on the card when the optirun/primusrun is executed, but unfortunately it doesn't even try to unload it if bbswitch is not installed. But after manually unloading the module, the card turns off. The card is turned off after boot by default.
primus: fatal: Bumblebee daemon reported: error: Could not load GPU driver [link 05]:
Tried both of the proposed solutions (see beneath), they didn’t work:
Summary
I solved changing some lines in file /etc/bumblebee/bumblebee.conf : (In my case I’m using the version 352 of nvidia driver, change this value by your driver version)
  1. KernelDriver=nvidia-current to KernelDriver=nvidia-352
  2. LibraryPath=/usr/lib/nvidia-current:/usr/lib32/nvidia-current to LibraryPath=/usr/lib/nvidia-352:/usr/lib32/nvidia-352
  3. XorgModulePath=/usr/lib/nvidia-current/xorg,/usr/lib/xorg/modules to XorgModulePath=/usr/lib/nvidia-352/xorg,/usr/lib/xorg/modules
After that restart the system or restart the bumblebee service with:
sudo systemctl restart bumblebeed.service
To check the service status:
sudo systemctl status bumblebeed.service
Summary
new update: as I thought, changing just one line in /etc/bumblebee/bumblebee.conf actually worked out: I got everything working perfectly on updated LMDE 201403 (debian jessie based) by just adding some code to KernelDriver line. Before editing, it was like:
KernelDriver=nvidia
I just added -current to it. This is line now:
Now works fine with primusrun glxgears and optirun glxgears . Haven’t checked with anything else, have no time currently. Hope this helped, cheers. :smiley:
EDIT: Reason why bumblebee fails and β€œcannot find driver” is because of incorrect paths to nvidia driver libraries. What I do right now to make bumblebee work with any driver version I wish is changing following lines in /etc/bumblebee/bumblebee.conf file:
  1. line 22: Driver=nvidia
  2. line 55: KernelDriver=nvidia-_version_ , i.e. nvidia-352
  3. lines 58, 61: these lines contain paths to nvidia libraries and xorg modules. Paths probably start with /usr/lib/nvidia , /usr/lib32/nvidia , or /usr/lib/xorg . You should replace nvidia with nvidia-_version_ , i.e. /usr/lib/nvidia-352 . Pay attention: each line contains 2 paths, separated by colon or by comma. You should make changes to each path (DO NOT edit path that starts with /usr/lib/xorg ).
Note that if you want to use default drivers, _version_ should be current , i.e. line 52: KernelDriver=nvidia-current . I think that bumblebee comes preconfigured to use nvidia-current when package bumblebee-nvidia is installed ( sudo apt-get install bumblebee-nvidia ).
If done correctly, bumblebee should not report error finding drivers - this worked for me with numerous driver versions.
  1. What I didn’t try and why:
[ERROR]Cannot access secondary GPU: No devices detected [link 06]:
Because I don’t know how to do all these steps.
Modprobe Error: β€œCould not insert β€˜nvidia’: No such device” on linux >=4.8 [link 07]
Because I don’t know how to edit kernel parameters.
Also, I rather not tinker with the β€œdeep stuff” until I’m sure what the problem is.
I tried my best to condense all this info and avoid the post being a mess… I’m not sure if I succeeded. :sweat_smile: This is my first post, I will make changes as requested if I missed any guidelines.
Any help appreciated - I would really like to make the second GPU running!
I915 - Error Aromic update failure on pipe A
#2
Thank you for the detailed post. Well I’m far from all knowing but my suggestions on this topic would be:
You could try and use PRIME instead of bumblebee, see this tutorial with proprietary driver:
Or for the free driver see here:
https://wiki.archlinux.org/index.php/PRIME
Another alternative might be the Optimus Manager
i know you mentioned that you did add your user to the bumblebee group, but that says otherwise afaik. also im not sure how important it is to add user before enabling bumblebeed but for the sake of being sure, try the following.
sudo systemctl stop bumblebeed
sudo systemctl disable bumblebeed
sudo gpasswd -a $USER bumblebee
sudo gpasswd -a $USER video
sudo systemctl start bumblebeed
and btw, great job on the level of detail included, especially being your first post. :+1:
Thanks! :slightly_smiling_face:
Yes, I notice my mistake. I gave the wrong output because I’ve reset everything to the way it was (including removing myself from the group). I re-added myself and the output is now like this:
optirun glxgears:
(I have updated the OP to reflect this.)
