I’m running Manjaro stable with 6.6.0.1 kernel and 535.129.03 nvidia drivers. I was wondering if the latest new features branch version 545.29.02 are supported on that kernel.
Yes, it does. However, the 545 series is only in the unstable branch thus far. See Switching Branches - Manjaro
No, it doesnt and no it isn’t. That was referencing the 470 series.
Stigmatism.
Works on unstable, just installed kernel66.
inxi -G ✔
Device-1: NVIDIA GA102 [GeForce RTX 3090] driver: nvidia v: 545.29.02
Device-2: AMD Raphael driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau dri: radeonsi
gpu: amdgpu resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia,radeonsi,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
renderer: AMD Radeon Graphics (raphael_mendocino LLVM 16.0.6 DRM 3.54
6.6.0-2-MANJARO)
API: Vulkan v: 1.3.269 drivers: nvidia,radv surfaces: xcb,xlib
Thank you for your reply,
Is this only for the official manjaro repositories? Yesterday I installed the 545 from the run file on the Nvidia website just fine but with the 6.5. kernel.
Dont do that.
So just as a rule of thumb → always install everything through pacman and official repos?
I made a backup before doing that and have already reverted to it so now just switch branches and install the new drivers via pacman?
Not only on manjaro, on everything that is linux (there are a few exceptions) use whatever repository you have access to.
Downloading and installing from a website is a windows thing.
No need to install with pacman, follow yochans instructions on how to switch branch and your installed nvidia drivers will update to the version in the unstable branch.
If you want to change to the latest kernel:
