Nvidia driver issue
This topic is about the topic here: Nvidia driver conflict with bumblebbe
Since I couldn’t create a new topic I created a new one.
As cscs told me my driver should work well and there is no problem with my driver.
But I can see whenever I use “nvidia-smi” command I get the following error:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I tried to use the “nvidia-xconfig” command:
Then after starting the OS the GUI won’t start and I used the tty and then tried to start GUI by using “starts” command on tty then I got this error:
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
X.Org X Server 1.21.1.1
Current Operating System: Linux mehdi 5.15.2-2-MANJARO #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=ff3644c8-4550-44a5-913b-25bf328840c5 rw quiet apparmor=1 security=apparmor udev.log_priority=3 quiet splash acpi_backlight=vendor
Current version of pixman: 0.40.0
        Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.1.log", Time: Thu Nov 25 23:08:11 2021
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
================ WARNING WARNING WARNING WARNING ================
This server has a video driver ABI version of 25.2 that this
driver does not officially support.  Please check
http://www.nvidia.com/ for driver updates or downgrade to an X
server with a supported driver ABI.
(WW) NVIDIA: The driver will continue to load, but may behave strangely.
(WW) NVIDIA: This driver was compiled against the X.Org server SDK from commit 4c00369024c9754e670fca37804711fef2980e2f and may not be compatible with the final version of this SDK.
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
