NVIDIA-bumblebee stops working, needs to be reinstalled
#21
And a shutdown/boot later:
glxinfo | grep -i vendor
shows the same
but there is 2 errors more with
/usr/bin/flatpak run --branch=stable --arch=x86_64 --command=/app/bin/steam-wrapper --file-forwarding com.valvesoftware.Steam @@u %U @@
Couldn’t find dpkg, please update steamdeps for your distribution.
Running Steam on org.freedesktop.platform 1.6 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Installing breakpad exception handler for appid(steam)/version(1522709999)
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
#22
Driver should work according to
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
Everything seems to work ok.
For me the problem isn’t solved. Steam is why I notice this and it’s not working. Please remember that everything works after installing video-hybrid-intel-nvidia-bumblebee, but only after the first bootup with it. Also AFIK the nvidia driver on this card, doesn’t allow videodecoding or the use of hwencoding of videos, so I need the intel card to.
inxi -b
System: Host: hc-pc Kernel: 4.16.7-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.12.5
Distro: Manjaro Linux 17.1.10 Hakoila
Machine: Type: Laptop System: Dell product: Vostro 5568 v: N/A serial: N/A
Mobo: Dell model: 0CWJTV v: A00 serial: N/A UEFI [Legacy]: Dell v: 1.1.4 date: 06/02/2017
Battery: ID-1: BAT0 charge: 42.0 Wh condition: 39.1/42.0 Wh (93%)
CPU: Dual Core: Intel Core i5-7200U type: MT MCP speed: 1893 MHz min/max: 400/3100 MHz
Card-1: Intel HD Graphics 620 driver: i915 v: kernel
Card-2: NVIDIA GM108M [GeForce 940MX] driver: nvidia v: 396.24
Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 396.24
Network: Card-1: Intel Wireless 3165 driver: iwlwifi
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
Drives: HDD Total Size: 698.65 GiB used: 90.86 GiB (13.0%)
Info: Processes: 191 Uptime: 9m Memory: 15.49 GiB used: 3.33 GiB (21.5%)
Shell: bash inxi: 3.0.07
#23
Have a nice time!
#24
Thank you for your time spend on this error.
I can’t play any games the requieres nvidia more than after the first install of the drivers, so it’s not just steam
#25
I thought I was going crazy! I have this issue too, and somehow couldn’t find this discussion using the forum search.
Tried discussing this here, however this thread has a much better description of what I find in my system.
My conclusion is same as OP, this is a driver issue and there is nothing much to do with this, except fill a report and wait for fixes. Also, would like to add that installing Nvidia prime is not working as well in my case.
#26
I HAD the exact same issue.
i had to remove already installed bumblebee, reinstall it. reboot, cross fingers, after every second or third boot.
for the last week i didn’t have to do anything. if anyone can tell me to see what updates/changes i made to my system via add-remove-software and tell me how to find a log i can provide it to see how it got resolved by itself.
#27
package changes (updating/uninstalling/installing) are logged in /var/log/pacman.log.
if you encounter that issue again you could check xorg.log and maybe dmesg (and if you’re using a display-manager systemctl status output)
#28
I believe this was a bug in kernel-alive which is now fixed. If it is not fixed, remove kernel-alive to verify.
#29
I’m sorry for you, who also has this annoying problem, but glade I’m not the only one. :angel:
I have made the following change in
/etc/bumblebee/bumblebee.conf
Under
[driver-nvidia]
I changed:
PMMethod=auto
to
PMMethod=bbswitch
It seems as that made the reinstalls needed to go down to something like 3-5 shutdowns, before the driver is gone again.
Note: I have no evidence that the change does anything…
I now use this method to un/reinstall:
Login on another screen and run a script with:
mhwd -r pci video-hybrid-intel-nvidia-bumblebee
wait
mhwd -i pci video-hybrid-intel-nvidia-bumblebee
logout of the normal session and do a
ctrl+alt+deletebackspace
and login again and check with
primusrun inxi -Gxzc0
#30
I have never had this installed.
