Nvidia driver desktop taking ages to load
I have a GT 710 (my spare backup card) running on a Gigabyte X58A-UD3R mobo, X5560 CPU.
I have a Samsung 840 Pro SSD 12GB ram.
I am also dual booting with Windows 10 with linux + swap in a extended partition
Trying KDE (fresh install) I get a super long load time till the desktop appears.
If I cycle between screens 'Ctrl-Alt-F2' etc the desktop will appear fairly quickly but if left will take ages to load, the last load left alone took 7 minutes until the KDE desktop appeared.
This happens on the video-nvidia driver and the 390 driver trying the 390 and reverting to the video-nvidia seemed to make the load longer.
The video-linux driver by itself loads the desktop fairly quickly.
Trying the Deepin spin I get the same thing with the long black screen until desktop though Deepin shows the desktop much quicker the KDE.
I looked at the Nvidia driver page and the GT 710 is listed in the latest driver so the graphics card is compatible just its not booting fast for some reason.
My log from boot to when the desktop started showing is as follows:
You can see the 6 minute gap near the end which is what is happenging.
30/4/19 11:50 PM	kernel	Key type blacklist registered
30/4/19 11:50 PM	kernel	workingset: timestamp_bits=41 max_order=22 bucket_order=0
30/4/19 11:50 PM	kernel	zbud: loaded
30/4/19 11:50 PM	kernel	pstore: using zstd compression
30/4/19 11:50 PM	kernel	Key type asymmetric registered
30/4/19 11:50 PM	kernel	Asymmetric key parser 'x509' registered
30/4/19 11:50 PM	kernel	Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
30/4/19 11:50 PM	kernel	io scheduler noop registered
30/4/19 11:50 PM	kernel	io scheduler deadline registered
30/4/19 11:50 PM	kernel	io scheduler cfq registered
30/4/19 11:50 PM	kernel	io scheduler mq-deadline registered
30/4/19 11:50 PM	kernel	io scheduler kyber registered
30/4/19 11:50 PM	kernel	io scheduler bfq registered
30/4/19 11:50 PM	kernel	io scheduler bfq-sq registered (default)
30/4/19 11:50 PM	kernel	BFQ I/O-scheduler: v9 (with cgroups support)
30/4/19 11:50 PM	kernel	io scheduler bfq-mq registered
30/4/19 11:50 PM	kernel	pcieport 0000:00:1c.0: enabling device (0000 -> 0003)
30/4/19 11:50 PM	kernel	shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
30/4/19 11:50 PM	kernel	vesafb: mode is 1920x1200x32, linelength=7680, pages=0
30/4/19 11:50 PM	kernel	vesafb: scrolling: redraw
30/4/19 11:50 PM	kernel	vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
30/4/19 11:50 PM	kernel	vesafb: framebuffer at 0xef000000, mapped to 0x(____ptrval____), using 9024k, total 9024k
30/4/19 11:50 PM	kernel	fbcon: Deferring console take-over
30/4/19 11:50 PM	kernel	fb0: VESA VGA frame buffer device
30/4/19 11:50 PM	kernel	intel_idle: MWAIT substates: 0x1120
30/4/19 11:50 PM	kernel	intel_idle: v0.4.1 model 0x2C
30/4/19 11:50 PM	kernel	intel_idle: lapic_timer_reliable_states 0xffffffff
30/4/19 11:50 PM	kernel	input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
30/4/19 11:50 PM	kernel	ACPI: Power Button [PWRB]
30/4/19 11:50 PM	kernel	input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
30/4/19 11:50 PM	kernel	ACPI: Power Button [PWRF]
30/4/19 11:50 PM	kernel	Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
30/4/19 11:50 PM	kernel	usbcore: registered new interface driver usbserial_generic
30/4/19 11:50 PM	kernel	usbserial: USB Serial support registered for generic
30/4/19 11:50 PM	kernel	rtc_cmos 00:01: RTC can wake from S4
30/4/19 11:50 PM	kernel	rtc_cmos 00:01: registered as rtc0
30/4/19 11:50 PM	kernel	rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
30/4/19 11:50 PM	kernel	ledtrig-cpu: registered to indicate activity on CPUs
30/4/19 11:50 PM	kernel	NET: Registered protocol family 10
30/4/19 11:50 PM	kernel	Segment Routing with IPv6
30/4/19 11:50 PM	kernel	NET: Registered protocol family 17
30/4/19 11:50 PM	kernel	RAS: Correctable Errors collector initialized.
30/4/19 11:50 PM	kernel	microcode: sig=0x206c2, pf=0x1, revision=0x1f
30/4/19 11:50 PM	kernel	microcode: Microcode Update Driver: v2.2.
30/4/19 11:50 PM	kernel	sched_clock: Marking stable (1200985171, 217897)->(1321263751, -120060683)
30/4/19 11:50 PM	kernel	registered taskstats version 1
30/4/19 11:50 PM	kernel	Loading compiled-in X.509 certificates
30/4/19 11:50 PM	kernel	Loaded X.509 cert 'Build time autogenerated kernel key: d345ff620d1eca04703d453b132463f2951a4050'
30/4/19 11:50 PM	kernel	zswap: loaded using pool lzo/zbud
30/4/19 11:50 PM	kernel	Key type big_key registered
30/4/19 11:50 PM	kernel	  Magic number: 15:620:842
30/4/19 11:50 PM	kernel	rtc_cmos 00:01: setting system clock to 2019-04-30 15:50:52 UTC (1556639452)
30/4/19 11:50 PM	kernel	Freeing unused decrypted memory: 2040K
30/4/19 11:50 PM	kernel	Freeing unused kernel image memory: 1536K
30/4/19 11:50 PM	kernel	Write protecting the kernel read-only data: 18432k
30/4/19 11:50 PM	kernel	Freeing unused kernel image memory: 2008K
30/4/19 11:50 PM	kernel	Freeing unused kernel image memory: 400K
30/4/19 11:50 PM	kernel	x86/mm: Checked W+X mappings: passed, no W+X pages found.
30/4/19 11:50 PM	kernel	x86/mm: Checking user space page tables
30/4/19 11:50 PM	kernel	Run /init as init process
30/4/19 11:50 PM	kernel	i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
30/4/19 11:50 PM	kernel	i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
30/4/19 11:50 PM	kernel	serio: i8042 KBD port at 0x60,0x64 irq 1
30/4/19 11:50 PM	kernel	ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
30/4/19 11:50 PM	kernel	ehci-pci: EHCI PCI platform driver
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1a.7: EHCI Host Controller
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1a.7: debug port 1
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1a.7: irq 18, io mem 0xfbffe000
30/4/19 11:50 PM	kernel	SCSI subsystem initialized
30/4/19 11:50 PM	kernel	libata version 3.00 loaded.
