could not satisfy dependencies:
- unable to satisfy dependency ‘nvidia-430xx-utils=430.64’ required by linux419-nvidia-430xx
I’m so bad at this stuff. Update today
Can you provide the full output and the output of inxi -Fza
Kernel: 4.19.141-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=84f05be4-19cd-4a4b-ba74-168310cebf39 rw quiet
resume=UUID=4b839d9b-16ef-4142-b1a4-92ebf2af0ad7
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.22 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop System: ASUS product: All Series v: N/A serial:
Mobo: ASUSTeK model: X99-E WS v: Rev 1.xx serial:
UEFI: American Megatrends v: 1003 date: 03/04/2015
Topology: 6-Core model: Intel Xeon E5-1650 v3 bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3F (63) stepping: 2 microcode: 43
L2 cache: 15.0 MiB
bogomips: 83953
Speed: 1199 MHz min/max: 1200/3800 MHz Core speeds (MHz): 1: 2044 2: 1199
3: 1200 4: 1205 5: 1199 6: 1199 7: 1199 8: 1211 9: 2191 10: 1200 11: 1200
12: 1200
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Device-1: NVIDIA GM200 [GeForce GTX TITAN X] vendor: eVga.
driver: nvidia v: 430.64 bus ID: 05:00.0 chip ID: 10de:17c2
Display: x11 server: XOrg 1.20.8 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 445x278mm (17.5x10.9")
s-diag: 525mm (20.7")
Monitor-1: DVI-I-1 res: 1680x1050 hz: 60 dpi: 90
size: 473x296mm (18.6x11.7") diag: 558mm (22")
OpenGL: renderer: GeForce GTX TITAN X/PCIe/SSE2 v: 4.6.0 NVIDIA 430.64
direct render: Yes
Device-1: Intel C610/X99 series HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8d20
Device-2: NVIDIA GM200 High Definition Audio vendor: eVga.
driver: snd_hda_intel v: kernel bus ID: 05:00.1 chip ID: 10de:0fb0
Device-3: Philips (or NXP) type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-10.1:5
chip ID: 0471:2118
Sound Server: ALSA v: k4.19.141-2-MANJARO
Device-1: Intel Ethernet I218-LM vendor: ASUSTeK driver: e1000e v: 3.2.6-k
port: f020 bus ID: 00:19.0 chip ID: 8086:15a0
IF: eno1 state: down mac:
Device-2: Intel I210 Gigabit Network vendor: ASUSTeK driver: igb
v: 5.4.0-k port: c000 bus ID: 0e:00.0 chip ID: 8086:1533
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac:
Local Storage: total: 2.27 TiB used: 302.16 GiB (13.0%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: rev: 1B6Q scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD2000FYYZ-01UL1B2
size: 1.82 TiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: rev: 1K03 scheme: MBR
ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
serial: rev: 1B6Q scheme: MBR
ID-1: / raw size: 198.14 GiB size: 194.03 GiB (97.93%)
used: 42.54 GiB (21.9%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 34.45 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 22%
Processes: 265 Uptime: 45m Memory: 31.32 GiB used: 3.65 GiB (11.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 7/8/9 clang: 10.0.1
Packages: pacman: 1448 lib: 442 Shell: Bash v: 5.0.18
running in: gnome-terminal inxi: 3.1.05
had to take out some links there as not allowed to post them
Could you edit the post, select the output of inxi and press the </>
button on the toolbar?
And what do you do to get this error, and what’s the full output?
I’m trying to install latest updates from pacman (also tried it from terminal)
I get this -
Failed to prepare dependencies
conflicting dependencies:
removing nvidia-430xx-utils breaks dependency ‘nvidia-430xx-utils’ required by lib32-nvidia-430xx-utils
When you have this kind of error it is actually not a real ‘error’, it is because another package forbids the removal of another one, so you need to find the culprit.
Package from memory that could do that to your nvidia drivers are the metapackages like linux-latest or linux-lts, but it can also be an application like Cuda, NvidiaSystem Monitor, and so on.
Please post the full terminal output from your initial command to the error you get (and please, click the </>
button then paste your terminal output in the preformated block the button creates).
PS: pacman is the terminal tool, the GUI tool you’re probably talking about is called Pamac, not Pacman
Yes Pamac sorry.
This is what I get if I use sudo pacman -Syu
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Starting full system upgrade…
:: Replace xapps with community/xapp? [Y/n] y
resolving dependencies…
:: nvidia-450xx-utils and nvidia-430xx-utils are in conflict (nvidia-libgl). Remove nvidia-430xx-utils? [y/N] y
:: unable to satisfy dependency ‘nvidia-430xx-utils=430.64’ required by linux419-nvidia-430xx
:: removing nvidia-430xx-utils breaks dependency ‘nvidia-430xx-utils’ required by lib32-nvidia-430xx-utils
You didn’t paste properly, only your first line is properly formatted. Anyway, did yo ucheck what I said? Do you have one of the application I listed installed on your system?
linux-latest
linux-lts
cuda
nvidia-system-monitor
Sorry i cant get the hang of it.
I know I have CUDA, is there a command I can use to search for the others?
Ok. Do you need CUDA? I mean do you use it for anything special?
Huge majority of people do not need CUDA at all. I’m a hardcore gamer and do not use it at all if you wonder if you require it for games.
Ahh ok i’ll try that.
Yup I need CUDA, i do a little gaming but do 3D modeling mainly so it’s necessary for me.
ooooh it worked as far as the updates go.
when trying to re-install CUDA it said
Warning: removing nvidia-430xx-utils breaks dependency 'nvidia-430xx-utils' required by lib32-nvidia-430xx-utils
Add lib32-nvidia-430xx-utils to remove
Warning: removing nvidia-430xx-utils breaks dependency 'nvidia-430xx-utils=430.64' required by linux419-nvidia-430xx
Add linux419-nvidia-430xx to remove
it’s still downloading it though
Welp.
It broke.
After restart I get this error
“Failed to start light display manager”
I’m on my phone
It shouldn’t have break anything if you only removed CUDA, updated the system.
I’ll try to see the forum for more info about your issue, it is maybe unrelated to your action and is something in the update but that is weird.
What happened then before you reboot (didn’t ask you to reboot by the way)?
Did update finish successfully?
Did you successfully reinstall CUDA?
Yeah as far as I can tell it all went fine.
I guess it’s time for a fresh install perhaps? Good job I keep my important stuff on a separate hard drive
No you’ll get on track sooner than you think, It is probably a minor issue I think (OK it is big issue for you right now you can’t use PC lol).
You can access a terminal from your non working computer with CTRL+ALT+F2 this will switch you to another TTY where you can login and type commands (and from TTY you do ALT+F1 to get back to desktop/broken computer).
Wait a little for someone to jump in or that I find some more info for you.
EDIT in the mean time can you check if video drivers are properly installed, maybe try to reinstall them from TTY?
To list installed drivers:
mhwd -li
mhwd -li
Video-nvidia-430xx 2019.10.25 free driver = false PCI
Warning no installed USB configs