#31
Yesterday I upgraded to the 1/7 update.
The problem is still there.
sh: line 1: 13296 Segmentation fault (core dumped) /sbin/glxinfo 2> /dev/null
Graphics: Card-1: Intel HD Graphics 620 driver: i915 v: kernel bus ID: 00:02.0
Card-2: NVIDIA GM108M [GeForce 940MX] driver: nvidia v: 396.24 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: intel resolution: 1920x1080~60Hz
Message: No advanced graphics data found on this system.
#32
I also have similar issues, but it does not happen so often.
What I noticed, that on the fresh boot, the bumblebee works fine. But after suspend it is broken.
I do not need to reinstall, just a restart works.
I have the similar problem with Plasma and currently on Gnome.
Later I will add the exact error when I try to use primus/opt - run after a suspend.
#33
Works just fine for me since forever with PMMethod=auto
Some kernel releases are sketchier than others but optirun both starts and shutdowns correctly with 4.17.3-1-MANJARO even after resume from hibernate(!).
System:    Host: mjr-inspiron Kernel: 4.17.3-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.13.2
           Distro: Manjaro Linux 17.1.11 Hakoila
Machine:   Type: Laptop System: Dell product: Inspiron 7577
CPU:       Topology: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP L2 cache: 6144 KiB
           Speed: 1058 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1100 2: 1100 3: 1100 4: 1100
Graphics:  Card-1: Intel driver: i915 v: kernel
           Card-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: N/A
           OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2) v: 4.5 Mesa 18.1.3
# Configuration file for Bumblebee. Values should **not** be put between quotes
## Server options. Any change made in this section will need a server restart
# to take effect.
[bumblebeed]
# The secondary Xorg server DISPLAY number
VirtualDisplay=:8
# Should the unused Xorg server be kept running? Set this to true if waiting
# for X to be ready is too long and don't need power management at all.
KeepUnusedXServer=false
# The name of the Bumbleblee server group name (GID name)
ServerGroup=bumblebee
# Card power state at exit. Set to false if the card shoud be ON when Bumblebee
# server exits.
TurnCardOffAtExit=false
# The default behavior of '-f' option on optirun. If set to "true", '-f' will
# be ignored.
NoEcoModeOverride=false
# The Driver used by Bumblebee server. If this value is not set (or empty),
# auto-detection is performed. The available drivers are nvidia and nouveau
# (See also the driver-specific sections below)
Driver=nvidia
# Directory with a dummy config file to pass as a -configdir to secondary X
XorgConfDir=/etc/bumblebee/xorg.conf.d
# Xorg binary to run
XorgBinary=Xorg
## Client options. Will take effect on the next optirun executed.
[optirun]