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
30/4/19 11:50 PM	kernel	usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb1: Product: EHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb1: Manufacturer: Linux 4.19.36-1-MANJARO ehci_hcd
30/4/19 11:50 PM	kernel	usb usb1: SerialNumber: 0000:00:1a.7
30/4/19 11:50 PM	kernel	hub 1-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 1-0:1.0: 6 ports detected
30/4/19 11:50 PM	kernel	xhci_hcd 0000:02:00.0: xHCI Host Controller
30/4/19 11:50 PM	kernel	xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 2
30/4/19 11:50 PM	kernel	xhci_hcd 0000:02:00.0: hcc params 0x014042cb hci version 0x96 quirks 0x0000000000000004
30/4/19 11:50 PM	kernel	usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb2: Product: xHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb2: Manufacturer: Linux 4.19.36-1-MANJARO xhci-hcd
30/4/19 11:50 PM	kernel	usb usb2: SerialNumber: 0000:02:00.0
30/4/19 11:50 PM	kernel	hub 2-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 2-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 3
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1d.7: EHCI Host Controller
30/4/19 11:50 PM	kernel	xhci_hcd 0000:02:00.0: Host supports USB 3.0  SuperSpeed
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 4
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1d.7: debug port 1
30/4/19 11:50 PM	kernel	scsi host0: pata_jmicron
30/4/19 11:50 PM	kernel	ahci 0000:00:1f.2: version 3.0
30/4/19 11:50 PM	kernel	ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
30/4/19 11:50 PM	kernel	ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
30/4/19 11:50 PM	kernel	ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ccc ems
30/4/19 11:50 PM	kernel	usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
30/4/19 11:50 PM	kernel	usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb3: Product: xHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb3: Manufacturer: Linux 4.19.36-1-MANJARO xhci-hcd
30/4/19 11:50 PM	kernel	usb usb3: SerialNumber: 0000:02:00.0
30/4/19 11:50 PM	kernel	hub 3-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 3-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1d.7: irq 23, io mem 0xfbffd000
30/4/19 11:50 PM	kernel	scsi host1: pata_jmicron
30/4/19 11:50 PM	kernel	ata1: PATA max UDMA/100 cmd 0xbf00 ctl 0xbe00 bmdma 0xbb00 irq 18
30/4/19 11:50 PM	kernel	ata2: PATA max UDMA/100 cmd 0xbd00 ctl 0xbc00 bmdma 0xbb08 irq 18
30/4/19 11:50 PM	kernel	pata_jmicron 0000:06:00.1: enabling device (0000 -> 0001)
30/4/19 11:50 PM	kernel	scsi host2: pata_jmicron
30/4/19 11:50 PM	kernel	scsi host3: pata_jmicron
30/4/19 11:50 PM	kernel	ata3: PATA max UDMA/100 cmd 0xaf00 ctl 0xae00 bmdma 0xab00 irq 16
30/4/19 11:50 PM	kernel	ata4: PATA max UDMA/100 cmd 0xad00 ctl 0xac00 bmdma 0xab08 irq 16
30/4/19 11:50 PM	kernel	ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
30/4/19 11:50 PM	kernel	usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb4: Product: EHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb4: Manufacturer: Linux 4.19.36-1-MANJARO ehci_hcd
30/4/19 11:50 PM	kernel	usb usb4: SerialNumber: 0000:00:1d.7
30/4/19 11:50 PM	kernel	hub 4-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 4-0:1.0: 6 ports detected
30/4/19 11:50 PM	kernel	uhci_hcd: USB Universal Host Controller Interface driver
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.0: UHCI Host Controller
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 5
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.0: detected 2 ports
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff00
30/4/19 11:50 PM	kernel	usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb5: Product: UHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb5: Manufacturer: Linux 4.19.36-1-MANJARO uhci_hcd
30/4/19 11:50 PM	kernel	usb usb5: SerialNumber: 0000:00:1a.0
30/4/19 11:50 PM	kernel	hub 5-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 5-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.1: UHCI Host Controller
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 6
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.1: detected 2 ports
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000fe00
30/4/19 11:50 PM	kernel	usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb6: Product: UHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb6: Manufacturer: Linux 4.19.36-1-MANJARO uhci_hcd
30/4/19 11:50 PM	kernel	usb usb6: SerialNumber: 0000:00:1a.1
30/4/19 11:50 PM	kernel	hub 6-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 6-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.2: UHCI Host Controller
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 7
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.2: detected 2 ports
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000fd00
30/4/19 11:50 PM	kernel	usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb7: Product: UHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb7: Manufacturer: Linux 4.19.36-1-MANJARO uhci_hcd
30/4/19 11:50 PM	kernel	usb usb7: SerialNumber: 0000:00:1a.2
30/4/19 11:50 PM	kernel	hub 7-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 7-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.0: UHCI Host Controller
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 8
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.0: detected 2 ports
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fc00
30/4/19 11:50 PM	kernel	usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb8: Product: UHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb8: Manufacturer: Linux 4.19.36-1-MANJARO uhci_hcd
30/4/19 11:50 PM	kernel	usb usb8: SerialNumber: 0000:00:1d.0
30/4/19 11:50 PM	kernel	hub 8-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 8-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.1: UHCI Host Controller
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 9
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.1: detected 2 ports
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fb00
30/4/19 11:50 PM	kernel	usb usb9: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb9: Product: UHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb9: Manufacturer: Linux 4.19.36-1-MANJARO uhci_hcd
30/4/19 11:50 PM	kernel	usb usb9: SerialNumber: 0000:00:1d.1
30/4/19 11:50 PM	kernel	hub 9-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 9-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.2: UHCI Host Controller
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 10
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.2: detected 2 ports
30/4/19 11:50 PM	kernel	uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fa00
30/4/19 11:50 PM	kernel	usb usb10: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
30/4/19 11:50 PM	kernel	usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
30/4/19 11:50 PM	kernel	usb usb10: Product: UHCI Host Controller
30/4/19 11:50 PM	kernel	usb usb10: Manufacturer: Linux 4.19.36-1-MANJARO uhci_hcd
30/4/19 11:50 PM	kernel	usb usb10: SerialNumber: 0000:00:1d.2
30/4/19 11:50 PM	kernel	hub 10-0:1.0: USB hub found
30/4/19 11:50 PM	kernel	hub 10-0:1.0: 2 ports detected
30/4/19 11:50 PM	kernel	input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
30/4/19 11:50 PM	kernel	firewire_ohci 0000:08:06.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
30/4/19 11:50 PM	kernel	scsi host4: ahci
30/4/19 11:50 PM	kernel	scsi host5: ahci
30/4/19 11:50 PM	kernel	scsi host6: ahci
30/4/19 11:50 PM	kernel	scsi host7: ahci
30/4/19 11:50 PM	kernel	scsi host8: ahci
30/4/19 11:50 PM	kernel	scsi host9: ahci
30/4/19 11:50 PM	kernel	ata5: SATA max UDMA/133 abar m2048@0xfbffc000 port 0xfbffc100 irq 32
30/4/19 11:50 PM	kernel	ata6: SATA max UDMA/133 abar m2048@0xfbffc000 port 0xfbffc180 irq 32
30/4/19 11:50 PM	kernel	ata7: SATA max UDMA/133 abar m2048@0xfbffc000 port 0xfbffc200 irq 32
30/4/19 11:50 PM	kernel	ata8: SATA max UDMA/133 abar m2048@0xfbffc000 port 0xfbffc280 irq 32
30/4/19 11:50 PM	kernel	ata9: SATA max UDMA/133 abar m2048@0xfbffc000 port 0xfbffc300 irq 32
30/4/19 11:50 PM	kernel	ata10: SATA max UDMA/133 abar m2048@0xfbffc000 port 0xfbffc380 irq 32
30/4/19 11:50 PM	kernel	ahci 0000:01:00.0: AHCI 0001.0200 32 slots 8 ports 6 Gbps 0xff impl SATA mode
30/4/19 11:50 PM	kernel	ahci 0000:01:00.0: flags: 64bit ncq pio
30/4/19 11:50 PM	kernel	scsi host10: ahci
30/4/19 11:50 PM	kernel	scsi host11: ahci
30/4/19 11:50 PM	kernel	scsi host12: ahci
30/4/19 11:50 PM	kernel	scsi host13: ahci
30/4/19 11:50 PM	kernel	scsi host14: ahci
30/4/19 11:50 PM	kernel	scsi host15: ahci
30/4/19 11:50 PM	kernel	scsi host16: ahci
30/4/19 11:50 PM	kernel	scsi host17: ahci
30/4/19 11:50 PM	kernel	ata11: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff100 irq 33
30/4/19 11:50 PM	kernel	ata12: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff180 irq 33
30/4/19 11:50 PM	kernel	ata13: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff200 irq 33
30/4/19 11:50 PM	kernel	ata14: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff280 irq 33
30/4/19 11:50 PM	kernel	ata15: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff300 irq 33
30/4/19 11:50 PM	kernel	ata16: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff380 irq 33
30/4/19 11:50 PM	kernel	ata17: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff400 irq 33
30/4/19 11:50 PM	kernel	ata18: SATA max UDMA/133 abar m2048@0xfbaff000 port 0xfbaff480 irq 33
30/4/19 11:50 PM	kernel	ahci 0000:05:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
30/4/19 11:50 PM	kernel	ahci 0000:05:00.0: flags: 64bit ncq pm led clo pmp pio slum part
30/4/19 11:50 PM	kernel	scsi host18: ahci
30/4/19 11:50 PM	kernel	scsi host19: ahci
30/4/19 11:50 PM	kernel	ata19: SATA max UDMA/133 abar m8192@0xfb9fe000 port 0xfb9fe100 irq 17
30/4/19 11:50 PM	kernel	ata20: SATA max UDMA/133 abar m8192@0xfb9fe000 port 0xfb9fe180 irq 17
30/4/19 11:50 PM	kernel	ahci 0000:06:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
30/4/19 11:50 PM	kernel	ahci 0000:06:00.0: flags: 64bit ncq pm led clo pmp pio slum part
30/4/19 11:50 PM	kernel	scsi host20: ahci
30/4/19 11:50 PM	kernel	scsi host21: ahci
30/4/19 11:50 PM	kernel	ata21: SATA max UDMA/133 abar m8192@0xfbefe000 port 0xfbefe100 irq 19
30/4/19 11:50 PM	kernel	ata22: SATA max UDMA/133 abar m8192@0xfbefe000 port 0xfbefe180 irq 19
30/4/19 11:50 PM	kernel	ata5: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	tsc: Refined TSC clocksource calibration: 2664.772 MHz
30/4/19 11:50 PM	kernel	clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26693fd9f3c, max_idle_ns: 440795229057 ns
30/4/19 11:50 PM	kernel	clocksource: Switched to clocksource tsc
30/4/19 11:50 PM	kernel	ata17: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata16: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata18: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
30/4/19 11:50 PM	kernel	ata14: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata15: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata13: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata18.00: ATAPI: MARVELL VIRTUALL, 1.09, max UDMA/66
30/4/19 11:50 PM	kernel	ata12: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata18.00: configured for UDMA/66
30/4/19 11:50 PM	kernel	ata11: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata19: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata20: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata22: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata21: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	usb 5-2: new full-speed USB device number 2 using uhci_hcd
30/4/19 11:50 PM	kernel	firewire_core 0000:08:06.0: created device fw0: GUID 003a2933001c6f65, S400
30/4/19 11:50 PM	kernel	usb 5-2: New USB device found, idVendor=046d, idProduct=c246, bcdDevice=70.03
30/4/19 11:50 PM	kernel	usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
30/4/19 11:50 PM	kernel	usb 5-2: Product: G300s Optical Gaming Mouse
30/4/19 11:50 PM	kernel	usb 5-2: Manufacturer: Logitech
30/4/19 11:50 PM	kernel	hidraw: raw HID events driver (C) Jiri Kosina
30/4/19 11:50 PM	kernel	usbcore: registered new interface driver usbhid
30/4/19 11:50 PM	kernel	usbhid: USB HID core driver
30/4/19 11:50 PM	kernel	input: Logitech G300s Optical Gaming Mouse as /devices/pci0000:00/0000:00:1a.0/usb5/5-2/5-2:1.0/0003:046D:C246.0001/input/input3
30/4/19 11:50 PM	kernel	hid-generic 0003:046D:C246.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech G300s Optical Gaming Mouse] on usb-0000:00:1a.0-2/input0
30/4/19 11:50 PM	kernel	input: Logitech G300s Optical Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:1a.0/usb5/5-2/5-2:1.1/0003:046D:C246.0002/input/input4
30/4/19 11:50 PM	kernel	input: Logitech G300s Optical Gaming Mouse as /devices/pci0000:00/0000:00:1a.0/usb5/5-2/5-2:1.1/0003:046D:C246.0002/input/input5
30/4/19 11:50 PM	kernel	hid-generic 0003:046D:C246.0002: input,hiddev0,hidraw1: USB HID v1.10 Keyboard [Logitech G300s Optical Gaming Mouse] on usb-0000:00:1a.0-2/input1
30/4/19 11:50 PM	kernel	ata6: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata7: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata8: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	ata9: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
30/4/19 11:50 PM	kernel	ata9.00: NCQ Send/Recv Log not supported
30/4/19 11:50 PM	kernel	ata9.00: ATA-9: Samsung SSD 840 PRO Series, DXM06B0Q, max UDMA/133
30/4/19 11:50 PM	kernel	ata9.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 32), AA
30/4/19 11:50 PM	kernel	ata9.00: configured for UDMA/133
30/4/19 11:50 PM	kernel	scsi 8:0:0:0: Direct-Access     ATA      Samsung SSD 840  6B0Q PQ: 0 ANSI: 5
30/4/19 11:50 PM	kernel	ata9.00: Enabling discard_zeroes_data
30/4/19 11:50 PM	kernel	sd 8:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
30/4/19 11:50 PM	kernel	sd 8:0:0:0: [sda] Write Protect is off
30/4/19 11:50 PM	kernel	sd 8:0:0:0: [sda] Mode Sense: 00 3a 00 00
30/4/19 11:50 PM	kernel	sd 8:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
30/4/19 11:50 PM	kernel	 sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
30/4/19 11:50 PM	kernel	sd 8:0:0:0: [sda] Attached SCSI disk
30/4/19 11:50 PM	kernel	ata10: SATA link down (SStatus 0 SControl 300)
30/4/19 11:50 PM	kernel	scsi 17:0:0:0: Processor         Marvell  91xx Config      1.01 PQ: 0 ANSI: 5
30/4/19 11:50 PM	kernel	PM: Image not found (code -22)
30/4/19 11:50 PM	kernel	EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
30/4/19 11:50 PM	kernel	random: fast init done
30/4/19 11:50 PM	systemd	systemd 242.16-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
30/4/19 11:50 PM	systemd	Detected architecture x86-64.
30/4/19 11:50 PM	systemd	Set hostname to <Linux-px>.
30/4/19 11:50 PM	kernel	random: systemd: uninitialized urandom read (16 bytes read)
30/4/19 11:50 PM	systemd	Started Dispatch Password Requests to Console Directory Watch.
30/4/19 11:50 PM	systemd	Listening on Process Core Dump Socket.
30/4/19 11:50 PM	systemd	Listening on udev Kernel Socket.
30/4/19 11:50 PM	systemd	Listening on initctl Compatibility Named Pipe.
30/4/19 11:50 PM	systemd	Listening on Device-mapper event daemon FIFOs.
30/4/19 11:50 PM	systemd	Listening on Journal Socket.
30/4/19 11:50 PM	systemd	Starting Load Kernel Modules...
30/4/19 11:50 PM	kernel	EXT4-fs (sda5): re-mounted. Opts: discard
30/4/19 11:50 PM	kernel	version 39.2
30/4/19 11:50 PM	kernel	ipmi device interface
30/4/19 11:50 PM	kernel	nvidia: loading out-of-tree module taints kernel.
30/4/19 11:50 PM	kernel	nvidia: module license 'NVIDIA' taints kernel.
30/4/19 11:50 PM	kernel	Disabling lock debugging due to kernel taint
30/4/19 11:50 PM	kernel	nvidia: module verification failed: signature and/or required key missing - tainting kernel
30/4/19 11:50 PM	kernel	nvidia-nvlink: Nvlink Core is being initialized, major device number 239
30/4/19 11:50 PM	kernel	nvidia 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
30/4/19 11:50 PM	kernel	NVRM: loading NVIDIA UNIX x86_64 Kernel Module  418.56  Fri Mar 15 12:59:26 CDT 2019
30/4/19 11:50 PM	systemd-journald	Journal started
30/4/19 11:50 PM	systemd-journald	Runtime journal (/run/log/journal/1a41a8416caf4928ba4f9fe4adbe94d3) is 8.0M, max 600.2M, 592.2M free.
30/4/19 11:50 PM	systemd-modules-load	Inserted module 'crypto_user'
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd-modules-load	Inserted module 'nvidia'
30/4/19 11:50 PM	systemd	Starting Flush Journal to Persistent Storage...
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.170:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	Linux agpgart interface v0.103
30/4/19 11:50 PM	systemd-journald	Time spent on flushing to /var is 89.564ms for 926 entries.
30/4/19 11:50 PM	systemd-journald	System journal (/var/log/journal/1a41a8416caf4928ba4f9fe4adbe94d3) is 32.0M, max 4.0G, 3.9G free.
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.204:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  418.56  Fri Mar 15 12:32:40 CDT 2019
30/4/19 11:50 PM	kernel	[drm] [nvidia-drm] [GPU ID 0x00000300] Loading driver
30/4/19 11:50 PM	kernel	[drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:03:00.0 on minor 0
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.257:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.274:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	EDAC MC0: Giving out device to module i7core_edac.c controller i7 core #0: DEV 0000:3f:03.0 (INTERRUPT)
30/4/19 11:50 PM	kernel	EDAC PCI0: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:3f:03.0 (POLLED)
30/4/19 11:50 PM	kernel	EDAC i7core: Driver loaded, 1 memory controller(s) found.
