I’d like to make my GPU work, at least when I want it to, but despite the nvidia drivers being installed (via mhwd -a pci nonfree 0300) it still shows that they are not loaded and it seems that the gpu never does any work. The output of “nvidia-smi”:
| NVIDIA-SMI 460.39 Driver Version: 460.39 CUDA Version: 11.2 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 GeForce GTX 1050 Off | 00000000:01:00.0 Off | N/A | | N/A 48C P0 N/A / N/A | 0MiB / 4042MiB | 1% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | No running processes found | +-----------------------------------------------------------------------------+
nvidia-settings (it worked before, after reinstalling drivers it shows that, no matter what):
Gtk-Message: 13:37:01.227: Failed to load module “appmenu-gtk-module”
ERROR: Unable to load info from any available system
mhwd -li:
> Installed PCI configs: > -------------------------------------------------------------------------------- > NAME VERSION FREEDRIVER TYPE > -------------------------------------------------------------------------------- > video-hybrid-intel-nvidia-prime 2020.11.30 false PCI > video-modesetting 2020.01.13 true PCI
inxi -G:
Graphics: Device-1: Intel UHD Graphics 630 driver: i915 v: kernel Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 460.39 Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting resolution: 1920x1080~60Hz OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
prime-run inxi -G:
Graphics: Device-1: Intel UHD Graphics 630 driver: i915 v: kernel Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 460.39 Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting resolution: 1920x1080~60Hz OpenGL: renderer: N/A v: N/A
Running “sudo nvidia-xonfig” makes it so that after reboot the x server doesn’t load and cannot be started from tty.
How do I make the gpu work instead of integrated graphics in games and other cases? I wouldn’t mind if it worked all the time, though it’s a laptop so for energy saving reasons the ability to change gpu at will is preffered. I already tried reinstalling the drivers, tried the alternatives, the outcome is always the same - the nvidia gpu is off.