I have tried the list of commands You suggested, but sadly there is no change.
#5
try primusrun, i believe it installs with bumblebee, if not sudo pacman -S primus
primusrun glxgears
afaik primusrun is the successor to optirun
#6
Yes, it was installed with bumblebee. The outputs for both glxgears and glxspheres64 are in the OP. To me it seems that everything, and I mean everything is in order except one fatal thing: the card doesn’t load. Bumblebee is running, the card is recognised. But I might be wrong, since this is out of the scope of my understanding.
#7
did you try the primusrun command instead of optirun and get same result?
if yes, i found a solution to your exact error, it involves tlp interfering with nvidia. i think this should take care of the issue.
Use lspci to identify the PCI slot information associated with the discrete GPU.
Example: lspci | grep β€œNVIDIA” | cut -b -8 will show only the PCI slot information associated with the NVIDIA card.
Copy the PCI slot information, open the /etc/default/tlp with any text editor with sudo permission. Append the arguments of RUNTIME_PM_BLACKLIST with the copied PCI slot information. Save the file, exit and reboot.
Example: sudo nano /etc/default/tlp
Note: RUNTIME_PM_BLACKLIST must be uncommented(remove # before it) if it is not already.
in terminal:
you should get an output similar to 02:00.0
then:
find the line
#RUNTIME_PM_BLACKLIST=β€œbb:dd.f 11:22.3 44:55.6”
and make it look like this:
RUNTIME_PM_BLACKLIST=β€œ02:00.0”
change the 02:00.0 to the first command’s output and then save. you may have to reboot after
dont forget to remove the # at the beginning of the line
#8
Yes, I did. In the meantime however, I did as suggested in the first reply. That very complicated solution has worked (see my following reply), thus I will keep things as they are. In the future, when I possibly reinstall the system, I will try out Your suggestion as well, since it is much easier (if it only works). If and when I do, I will report back here if I can.
Thank You for Your time and expertise, I highly appreciate it! :wink:
Well, that was quite the ride, but it works! :sunglasses: Thank You for the hint!
good, glad to hear you got it working. in my less than seasoned opinion, prime is the best and easiest way to go. better performance, no need for opti/primus/bbswitch, and it just works.
Indeed it does. :sunglasses: I will not go into detail just how satisfied I am with its performance, suffice to say that it was worth the trouble.
@mozzribo , dude can u tell me exactly the steps to install Prime , because i have the same laptop as you do with updated Bios (which i think is the problem). I mention that i am newbie on linux. I have done exactly what u did with bumblebee and nothing seems to work !!
#13
theres a link to the prime tutorial posted above, and since your new and this actually happened to someone before, please do notice that there are drop downs in that tutorial that look like " >" that contain the contents to put in each of those files specified. also, when you get step 5 only follow the directions that go with your display manager (kde uses sddm, gnome uses gdm, if your not sure, check) and dont rush, make sure you do each and every thing exactly as instructed and you’ll do fine
Thanks a lot for your advice, i ll go with the tutorial and post an update, if i finally made it
I did everything as the tutorial said and I can’t boot in Manjaro… Any suggestions?
#16
yes, i would say start a new thread but as it is there are too many that are nvidia related and another is only going to make it harder for someone else to decide which to follow.
do this:
-grab the manjaro live usb you created (make another if you dont have it)
-boot to live desktop on usb and connect to your network
-then, open a browser and come back here and i’ll work through it with you.