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.294:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x000000000000042C-0x000000000000042D (\GP2C) (20180810/utaddress-213)
30/4/19 11:50 PM	kernel	ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
30/4/19 11:50 PM	kernel	lpc_ich: Resource conflict(s) found affecting gpio_ich
30/4/19 11:50 PM	kernel	r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
30/4/19 11:50 PM	kernel	r8168 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
30/4/19 11:50 PM	kernel	r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
30/4/19 11:50 PM	kernel	r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
 This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
 This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
30/4/19 11:50 PM	kernel	input: PC Speaker as /devices/platform/pcspkr/input/input6
30/4/19 11:50 PM	kernel	gpio_ich: GPIO from 451 to 511 on gpio_ich
30/4/19 11:50 PM	kernel	r8168 0000:07:00.0 enp7s0: renamed from eth0
30/4/19 11:50 PM	kernel	i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
30/4/19 11:50 PM	kernel	iTCO_vendor_support: vendor-support=0
30/4/19 11:50 PM	kernel	iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
30/4/19 11:50 PM	kernel	iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
30/4/19 11:50 PM	kernel	cryptd: max_cpu_qlen set to 1000
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Started udev Kernel Device Manager.
30/4/19 11:50 PM	systemd-modules-load	Inserted module 'nvidia_drm'
30/4/19 11:50 PM	systemd-modules-load	Inserted module 'uinput'
30/4/19 11:50 PM	systemd	Started Load Kernel Modules.
30/4/19 11:50 PM	systemd	Starting Apply Kernel Variables...
30/4/19 11:50 PM	systemd	Condition check resulted in FUSE Control File System being skipped.
30/4/19 11:50 PM	systemd	Mounting Kernel Configuration File System...
30/4/19 11:50 PM	systemd	Mounted Kernel Configuration File System.
30/4/19 11:50 PM	systemd	Started Apply Kernel Variables.
30/4/19 11:50 PM	systemd	Started Flush Journal to Persistent Storage.
30/4/19 11:50 PM	systemd-udevd	link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
30/4/19 11:50 PM	systemd-udevd	Using default interface naming scheme 'v240'.
30/4/19 11:50 PM	mtp-probe	checking bus 5, device 2: "/sys/devices/pci0000:00/0000:00:1a.0/usb5/5-2"
30/4/19 11:50 PM	mtp-probe	bus: 5, device: 2 was not an MTP device
30/4/19 11:50 PM	kernel	SSE version of gcm_enc/dec engaged.
30/4/19 11:50 PM	systemd-vconsole-setup	/usr/bin/loadkeys failed with exit status 1.
30/4/19 11:50 PM	systemd-vconsole-setup	KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
30/4/19 11:50 PM	systemd-vconsole-setup	Fonts will not be copied to remaining consoles
30/4/19 11:50 PM	systemd-udevd	Process '/usr/lib/systemd/systemd-vconsole-setup' failed with exit code 1.
30/4/19 11:50 PM	systemd	Found device Samsung_SSD_840_PRO_Series 6.
30/4/19 11:50 PM	kernel	mousedev: PS/2 mouse device common for all mice
30/4/19 11:50 PM	kernel	snd_hda_intel 0000:03:00.1: Disabling MSI
30/4/19 11:50 PM	kernel	snd_hda_intel 0000:03:00.1: Handle vga_switcheroo audio client
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC889: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:    mono: mono_out=0x0
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:    dig-out=0x11/0x1e
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:    inputs:
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:      Front Mic=0x19
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:      Rear Mic=0x18
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:      Line=0x1a
30/4/19 11:50 PM	kernel	snd_hda_codec_realtek hdaudioC0D2:    dig-in=0x1f
30/4/19 11:50 PM	systemd	Activating swap /dev/disk/by-uuid/d81af167-9fbc-43bc-b695-8cf8585b7031...
30/4/19 11:50 PM	kernel	input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
30/4/19 11:50 PM	kernel	input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
30/4/19 11:50 PM	kernel	input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
30/4/19 11:50 PM	kernel	input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
30/4/19 11:50 PM	kernel	input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
30/4/19 11:50 PM	kernel	input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
30/4/19 11:50 PM	kernel	input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
30/4/19 11:50 PM	kernel	input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
30/4/19 11:50 PM	kernel	Adding 15357948k swap on /dev/sda6.  Priority:-2 extents:1 across:15357948k SSDscFS
30/4/19 11:50 PM	systemd	Activated swap /dev/disk/by-uuid/d81af167-9fbc-43bc-b695-8cf8585b7031.
30/4/19 11:50 PM	systemd	Condition check resulted in Rebuild Hardware Database being skipped.
30/4/19 11:50 PM	systemd	Condition check resulted in File System Check on Root Device being skipped.
30/4/19 11:50 PM	systemd	Condition check resulted in First Boot Wizard being skipped.
30/4/19 11:50 PM	systemd	Condition check resulted in Create System Users being skipped.
30/4/19 11:50 PM	systemd	Reached target Swap.
30/4/19 11:50 PM	kernel	kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
30/4/19 11:50 PM	systemd-udevd	Process '/usr/bin/alsactl restore 0' failed with exit code 99.
30/4/19 11:50 PM	systemd	Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Reached target Local File Systems (Pre).
30/4/19 11:50 PM	systemd	Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.904:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Mounting /tmp...
30/4/19 11:50 PM	systemd	Mounted /tmp.
30/4/19 11:50 PM	systemd	Reached target Local File Systems.
30/4/19 11:50 PM	systemd	Starting Create Volatile Files and Directories...
30/4/19 11:50 PM	systemd	Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
30/4/19 11:50 PM	systemd	Condition check resulted in Commit a transient machine-id on disk being skipped.
30/4/19 11:50 PM	systemd	Started Create Volatile Files and Directories.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Condition check resulted in Rebuild Journal Catalog being skipped.
30/4/19 11:50 PM	systemd	Condition check resulted in Update is Completed being skipped.
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.934:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Starting Update UTMP about System Boot/Shutdown...
30/4/19 11:50 PM	audit	SYSTEM_BOOT pid=530 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	audit: type=1127 audit(1556639456.944:9): pid=530 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Started Update UTMP about System Boot/Shutdown.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Reached target System Initialization.
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639456.947:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Started Daily verification of password and group files.
30/4/19 11:50 PM	systemd	Started Daily man-db regeneration.
30/4/19 11:50 PM	systemd	Started Daily rotation of log files.
30/4/19 11:50 PM	systemd	Listening on D-Bus System Message Bus Socket.
30/4/19 11:50 PM	systemd	Started CUPS Scheduler.
30/4/19 11:50 PM	systemd	Reached target Paths.
30/4/19 11:50 PM	systemd	Listening on CUPS Scheduler.
30/4/19 11:50 PM	systemd	Starting Mark boot as indeterminate...
30/4/19 11:50 PM	systemd	Started Daily Cleanup of Temporary Directories.
