NVIDIA’s proprietary driver 455.45.01-10.0, installed with mhwd
I’m able to use the NVIDIA card (for example with prime-run), but even when I do not use it, it remains on: in fact, the command cat /sys/bus/pci/devices/0000\:01\:00.0/power/runtime_status outputs active instead of suspended.
I have already enabled D3 power management as in NVIDIA’s official guide, but the command still outputs active and I can confirm it because of the poor battery life.
Thank you! Unfortunately, I’ll have to wait for the fix because I tried 5.9 but it does not work well with nvidia-455 driver. Meanwhile, I’ll use this workaround to preserve more battery life and still use the NVIDIA card when required, though with slightly worse performance.