# Acceleration/ rendering bridge, possible values are auto, virtualgl and
# primus.
Bridge=auto
# The method used for VirtualGL to transport frames between X servers.
# Possible values are proxy, jpeg, rgb, xv and yuv.
VGLTransport=proxy
# List of paths which are searched for the primus libGL.so.1 when using
# the primus bridge
PrimusLibraryPath=/usr/lib/primus:/usr/lib32/primus
# Should the program run under optirun even if Bumblebee server or nvidia card
# is not available?
AllowFallbackToIGC=false
# Driver-specific settings are grouped under [driver-NAME]. The sections are
# parsed if the Driver setting in [bumblebeed] is set to NAME (or if auto-
# detection resolves to NAME).
# PMMethod: method to use for saving power by disabling the nvidia card, valid
# values are: auto - automatically detect which PM method to use
#         bbswitch - new in BB 3, recommended if available
#       switcheroo - vga_switcheroo method, use at your own risk
#             none - disable PM completely
# https://github.com/Bumblebee-Project/Bumblebee/wiki/Comparison-of-PM-methods
## Section with nvidia driver specific options, only parsed if Driver=nvidia
[driver-nvidia]
# Module name to load, defaults to Driver if empty or unset
KernelDriver=nvidia
PMMethod=auto
# colon-separated path to the nvidia libraries
LibraryPath=/usr/lib/nvidia:/usr/lib32/nvidia:/usr/lib:/usr/lib32
# comma-separated path of the directory containing nvidia_drv.so and the
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia/xorg,/usr/lib/xorg/modules
XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
## Section with nouveau driver specific options, only parsed if Driver=nouveau
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
XorgConfFile=/etc/bumblebee/xorg.conf.nouveau
Section "ServerLayout"
    Identifier "Layout0"
	Option "AutoAddDevices" "true"
EndSection
Section "Device"
	Identifier  "Device1"
	Driver      "nvidia"
	BusID       "PCI:1:0:0"
	VendorName "NVIDIA Corporation"
	Option "NoLogo" "true"
	Option "ConnectedMonitor" "DFP"
	Option "UseEDID" "true"
EndSection
/etc/default/tlp
TLP_ENABLE=1
TLP_DEFAULT_MODE=AC
TLP_PERSISTENT_DEFAULT=0
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=180
MAX_LOST_WORK_SECS_ON_BAT=300
CPU_HWP_ON_AC=balance_performance
CPU_HWP_ON_BAT=balance_power
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
ENERGY_PERF_POLICY_ON_AC=performance
ENERGY_PERF_POLICY_ON_BAT=power
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
DISK_SPINDOWN_TIMEOUT_ON_AC="0 100"
DISK_SPINDOWN_TIMEOUT_ON_BAT="0 70"
SATA_LINKPWR_ON_AC="max_performance"
SATA_LINKPWR_ON_BAT="max_performance"
AHCI_RUNTIME_PM_TIMEOUT=15
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=default
RADEON_POWER_PROFILE_ON_BAT=low
RADEON_DPM_STATE_ON_AC=performance
RADEON_DPM_STATE_ON_BAT=battery
RADEON_DPM_PERF_LEVEL_ON_AC=auto
RADEON_DPM_PERF_LEVEL_ON_BAT=auto
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=on
WOL_DISABLE=Y
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_AC=1
BAY_POWEROFF_ON_BAT=1
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
RUNTIME_PM_DRIVER_BLACKLIST="amdgpu nouveau nvidia radeon"
USB_AUTOSUSPEND=1
USB_BLACKLIST_BTUSB=0
USB_BLACKLIST_PHONE=1
USB_BLACKLIST_PRINTER=1
USB_BLACKLIST_WWAN=1
USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=1
RESTORE_DEVICE_STATE_ON_STARTUP=1
DEVICES_TO_DISABLE_ON_STARTUP=""
DEVICES_TO_ENABLE_ON_STARTUP="wifi bluetooth"
DEVICES_TO_DISABLE_ON_SHUTDOWN=""
DEVICES_TO_DISABLE_ON_BAT="wwan"
DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="wifi wwan"
DEVICES_TO_DISABLE_ON_LAN_CONNECT="wwan"
DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT="wwan"
DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT="wifi"
Bumblebee error - Could not enable discrete graphics card
#34
This is not a bug that everyone has, only the selected few :wink:
System:    Host: hc-pc Kernel: 4.17.3-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.13.2
CPU:       Dual Core: Intel Core i5-7200U type: MT MCP speed: 1365 MHz min/max: 400/2500 MHz
           Card-2: NVIDIA GM108M [GeForce 940MX] driver: N/A
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.5 Mesa 18.1.3
I don’t use a swap partition, so can’t say anything about hibernate.