30/4/19 11:50 PM	systemd	Reached target Timers.
30/4/19 11:50 PM	systemd	Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
30/4/19 11:50 PM	systemd	Reached target Sockets.
30/4/19 11:50 PM	systemd	Reached target Basic System.
30/4/19 11:50 PM	systemd	Started Periodic Command Scheduler.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Condition check resulted in Manage Sound Card State (restore and store) being skipped.
30/4/19 11:50 PM	systemd	Starting Modem Manager...
30/4/19 11:50 PM	crond	(CRON) STARTUP (1.5.4)
30/4/19 11:50 PM	crond	(CRON) INFO (Syslog will be used instead of sendmail.)
30/4/19 11:50 PM	crond	(CRON) INFO (RANDOM_DELAY will be scaled with factor 78% if used.)
30/4/19 11:50 PM	systemd	Starting Login Service...
30/4/19 11:50 PM	crond	(CRON) INFO (running with inotify support)
30/4/19 11:50 PM	systemd	Started D-Bus System Message Bus.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Starting Network Manager...
30/4/19 11:50 PM	systemd	Starting Avahi mDNS/DNS-SD Stack...
30/4/19 11:50 PM	systemd	Condition check resulted in Save/Restore Sound Card State being skipped.
30/4/19 11:50 PM	systemd	Reached target Sound Card.
30/4/19 11:50 PM	avahi-daemon	Found user 'avahi' (UID 975) and group 'avahi' (GID 975).
30/4/19 11:50 PM	ModemManager	<info>  ModemManager (version 1.10.0) starting in system bus...
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.0229] NetworkManager (version 1.18.0-1) is starting... (for the first time)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.0230] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
30/4/19 11:50 PM	systemd	grub-boot-indeterminate.service: Succeeded.
30/4/19 11:50 PM	systemd	Started Mark boot as indeterminate.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	audit	SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Reached target Offline System Update (Pre).
30/4/19 11:50 PM	avahi-daemon	Successfully dropped root privileges.
30/4/19 11:50 PM	avahi-daemon	avahi-daemon 0.7 starting up.
30/4/19 11:50 PM	dbus-daemon	[system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.2' (uid=0 pid=533 comm="/usr/bin/ModemManager ")
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.0324] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.0325] manager[0x55c242be80a0]: monitoring kernel firmware directory '/lib/firmware'.
30/4/19 11:50 PM	systemd	Started Network Manager.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Started Avahi mDNS/DNS-SD Stack.
30/4/19 11:50 PM	avahi-daemon	Successfully called chroot().
30/4/19 11:50 PM	systemd	Reached target Network.
30/4/19 11:50 PM	avahi-daemon	Successfully dropped remaining capabilities.
30/4/19 11:50 PM	avahi-daemon	No service file found in /etc/avahi/services.
30/4/19 11:50 PM	dbus-daemon	[system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=536 comm="/usr/bin/NetworkManager --no-daemon ")
30/4/19 11:50 PM	avahi-daemon	Network interface enumeration completed.
30/4/19 11:50 PM	systemd	Starting Permit User Sessions...
30/4/19 11:50 PM	avahi-daemon	Server startup complete. Host name is Linux-px.local. Local service cookie is 2841639405.
30/4/19 11:50 PM	systemd	Starting Authorization Manager...
30/4/19 11:50 PM	systemd	Starting Hostname Service...
30/4/19 11:50 PM	systemd	Started Permit User Sessions.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	polkitd	Started polkitd version 0.116
30/4/19 11:50 PM	kernel	input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input15
30/4/19 11:50 PM	kernel	input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input16
30/4/19 11:50 PM	systemd-udevd	Process '/usr/bin/alsactl restore 1' failed with exit code 99.
30/4/19 11:50 PM	polkitd	Loading rules from directory /etc/polkit-1/rules.d
30/4/19 11:50 PM	polkitd	Loading rules from directory /usr/share/polkit-1/rules.d
30/4/19 11:50 PM	polkitd	Finished loading, compiling and executing 5 rules
30/4/19 11:50 PM	dbus-daemon	[system] Successfully activated service 'org.freedesktop.PolicyKit1'
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Started Authorization Manager.
30/4/19 11:50 PM	polkitd	Acquired the name org.freedesktop.PolicyKit1 on the system bus
30/4/19 11:50 PM	systemd	Started Modem Manager.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd-logind	New seat seat0.
30/4/19 11:50 PM	systemd-logind	Watching system buttons on /dev/input/event1 (Power Button)
30/4/19 11:50 PM	systemd-logind	Watching system buttons on /dev/input/event0 (Power Button)
30/4/19 11:50 PM	systemd-logind	Watching system buttons on /dev/input/event4 (Logitech G300s Optical Gaming Mouse Keyboard)
30/4/19 11:50 PM	dbus-daemon	[system] Successfully activated service 'org.freedesktop.hostname1'
30/4/19 11:50 PM	systemd	Started Hostname Service.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	kauditd_printk_skb: 9 callbacks suppressed
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639457.430:20): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4545] hostname: hostname: using hostnamed
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4546] hostname: hostname changed from (none) to "Linux-px"
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4551] dns-mgr[0x55c242ba9210]: init: dns=default,systemd-resolved rc-manager=symlink
30/4/19 11:50 PM	dbus-daemon	[system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=536 comm="/usr/bin/NetworkManager --no-daemon ")
30/4/19 11:50 PM	systemd	Starting Network Manager Script Dispatcher Service...