-let me know when youve done this
#17
I ve done it, i am ready
#18
open a terminal and input:
manjaro-chroot -a
that should put you into a comand prompt of the manjaro you already have installed like this:
==> Mounting (ManjaroLinux) [/dev/sdb2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
[dglt-6 /]#
then post output for:
mhwd -li
inxi -F
dont forget to put 3 backtics ``` before and after each output when posting it here so its formatted properly
[manjaro@manjaro-gnome ~]$ sudo manjaro-chroot -a
==> Detected systems:
 --> 0) ManjaroLinux
==> Select system to mount [0-0] :
1
==> Mounting (ManjaroLinux) [/dev/sdb5]
 --> mount: [/mnt]
mount: /mnt: /dev/sdb5 already mounted on /run/media/manjaro/7d6a133a-3e95-4877-910f-166b0705c842.
[manjaro-gnome /]# mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
          video-nvidia            2018.08.09               false            PCI
[manjaro-gnome /]# inxi -F
12System:    12Host manjaro-gnome 12Kernel 4.19.0-3-MANJARO x86_64 12bits 64 12Console N/A
           12Distro Manjaro Linux
12Machine:   12Type Laptop 12System Dell 12product G5 5587 12v N/A 12serial <filter>
           12Mobo Dell 12model 0M2MWX 12v A00 12serial <filter> 12UEFI Dell 12v 1.6.1 12date 11/01/2018
12Battery:   12ID-1 BAT0 12charge 52.1 Wh 12condition 52.1/56.0 Wh (93%)
12CPU:       12Topology 6-Core 12model Intel Core i7-8750H 12bits 64 12type MT MCP 12L2 cache 9216 KiB
           12Speed 800 MHz 12min/max 800/4100 MHz 12Core speeds (MHz) 121 800 122 800 123 800 124 800 125 800
           126 800 127 800 128 800 129 800 1210 800 1211 800 1212 801
12Graphics:  12Device-1 Intel 12driver i915 12v kernel
           12Device-2 NVIDIA GP106M [GeForce GTX 1060 Mobile] 12driver nouveau 12v kernel
           12Display 12server X.org 1.20.3 12driver nouveau 12resolution <xdpyinfo missing>
           12OpenGL 12renderer Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2) 12v 4.5 Mesa 18.2.3
12Audio:     12Device-1 Intel Cannon Lake PCH cAVS 12driver snd_hda_intel
           12Sound Server ALSA 12v k4.19.0-3-MANJARO
12Network:   12Device-1 Intel Wireless-AC 9560 [Jefferson Peak] 12driver iwlwifi
           12IF wlp0s20f3 12state up 12mac <filter>
           12Device-2 Qualcomm Atheros Killer E2400 Gigabit Ethernet 12driver alx
           12IF enp59s0 12state down 12mac <filter>
12Drives:    12Local Storage 12total 1.16 TiB 12used 6.28 GiB (0.5%)
           12ID-1 /dev/sda 12vendor Seagate 12model ST1000LM035-1RK172 12size 931.51 GiB
           12ID-2 /dev/sdb 12vendor SK Hynix 12model SC311 SATA 256GB 12size 238.47 GiB
           12ID-3 /dev/sdc 12type USB 12vendor SanDisk 12model Ultra USB 3.0 12size 14.32 GiB
12Partition: 12ID-1 / 12size 97.93 GiB 12used 6.14 GiB (6.3%) 12fs ext4 12dev /dev/sdb5
12Sensors:   12System Temperatures 12cpu 55.0 C 12mobo N/A 12gpu nouveau 12temp 511 C
           12Fan Speeds (RPM) N/A
12Info:      12Processes 289 12Uptime 18m 12Memory 15.37 GiB 12used 1.36 GiB (8.9%)
           12Client Unknown Client: systemd 12inxi 3.0.27
#20
i think i see whats wrong now, post output for the following:
cat /etc/X11/xorg.conf.d/90-mhwd.conf
cat /etc/X11/xorg.conf.d/optimus.conf
ls /etc/modprobe.d/
cat /etc/modprobe.d/nvidia.conf
cat /etc/modprobe.d/nvidia-drm.conf
