I recently noticed my NVIDIA drivers are not running when using graphic intensive programs. When attempting to run sudo nvidia-settings I get the following error:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
I have been following the manjaro wiki Configure Graphics Cards guide for configuring my graphics card but I haven’t been able to get the drivers to load.
Below are my system’s config settings.
inxi -Fazy output
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0409a529-b6df-4ab4-ba7f-4c626f309e5c rw quiet apparmor=1
security=apparmor resume=UUID=e2216d28-95a3-4c30-b9d3-a9f01249af64
udev.log_priority=3
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel, plank
wm: xfwm v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Acer product: Aspire E5-575G v: V1.23
serial: <superuser required>
Mobo: Acer model: Ironman_SK v: V1.23 serial: <superuser required>
UEFI: Insyde v: 1.23 date: 01/16/2017
ID-1: BAT1 charge: 39.4 Wh (68.9%) condition: 57.2/61.0 Wh (93.7%)
volts: 11.2 min: 10.9 model: LGC AS16B8J type: Li-ion serial: <filter>
status: discharging
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 9 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 799 high: 800 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 799 2: 800 3: 800 4: 800
bogomips: 21607
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI Aspire E5-575G
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM107 [GeForce 940MX] vendor: Acer Incorporated ALI
Aspire E5-575G driver: N/A alternate: nouveau, nvidia_drm, nvidia
non-free: 515.xx+ status: current (as of 2022-08) arch: Maxwell
code: GMxxx process: TSMC 28nm built: 2014-19 pcie: speed: Unknown
lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0
chip-ID: 10de:179c class-ID: 0302
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 04f2:b573 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d2 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
mhwd -l -d output:
> PCI Device: /devices/pci0000:00/0000:00:1d.3/0000:04:00.1 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2016.04.20
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:1c.0/0000:01:00.0 (0302:10de:179c)
Display controller nVidia Corporation GM107 [GeForce 940MX]
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.11.04
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 7
FREEDRIVER: false
DEPENDS: video-modesetting
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.26
INFO: Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2021.11.04
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.11.26
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:5916)
Display controller Intel Corporation HD Graphics 620
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.26
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
cat /etc/X11/mhwd.d/nvidia.conf output:
## Generated by mhwd - Manjaro Hardware Detection
cat /etc/mkinitcpio.conf output:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=""
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap resume filesystems"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
cat ~/.xinitrc output
#!/bin/bash
# ~/.xinitrc
# Executed by startx (run your window manager from here)
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/etc/X11/xinit/.Xresources
sysmodmap=/etc/X11/xinit/.Xmodmap
SESSION=${1:-xfce}
# merge in defaults and keymaps
if [ -f $sysresources ]; then
xrdb -merge $sysresources
fi
if [ -f $sysmodmap ]; then
xmodmap $sysmodmap
fi
if [ -f "$userresources" ]; then
xrdb -merge "$userresources"
fi
if [ -f "$usermodmap" ]; then
xmodmap "$usermodmap"
fi
# start some nice programs
if [ -d /etc/X11/xinit/xinitrc.d ] ; then
for f in /etc/X11/xinit/xinitrc.d/?*.sh ; do
[ -x "$f" ] && . "$f"
done
unset f
fi
get_session(){
local dbus_args=(--sh-syntax --exit-with-session)
case "$SESSION" in
awesome) dbus_args+=(awesome) ;;
bspwm) dbus_args+=(bspwm-session) ;;
budgie) dbus_args+=(budgie-desktop) ;;
cinnamon) dbus_args+=(cinnamon-session) ;;
deepin) dbus_args+=(startdde) ;;
enlightenment) dbus_args+=(enlightenment_start) ;;
fluxbox) dbus_args+=(startfluxbox) ;;
gnome) dbus_args+=(gnome-session) ;;
i3|i3wm) dbus_args+=(i3 --shmlog-size 0) ;;
jwm) dbus_args+=(jwm) ;;
kde) dbus_args+=(startkde) ;;
lxde) dbus_args+=(startlxde) ;;
lxqt) dbus_args+=(lxqt-session) ;;
mate) dbus_args+=(mate-session) ;;
xfce) dbus_args+=(xfce4-session) ;;
openbox) dbus_args+=(openbox-session) ;;
*) dbus_args+=("$SESSION") ;;
esac
echo "dbus-launch ${dbus_args[*]}"
exec $(get_session)
Not sure what I’m missing. Any help would be appreciated.