Thankyou for sharing your settings, here are the diffs from yours and mine. Maybe someone can spot if there’s any fatal differences:
That file is equal to yours. It seems to get changed to default on every update?,
so now I also have
PMMethod=auto
I’ll keep it to see if it does change the frequent of needed un/installs.
diff -w slet /etc/bumblebee/xorg.conf.nvidia
8c8
<       Option "AutoAddDevices" "true"
>     Option "AutoAddDevices" "false"
14d13
<       BusID       "PCI:1:0:0"
16a16
>     Option "UseEDID" "false"
18d17
<       Option "UseEDID" "true"
19a19
/etc/default/tlp
cat /etc/default/tlp | sed -e 's/\#.*//' | sed '/^\s*$/d' >slet2
diff -w slet slet2
6,7c6,7
< MAX_LOST_WORK_SECS_ON_AC=180
< MAX_LOST_WORK_SECS_ON_BAT=300
> MAX_LOST_WORK_SECS_ON_AC=15
> MAX_LOST_WORK_SECS_ON_BAT=60
18,21c18,19
< DISK_SPINDOWN_TIMEOUT_ON_AC="0 100"
< DISK_SPINDOWN_TIMEOUT_ON_BAT="0 70"
< SATA_LINKPWR_ON_AC="max_performance"
< SATA_LINKPWR_ON_BAT="max_performance"
> SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
> SATA_LINKPWR_ON_BAT="med_power_with_dipm max_performance"
37,38c35,36
< BAY_POWEROFF_ON_AC=1
< BAY_POWEROFF_ON_BAT=1
> BAY_POWEROFF_ON_AC=0
> BAY_POWEROFF_ON_BAT=0
42,43c40,41
< RUNTIME_PM_DRIVER_BLACKLIST="amdgpu nouveau nvidia radeon"
< USB_AUTOSUSPEND=1
> RUNTIME_PM_DRIVER_BLACKLIST="amdgpu nouveau nvidia radeon pcieport"
> USB_AUTOSUSPEND=0
45c43
< USB_BLACKLIST_PHONE=1
> USB_BLACKLIST_PHONE=0
48,61c46
< USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=1
< RESTORE_DEVICE_STATE_ON_STARTUP=1
< DEVICES_TO_DISABLE_ON_STARTUP=""
< DEVICES_TO_ENABLE_ON_STARTUP="wifi bluetooth"
< DEVICES_TO_DISABLE_ON_SHUTDOWN=""
< DEVICES_TO_DISABLE_ON_BAT="wwan"
< DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="wifi wwan"
< DEVICES_TO_DISABLE_ON_LAN_CONNECT="wwan"
< DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
< DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
< DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
< DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT="wwan"
< DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT="wifi"
> RESTORE_DEVICE_STATE_ON_STARTUP=0
#35
I would focus on xorg config.
Contrary to what I pasted, mine also includes a plethora of commented-out lines because unfortunately getting it to work just right seems to be akin to devising a magical incantation that changes every so often with kernel/xorg/mesa releases.
#36
I tested, but it seems not to be related. Unfortunately. Thanks for trying to help.
#37
Well, I found a workaround, which requires an extra reboot. I either remove 20-intel.conf or add it again depending on the state, then I reboot. This is working every time, so I suppose the problem is related to DRI.
Section "Device"
        Identifier  "Intel Graphics"
        Driver      "intel"
        Option      "DRI" "2"             # DRI3 is now default
        Option      "AccelMethod"  "sna" # default
        #Option      "AccelMethod"  "uxa" # fallback
EndSection
#38
I’m running stable, if that has any influence on things.
Since the update to 1/7, I have had this bug twice, but only on the boot right after the update and then one more time a couple of boots later. Since then, the driver is loaded on every boot.
I don’t have 20-intel.conf
locate intel.conf
/etc/X11/mhwd.d/intel.conf
cat /etc/X11/mhwd.d/intel.conf
## Generated by mhwd - Manjaro Hardware Detection
Section "Device"
    Identifier  "Device0"
    Driver      "intel"
    BusID       "PCI:0:2:0"
        Option      "DRI"    "true"
EndSection
Section "DRI"
        Group  "video"
        Mode   0666
EndSection
Section "Extensions"
    Option "Composite" "Enable"
    Option "RENDER"    "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
#39
This seems to be solved. I don’t know what solved it but, the driver always loads now.
#40