30/4/19 11:50 PM	dbus-daemon	[system] Successfully activated service 'org.freedesktop.nm_dispatcher'
30/4/19 11:50 PM	systemd	Started Network Manager Script Dispatcher Service.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4883] settings: Loaded settings plugin: NMSKeyfilePlugin (internal)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4894] settings: Loaded settings plugin: NMSIbftPlugin ("/usr/lib/NetworkManager/1.18.0-1/libnm-settings-plugin-ibft.so")
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639457.484:21): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4919] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4921] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4923] manager: Networking is enabled by state file
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4931] dhcp-init: Using DHCP client 'internal'
30/4/19 11:50 PM	nm-dispatcher	req:1 'hostname': new request (0 scripts)
30/4/19 11:50 PM	nm-dispatcher	req:1 'hostname': completed: no scripts
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.4989] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-bluetooth.so)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5007] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-wifi.so)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5016] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-wwan.so)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5034] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-ovs.so)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5052] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-adsl.so)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5178] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-team.so)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5186] device (lo): carrier: link connected
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5189] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5198] manager: (enp7s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5225] keyfile: add connection /var/run/NetworkManager/system-connections/Wired connection 1.nmconnection (6afa3040-6cdb-3251-967e-449dc4b23c6c,"Wired connection 1")
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5240] settings: (enp7s0): created default wired connection 'Wired connection 1'
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.5247] device (enp7s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
30/4/19 11:50 PM	kernel	IPv6: ADDRCONF(NETDEV_UP): enp7s0: link is not ready
30/4/19 11:50 PM	kernel	enp7s0: 0xffffb395c1a6d000, 1c:6f:65:3e:14:23, IRQ 34
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.7297] ovsdb: Could not connect: No such file or directory
30/4/19 11:50 PM	NetworkManager	<info>  [1556639457.7316] modem-manager: ModemManager available
30/4/19 11:50 PM	nm-dispatcher	req:2 'connectivity-change': new request (0 scripts)
30/4/19 11:50 PM	nm-dispatcher	req:2 'connectivity-change': completed: no scripts
30/4/19 11:50 PM	systemd-logind	Watching system buttons on /dev/input/event2 (AT Translated Set 2 keyboard)
30/4/19 11:50 PM	systemd	Started Login Service.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639457.937:22): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Started Simple Desktop Display Manager.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Reached target Multi-User System.
30/4/19 11:50 PM	systemd	Starting TLP system startup/shutdown...
30/4/19 11:50 PM	systemd	Reached target Graphical Interface.
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639457.940:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	tlp	Applying power save settings...done.
30/4/19 11:50 PM	tlp	Setting battery charge thresholds...done.
30/4/19 11:50 PM	systemd	Started TLP system startup/shutdown.
30/4/19 11:50 PM	audit	SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	systemd	Startup finished in 4.236s (kernel) + 2.869s (userspace) = 7.106s.
30/4/19 11:50 PM	kernel	audit: type=1130 audit(1556639458.380:24): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:50 PM	ModemManager	<info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.4/0000:07:00.0': not supported by any plugin
30/4/19 11:50 PM	dbus-daemon	[system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=536 comm="/usr/bin/NetworkManager --no-daemon ")
30/4/19 11:50 PM	dbus-daemon	[system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
30/4/19 11:51 PM	kernel	r8168: enp7s0: link up
30/4/19 11:51 PM	kernel	IPv6: ADDRCONF(NETDEV_CHANGE): enp7s0: link becomes ready
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7749] device (enp7s0): carrier: link connected
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7755] device (enp7s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7765] policy: auto-activating connection 'Wired connection 1' (6afa3040-6cdb-3251-967e-449dc4b23c6c)
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7773] device (enp7s0): Activation: starting connection 'Wired connection 1' (6afa3040-6cdb-3251-967e-449dc4b23c6c)
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7775] device (enp7s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7781] manager: NetworkManager state is now CONNECTING
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7784] device (enp7s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7791] device (enp7s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.7796] dhcp4 (enp7s0): activation: beginning transaction (timeout in 45 seconds)
30/4/19 11:51 PM	NetworkManager	<warn>  [1556639460.7821] secret-key: failure to generate good random data for secret-key (use non-persistent key)
30/4/19 11:51 PM	avahi-daemon	Joining mDNS multicast group on interface enp7s0.IPv6 with address fe80::e737:41cd:7204:c09.
30/4/19 11:51 PM	avahi-daemon	New relevant interface enp7s0.IPv6 for mDNS.
30/4/19 11:51 PM	avahi-daemon	Registering new address record for fe80::e737:41cd:7204:c09 on enp7s0.*.
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8073] dhcp4 (enp7s0):   address 192.168.1.143
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8074] dhcp4 (enp7s0):   plen 24
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8074] dhcp4 (enp7s0):   expires in 86400 seconds (at 1556725860)
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8074] dhcp4 (enp7s0):   nameserver '192.168.1.1 192.168.1.254'
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8074] dhcp4 (enp7s0):   domain name 'revnet'
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8075] dhcp4 (enp7s0):   hostname 'Linux-px'
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8075] dhcp4 (enp7s0):   router 192.168.1.254
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8079] dhcp4 (enp7s0): state changed unknown -> bound
30/4/19 11:51 PM	avahi-daemon	Joining mDNS multicast group on interface enp7s0.IPv4 with address 192.168.1.143.
30/4/19 11:51 PM	avahi-daemon	New relevant interface enp7s0.IPv4 for mDNS.
30/4/19 11:51 PM	avahi-daemon	Registering new address record for 192.168.1.143 on enp7s0.IPv4.
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8089] device (enp7s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8098] device (enp7s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8102] device (enp7s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8109] manager: NetworkManager state is now CONNECTED_LOCAL
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8178] manager: NetworkManager state is now CONNECTED_SITE
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8180] policy: set 'Wired connection 1' (enp7s0) as default for IPv4 routing and DNS
30/4/19 11:51 PM	dbus-daemon	[system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=536 comm="/usr/bin/NetworkManager --no-daemon ")
30/4/19 11:51 PM	dbus-daemon	[system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8237] device (enp7s0): Activation: successful, device activated.
30/4/19 11:51 PM	NetworkManager	<info>  [1556639460.8245] manager: startup complete
30/4/19 11:51 PM	nm-dispatcher	req:3 'up' [enp7s0]: new request (0 scripts)
30/4/19 11:51 PM	nm-dispatcher	req:3 'up' [enp7s0]: completed: no scripts
30/4/19 11:51 PM	nm-dispatcher	req:4 'connectivity-change': new request (0 scripts)
30/4/19 11:51 PM	nm-dispatcher	req:4 'connectivity-change': completed: no scripts
30/4/19 11:51 PM	NetworkManager	<info>  [1556639461.7413] manager: NetworkManager state is now CONNECTED_GLOBAL
30/4/19 11:51 PM	nm-dispatcher	req:5 'connectivity-change': new request (0 scripts)
30/4/19 11:51 PM	nm-dispatcher	req:5 'connectivity-change': completed: no scripts
30/4/19 11:51 PM	systemd	NetworkManager-dispatcher.service: Succeeded.
30/4/19 11:51 PM	audit	SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:51 PM	kernel	audit: type=1131 audit(1556639467.284:25): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:51 PM	systemd	systemd-hostnamed.service: Succeeded.
30/4/19 11:51 PM	audit	SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:51 PM	kernel	audit: type=1131 audit(1556639487.517:26): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
30/4/19 11:57 PM	kernel	random: crng init done
30/4/19 11:57 PM	kernel	random: 7 urandom warning(s) missed due to ratelimiting
30/4/19 11:57 PM	sddm	Initializing...
30/4/19 11:57 PM	sddm	Starting...
30/4/19 11:57 PM	sddm	Logind interface found
30/4/19 11:57 PM	sddm	Adding new display on vt 1 ...
30/4/19 11:57 PM	sddm	Loading theme configuration from ""
30/4/19 11:57 PM	sddm	Display server starting...
I have tried:
Fresh install KDE free + nonfree
Fresh install Deepin nonfree
Changed drivers in the system.
I will try Gnome sometime and see.
It appears to do it on the nvidia driver.
Windows 10 on this system auto installed the graphics driver, loads quick and seems to run fine.
Typing this I seem to be getting input lag.
So any advice?
Do you have any reason to suspect this is coming from nvidia? Or is that just a guess?
Here is a good way to get/share system info:
inxi -Fxxxz
Here is the output from that.
I seemed to get my CPU wrong its a X5650
 inxi -Fxxxz
System:    Host: Linux-px Kernel: 4.19.36-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.4
           tk: Qt 5.12.3 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Gigabyte model: X58A-UD3R serial: <filter> BIOS: Award v: FH date: 01/06/2012
CPU:       Topology: 6-Core model: Intel Xeon X5650 bits: 64 type: MT MCP arch: Nehalem rev: 2 L2 cache: 12.0 MiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 63981
           Speed: 1599 MHz min/max: 1596/2661 MHz boost: enabled Core speeds (MHz): 1: 1599 2: 1599 3: 1599 4: 1599 5: 1599
           6: 1599 7: 1599 8: 1599 9: 1599 10: 1599 11: 1598 12: 1599
Graphics:  Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia v: 418.56 bus ID: 03:00.0
           chip ID: 10de:128b
           Display: x11 server: X.Org 1.20.4 driver: nvidia compositor: kwin_x11 resolution: 1920x1200~60Hz
           OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 418.56 direct render: Yes
Audio:     Device-1: Intel 82801JI HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           chip ID: 8086:3a3e
           Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 03:00.1
           chip ID: 10de:0e0f
           Sound Server: ALSA v: k4.19.36-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8168 v: 8.045.08-NAPI
           port: ee00 bus ID: 07:00.0 chip ID: 10ec:8168
           IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 7.72 GiB (3.2%)
           ID-1: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB speed: 3.0 Gb/s serial: <filter>
           rev: 6B0Q scheme: MBR
Partition: ID-1: / size: 81.20 GiB used: 7.72 GiB (9.5%) fs: ext4 dev: /dev/sda5
           ID-2: swap-1 size: 14.65 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
Sensors:   System Temperatures: cpu: 27.0 C mobo: N/A gpu: nvidia temp: 37 C
Info:      Processes: 282 Uptime: 37m Memory: 11.72 GiB used: 1.46 GiB (12.4%) Init: systemd v: 242 Compilers: gcc: 8.3.0
           Shell: bash v: 5.0.3 running in: konsole inxi: 3.0.33
Considering it seems to only do it on the video-nvidia driver and not the video-linux driver which loads up fairly quick leads me to suspect it is a graphical thing.
When I disabled quiet boot to show the verbose output the system would stall on "Started TLP system startup/shutdown" which from looking lead me to find various driver related issues on this forum but non were relevant as I eventually could load and speed it up by switching screens which I assume was forcing a (normal function) kwin display manager reset from the KDE notification.
Also to add I tried all video ports on the graphics card with the same result.
I will later test my GTX 1070 on here from my main i7 970k rig and see if the black screen continues.
Strange I removed video-nvidia and had just video-linux and it still had the black screen hang.
I pressed Ctrl-Alt-F2 and the desktop instantly came up.
Any ideas as this is strange?
Possibly entropy.
What happens if you create input by typing keys and moving mouse (dont switch, just make noise) ?
If that works then it probably is entropy.
Do you have haveged installed and enabled ?
I just found a post about it and seemed to do the trick installing it even with the nvidia driver.
I will need to look up what entropy is and why it happens.
Seems haveged isn't a default install thing.
I think it is installed by default, but not enabled.
Basically in order to create randomness and general noise.
The system relies on this in a number of ways, like encryption/decryption.
A lot of hardware does this on its own in one way or another.
But if it does not then we install/enable haveged which will do it for you on the software side.
Always be up to date before installing stuff:
sudo pacman-mirrors -f && sudo pacman -Syyu
Install haveged:
sudo pacman -S haveged
Enable the service (and start it):
systemctl enable haveged --now
@moson I think you might be right that it is included in most ISOs by default, but not enabled.
Considering it isnt too big, and can be required, I think this is a fair scenario.
I'm wondering what is exhausting the entry pool that much and why it's using the blocking /dev/random instead of urandom (i can understand for crypto you'd want this but for everything else PRNGs should do fine). Those posts are seen quite often here. A bit strange.
True enough.
I have no idea how to go about getting more info on it though :thinking: ..
Wait, where did you get this from:
I had just assumed entropy wasnt being created, or not in a way that the kernel knows .. ie not the right fan sensor, no firmware to do it, blah.
When you request data from /dev/random your entry pool goes down and it blocks when there is not enough random data to be provided (which is generated by mouse, keyboard events, irq's and whatnot, so something which is truly random, more or less). You can try this by doing cat /dev/random, it'll spit out some random data and stop for a while until enough entropy is available in order to create more random data.
/dev/urandom (PRNG) although, always spits out data regardless if the entry pool is exhausted or not. it just runs some computation to generate "random" data, thus pseudo random.
edit
made a small vid just for fun: :slight_smile:
https://streamable.com/35oo9
I did some reading last night and understand the situation a bit more now.
Yea seems like something that probably should be looked into by Manjaro as after knowing about the Entropy I found quite a few threads I never saw before about it.
This thread is pretty much solved and will mark as such but the discussion about this is something that needs to happen due to amount of instances I have seen just briefly browsing so one if you with more knowledge can start a proper discussion and feedback thread on it.
It isn't just the SDDM display manager (though that was worst for me) but also LightDM has the issue on Deepin etc.
It's not really a manjaro specific issue though. You'll find that in other distros as well.
Seems something was changed in kernel versions 4.16 and later which blocks urandom read:
